Postshading on WWII Russian tanks
    December 2011
Posted by Chrisk-k on Sunday, February 5, 2012 10:03 PM
Since the color of WWII Russian tanks is dark, I wonder if postshading using a diluted black paint would result in a noticeable effect. Am I worried too much? Smile
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    January 2003
Posted by TomZ2 on Sunday, February 5, 2012 10:58 PM
4BO (4БО) paint differ are a middle gray-green, sometimes it are a little darker, very near too dark green/dark gray, so nearly each green and gray can be justified. Some of the pigment with some oil, gasoline, kerosene or diesel, so there were many colors of the “correct” or “exact” Russian Green:
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    January 2007
Posted by the doog on Monday, February 6, 2012 11:53 AM
I would instead mix black with some of the base coat green that you choose to use. Black might be just too harsh and if you dilute it too much you're not going to be able to control it as well as a regular coat that you can spray into creases and crevices.
You could then use straight black as a pin wash. That way you would have the darkest black in the deepest areas of shadow.
    January 2003
Posted by TomZ2 on Monday, February 6, 2012 4:31 PM
the doog
"Black" green or very dark gray. Don't use black.
