T-35 Heavy Tank ~ ICM #35043
    September 2011
Posted by David Maddog on Sunday, November 11, 2012 12:59 PM
My next project is this beast of a tank, the T-35.  Overall this kit looks simple but the order of assembly calls for the tracks to be put on at an early stage since they will get buttoned up around the armor of the tank.  I like to assemble as much as I can, if not the entire kit aside from the wheels/tracks, before I start painting.  I can never seem to remove enough paint and so the bond isn't strong and it gets messy but that's just me.  So I think I may buy some Fruilmodel tracks which should allow me to put tracks on at the very end.  Another issue is that the upper hull is such a large molded piece, it has a nasty bend to it.  After gluing I think it will hold but I may need to he at it up to tank some of the warping out.  I'll update soon with pics.
    January 2006
Posted by SprueOne on Sunday, November 11, 2012 1:55 PM
The last ICM kit I built was the IT-28 Soviet Bridgelayer. I straightened the warped hull with the dunk in hot water technique.
And for the mold release grease, I soaked and agitated all the sprue trees in Denatured Alcohol and let air dry on a paper towel. The stuff was thick...
http://i91.photobucket.com/albums/k290/SprueOne/IT_28_bridgelayer/T-28_DA_agitation_tub.jpg
http://i91.photobucket.com/albums/k290/SprueOne/IT_28_bridgelayer/T-28_DA_dry.jpg
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    January 2006
Posted by SprueOne on Sunday, November 11, 2012 2:01 PM
I don't have the T-35 kit but looks like you can CA glue the side armor skirts in place last. With CA you don't have to scrape and a light coat of flat will hide the glue spots.
The ICM box stock indie track links for the IT-28 were really nice to work with so I used them
I'll be watching this build
    September 2011
Posted by David Maddog on Sunday, November 11, 2012 4:24 PM
I'll have to look it over again and see if it will work.  I also haven't had luck with CA sometimes, the bond over paint didn't seem good.  Maybe I need to find a better brand of CA, I'm using a generic brand called Extreme Power from Hobby Lobby.  For all of my prepainting glue, I use Proweld.
And you are right about the grease, it's all over.  I wasn't sure if just soap and water would do but you're suggestion looks like a winner.  Thanks for the tip!
Posted by tigerman on Sunday, November 11, 2012 8:28 PM
Hi David. It should turn out great if it looks anything like the BT-35. Cool
 Eric
Posted by Gamera on Monday, November 12, 2012 7:41 AM
Ohhhh looking forward to seeing this monster come together!
    July 2004
Posted by wbill76 on Monday, November 12, 2012 5:11 PM
These land-ships are always fun to watch come together, looking forward to see what you do with this one!
    October 2009
Posted by PANZERWAFFE on Sunday, November 18, 2012 9:17 AM
The T-35 and T-28 have always fascinated me !!!  I have both of them in the stash.  REALLY looking forward to see what you do with yours, will be watching Yes
Rob
    September 2011
Posted by David Maddog on Monday, November 19, 2012 9:06 PM
It took me a good part of a day to assemble all of the wheel assemblies and lower chassis, but the fits are very good, and all of the wheels line up very well. Next is the upper chassis, to which I hope I can take more progress shots. I got so into the lower chassis I failed to take any real step by step shots.
Because I prefer to assemble as much as I can before painting, and that if I used the stock tracks, the side shields would make it difficult to paint, so I ordered the friul tracks; plus it will help show real sag. I opted out of the Eduard PE however, I am pleased with the detail of the kit.
    July 2004
Posted by wbill76 on Tuesday, November 20, 2012 8:59 AM
A sure sign you're having fun is when time flies and you forget to take pictures of the progress! Beer Rolling right along with this one David. You might want to fill some of the gaps around the joins of the MG turrets with puttty. IIRC these were welded constructions and ICM didn't mold on the weld seams.
Posted by Gamera on Tuesday, November 20, 2012 9:34 AM
Wow, now that's some complex running gear!
    July 2006
Posted by telsono on Tuesday, November 20, 2012 3:27 PM
I like Friul tracks, but not the wire they supply as it's too soft. From hobby shops you can get music wire of the same diameter whic is striffer and won't bend as you insert it through the holes. the wire that Friul supplies bends so much that it's for me a pain to work with.
Mike T.
Beware the hobby that eats.  - Ben Franklin
Do not fear mistakes. You will know failure. Continue to reach out. - Ben Franklin
The U.S. Constitution  doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself. - Ben Franklin
    January 2006
Posted by SprueOne on Tuesday, November 20, 2012 7:25 PM
Wow, I didn't know this kit had so much stock interior details. I want to get one of these kits now.
Looks like you're boring out the pistol ports and peep slots in the little turrets for added realism too.
Tags: soviet armor , ICM
    September 2011
Posted by David Maddog on Tuesday, November 20, 2012 9:15 PM
Yeah, I thought that it'd be proper to drill those out.
As for the weld seams on the turret, how would I go about doing so?  Fill and sand the joints, and then put some testors glue on the corner and flatten them down with a knife?  I've heard of stretched sprue being glued along the corners and knifed down as well.  Any tips on this as I have not attempted it before?
    November 2008
Posted by plasticjunkie on Tuesday, November 20, 2012 9:40 PM
Brings the interior including the engine? For the weld seams, try stretched sprue then apply liquid cement. Let the sprue soften and use a knife or small screwdriver to texture the seams.
 GIFMaker.org_jy_Ayj_O
    January 2006
Posted by SprueOne on Tuesday, November 20, 2012 10:50 PM
For the weld seams on the IT-28 Bridgelayer, I got lazy with mine and didn't include the styrene rod or stretched sprue along the channel:
1) made a tool for shaping the softened plastic into a textured 'weld' bead
http://i91.photobucket.com/albums/k290/SprueOne/IT_28_bridgelayer/weldseam_rod.jpg
2) scribed with a sharp knife where the weld seam would be unless the kit parts already made one by it's assembled joint
http://i91.photobucket.com/albums/k290/SprueOne/IT_28_bridgelayer/weldseam_scribe.jpg
3) after running liquid cement along the channel to soften the plastic, I used the burnishing tool to shape the bead texture
http://i91.photobucket.com/albums/k290/SprueOne/IT_28_bridgelayer/weldseam_burnish.jpg
4) This is what it looked like after paint. Not the best I've seen but quick and easy
http://i91.photobucket.com/albums/k290/SprueOne/IT_28_bridgelayer/weldseam_weld.jpg
hope this helps
Tags: weld seam
    December 2004
Posted by vonryan on Wednesday, November 21, 2012 11:29 AM
VERY COOL BUILD David. i've always wanted to build one of those for a dio. oh well one day. again AWESOME.
Clay
    October 2009
Posted by PANZERWAFFE on Friday, November 23, 2012 6:38 PM
Looking good Yes  I too often use stretched sprue to make the welds.  Stretch the sprue to the appropriate diameter, glue on, coat several times with Testors liquid cement (pink bottle) to soften the sprue,  Then stipple with hobby knife to make the weld pattern.  Once you do it a few times it's pretty easy.
Many people use putties with really good results also.
Rob
    September 2011
Posted by David Maddog on Saturday, December 8, 2012 4:03 PM
Thanks for in the info guys, very helpful.  I've decided not to try the weld seams for this build, maybe I'll try it on something with fewer turrets ;).  Turrets are finished and I've started adding details to upper chassis.  I also just received my Friul Tracks and started assembling one side, what a chore but well worth it.  This is the first time ever using Friul.
    January 2006
Posted by SprueOne on Saturday, December 8, 2012 7:56 PM
whoa, Five turrets nicely done.
I've never used Friul tracks either so I'm watching to see how these work out
    September 2011
Posted by David Maddog on Saturday, December 8, 2012 10:02 PM
I am pleased with how they turned out and it was relatively easy to assemble, I will definitely be buying more of them! I finished the right side, using 129 links to get the desired sag.
    July 2004
Posted by wbill76 on Sunday, December 9, 2012 11:26 AM
Nice work on the turrets and tracks! Beer
Posted by tigerman on Sunday, December 9, 2012 12:01 PM
Tracks look excellent. The build isn't so bad either. Wink
 Eric
    September 2011
Posted by David Maddog on Sunday, December 9, 2012 4:04 PM
Thanks guys, I just finished the other set of tracks.  Upon further review, most pictures of the T-35 showed that there was barely any slack in the track, I decided to take one link out to tighten it up just a bit.  More pictures to come!
    January 2006
Posted by SprueOne on Sunday, December 9, 2012 4:53 PM
Yeah, the tracks look sweet!
I notice not much slack in historical photo refs as well so I made mine pretty tight on the IT-28.
Slack in tracks looks so good though Cool
Posted by tigerman on Sunday, December 9, 2012 10:34 PM
You won't see the slack with the sides on anyway. correct?
 Eric
    September 2011
Posted by David Maddog on Monday, December 10, 2012 4:41 PM
Actually they will be visible.
    September 2011
Posted by David Maddog on Monday, December 10, 2012 11:19 PM
I've painted the tracks in a Testors Gloss Black spray can and then lightly airbrushed with MM enamel Steel.  Continue work on the upper hull.
Posted by tigerman on Tuesday, December 11, 2012 1:04 AM
David Maddog
Duh. I looked again at the picture on page 1.  Dunce
 Eric
Posted by Gamera on Tuesday, December 11, 2012 10:26 AM
Yeah great work on the treads David, somehow they do look better with a little more sag though. Ah well...
What I think she needs is about five or so more turrets- take it up to an even ten maybe Stick out tongue
