Mobelwagon w/ 37mm, how to make the storage bin doors?
    April 2007
Posted by ipmsfan45 on Tuesday, October 30, 2012 6:48 PM
Hello all, or I guess this question is directed towards Wild Bill. I have seen posts on here that tell of a build you did on the Tamiya Mobelwagon & how you scratch built the storage bin doors for it. If I could pick your brain, Id like any info you could pass along to me please. Thanks for any help. Kurt
    July 2004
Posted by wbill76 on Wednesday, October 31, 2012 1:20 PM
Kurt,
I didn't scratch-build the ammo bins on my build, I used the parts available in an Eduard PE upgrade set.
Having said that, if I were to go about scratchbuilding them I would use some thin aluminum or brass sheet and scribe in the necessary "X" reinforcements from the back side using something hard to emboss the pattern on the outer surface. HTH!
    November 2004
Posted by spacepacker on Thursday, November 1, 2012 3:56 AM
I have used Bill's build for reference and made mine from foil, using a cocktail stick to do the embossing. Very easy to do
Cheers....Kenny
    April 2007
Posted by ipmsfan45 on Friday, November 2, 2012 9:12 AM
My Bad Bill, Thanks for the info, I will give it a go &  see what happens.
    October 2009
Posted by PANZERWAFFE on Sunday, November 18, 2012 8:14 AM
Kenny, thanks for the explanation of how you achieved this with the foil.  It gave some excellent results and will be trying your method out myself.  Was wondering how you did this Beer
Rob
