whats the best color to paint rommels greif?i have africa brown and dark yellow both are mm paints.the box color calls for dark yellow.any help is welcomeleon
KURSK "the battle of all battles'
Dark Yellow wouldn't work as it is too yellow. Try Model Master Panzer Dunkelgelb 1943 that is a closer match to the color used on the Greif as it looks like Tamiya Desert sand.
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15 http://photobucket.com/albums/v332/Mikeym_us/
Thanks Mikeym .Just got that color in the mail today
No problem and you can use the Model Master Dark Yellow on some of the projectiles on 1/35 scale tank ammo as that is a pretty close match to Tamiya Lemon Yellow. And another thing to consider with Afrika Korps vehicles is that the paint closely resembles the color of Dijon Mustard which is a yellowish brown and you can lighten the color with some Model Master Flat white to tone the color down to come close to a faded version of the color which would have come from being in the sun for long periods of time.
great tip.might try it for a weathering affect
Leon: I'd suggest using the Afrika Braun `43 with an interior of Panzer Schwarzgrau.
Greg H
"There is many a boy here today who looks on war as all glory, but, boys, it is all hell." Gen. Wm T. Sherman (11 April 1880, Columbus, Ohio)
Thanks for the suggestion,i tried a small spot with africa braun 42 ,but i don't like the color.I'ts
to light.I'm thinking of panzer dunklegleb and panzer schwarzgrau
Leon D
Leon the Sdkfz.250/3 Greif is a open top vehicle and both the interior and exterior are supposed to be the same color. As a matter of fact all Sdkfz.205 series halftracks are open topped and the interior color is the same as the exterior with the exception of the sdkfz.250/9 which is fully enclosed and painted a whitish color on the interior like the Panzer tanks.
Any question about painting the Greif's interior should be directed to WBill as he is way more knowledgeable than me on German Vehicles.
Oh and try painting the Panzer Shwartzgrau first before you paint the Panzer DunkelGelb as that can count as preshading .
Most vehicles sent to Afrika in `41-42 were sent originally painted in schwarzgrau and either repainted (on the exterior only) in country or camo'd using the local earth added to water (or fuel).
Here's a pic of GREIF showing the two-tone on the exterior
In the below pic, it appears the rear interior wall of the 250/3 is not the same color as the exterior
Thanks for the replys,I have a book on the africa korps,and it has pics of Greif ,
I do plan on painting it shwartzgrau,then the panzer dunklegleb.I'll try to post
some pics when i'm done.
Is WBill still on the forum?
Leon
Yes, I'm still here on the forum. When it comes to vehicles sent over to N. Africa, timing and conditions are everything. The first batch of vehicles sent over in '41 were in Panzer Gray and then field camo'd using a whole range of things including painted on mud. Starting in March '41, the first 'Tropen' scheme was ordered for vehicles that used a two-tone disruptive pattern of of 2/3 RAL 8000 and 1/3 RAL 7008 (Testors MM line refers to these colors as Afrika Grunbraun and Afrika Khakibraun respectively but those are their own name inventions!). This 'Tropen' scheme was applied to vehicles at the depots or factories prior to shipment to the theater and the paints were also issued to units in the field to repaint their existing equipment.
The speculation about Grief's scheme is an ongoing one...there are camps that believe that it's sporting a 'hybrid' scheme that includes Panzer Gray for the disruptive pattern along with the RAL 8000 as the main color and others that think it's got the 'Tropen' scheme applied. Open topped vehicles when repainted typically had their exposed interiors painted to match the outside as having that dark of a color contrast would not be a good thing in terms of visibility from the air. I can't say for certain that Grief had a RAL 8000 interior vs. a Pz Gray one (what it would've received if it was a 'standard' 250 and not one repainted with the Tropen scheme) but that's the way I would lean if it were my model in the absence of any clear shots of the interior that show otherwise. HTH!
BP Models
Thanks Bill,there is no clear evidence of how Greif was painted.I have a book on the africa korps
it shows Rommel in Greif and the caption reads Greief was painted in panzer grey and over sprayed
with a sand color.What is the actual definition of sand color.
Leon,
That would be the RAL8000 color I mentioned. Here's what Testors interpreted it to be along with the two-tone camo of RAL 7008 to go with it.
Thanks Bill . great pic.what piece of armor is this?
de009 Thanks Bill . great pic.what piece of armor is this?
I believe that is his DML Bison Leon. And Bill that RAL 8000 definitely fits in with my Dijon Mustard color description.
Leon, I'd suggest using MM (SKU# 2088) sandgelb - it's a Luftwaffe tropical color (RLM 79), but the Heer had a tendency to "liberated" LW paints in Nord Afrika for camo purposes.
Bill's AFV is the Bison II, one of "Rommel's Funnies." Basically, it was an extended Panser II chassis with the 15cm schwere infantrie gun mounted on it.
Mikey
When I built mine the question of colours was giving me a headache, so I painted for a European scheme with whitewash????
I'm no help; am I......cheers....Kenny
LOL, thanks for the laugh Kenny.I've deceided to go with panzer grey base and dunklegleb over that
