Neubau-Fahrzeug Nr. 3-5 Finished! 05-12-13
    January 2007
Posted by the doog on Sunday, May 5, 2013 6:27 PM
Nice progress, no matter how small, Bill. Keep plugging away! I know the feeling--it takes me months to finish something sometimes when I"m in a touring cycle. Just don't lose momentum--that's the important thing!
    May 2003
Posted by rtvmodeler on Sunday, May 5, 2013 7:20 PM
Smile Great build my friend!
Regards!
Rodolfo
Current Project:
Figures from Dragon, "German 6th Army, Stalingrad 1942-1943", 1/35
    July 2004
Posted by wbill76 on Sunday, May 5, 2013 8:58 PM
Karl
thanks as always for the comments/support! I hate it when a build stalls out completely so keeping this one moving especially since it's so close to the finish is important! Wink
Rodolfo
thanks for the comments as well my friend! Beer
    July 2004
Posted by wbill76 on Saturday, May 11, 2013 6:05 PM
With tomorrow being Mother's Day and all, this week's update takes place on a Saturday as a result!
Lots of great progress to report, the build is 99% complete. I picked up from the last round by applying a dull coat using MM Lusterless Flat in the spray can.
After that had dried, it was on to the pigment weathering. I selected Mig Dry Mud to produce the dusty effects as seen in the reference photo posted earlier in the build. This was applied as a wet mixture using ordinary tap water with a drop of liquid dish washing soap added to break the surface tension. It's applied liberally using a sable brush to get it into all the various nooks and crannies.
The wet mix is allowed to air dry and then the removal process begins. The first step is remove excess pigment using a round stiff bristle brush. I wear a dust mask during this process as inhaling the fine pigment powder is not a good idea. After the round brush, I use a series of smaller square and rectangular stiff bristle brushes to get into the harder to reach places and remove excess where necessary.
Next more of the pigment is removed/adjusted using dry cotton swabs. A pair of tweezers is kept handy to remove any snagged fibers that get loose from the swab in the process.
Because of the large hull sides on this vehicle, I wanted to show some dust streaking effects with the pigments. This was accomplished by using a water-dampened large sable brush and drawing the brush downward to pull the pigments into streak lines.
Last but not least, the final details were added for the large head lamp on the hull front in terms of the kit-provided clear lens. The smaller lights on the hull sides under the main turret received some 'lenses' of their own courtesy of small amounts of Testors Window-Maker glue added with a toothpick.
I also took a set of walk-around photos to see if there's anything amiss for final adjustment. Will check tomorrow to see if I need to tweak anything before declaring this one 'done'.
    July 2004
Posted by wbill76 on Sunday, May 12, 2013 5:13 PM
After a few tweaks and adjustments, this one was off to the photo booth for its final walk-around shots.
    April 2005
Posted by JohanT on Sunday, May 12, 2013 5:24 PM
Very Best Regards
Johan
    September 2011
Posted by David Maddog on Sunday, May 12, 2013 6:25 PM
Well done, very nice Bill.
    July 2004
Posted by wbill76 on Sunday, May 12, 2013 6:51 PM
Thanks Johan and David appreciate the comments! Beer
    April 2006
Posted by waynec on Sunday, May 12, 2013 7:06 PM
hi bill
sweet build . i have the cyberhobby one from a few years ago in the bunker "i really want to build this" stash. the weathering is just the right amount, gives it character but isn't overdone. very hard to master the when to stop part.
i have a JGPZ-IV and an LVT(A)-4 base coated. i will be practicing my tri color camo this week, tape for one and silly putty for the other and, if all goes well, i will have 2 builds to use at my weathering demo class for my wood ship club on saturday. i intend to revisit this page and show your technique.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
MrT
    December 2010
Posted by MrT on Sunday, May 12, 2013 10:56 PM
Very good work!!
Terry
Posted by Tojo72 on Monday, May 13, 2013 7:14 AM
Nice Bill,the dust effect is very good
    December 2006
Posted by Jester75 on Monday, May 13, 2013 7:39 AM
Sharp as a tack Bill! Wonderful work!!
Eric
    July 2004
Posted by wbill76 on Monday, May 13, 2013 9:58 AM
Wayne
appreciate the comments! You're right about the weathering, always tough to know 'when' to stop to avoid overpowering the finish. The Jagd IV and LVT are both excellent subjects for weathering given their physical dimensions, sounds like a great opportunity to demo on! Glad to know this one will help you with that, hope it goes well for you!
BeerTerry
,  Anthony, and Eric thanks for the support as well! Yes
    May 2013
Posted by KrashK on Monday, May 13, 2013 12:50 PM
wonderful job, the weathering is right on.
Glenn
Posted by Bish on Monday, May 13, 2013 1:18 PM
Bill, a pleasure as always, watching one of your builds, and always something to learn.
Its a real beaut.
    July 2004
Posted by wbill76 on Monday, May 13, 2013 5:14 PM
Thanks Glenn!
Bish
I had a great time building this one despite the interruptions in the middle. Felt good to finally finish something in 2013. Wink
    July 2006
Posted by redleg12 on Monday, May 13, 2013 7:47 PM
Very nice.....another Bill masterpiece. Real Life is taking chunks out of our bench time. I know exactly how you feel. It feels like I work twice the hours I did 5 years ago. Hopefully the next one will go a bit faster!!
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    August 2012
Posted by Rambo on Tuesday, May 14, 2013 5:14 PM
Good to see this one done Bill it turned out great like always
Clint
    July 2004
Posted by wbill76 on Tuesday, May 14, 2013 5:53 PM
Sorry to hear you're being denied time at the bench, hope it's not a long-term condition! Thanks as always for the comments.
BeerClint
thanks for following along, definitely felt good to get this one on the books for 2013. Beer
    January 2007
Posted by the doog on Wednesday, May 15, 2013 9:19 AM
Bill,
A top-shelf job on this one, honestly. Great weathering and staining, etc. It looks PERFECTLY dusty an all "muted-toney". Big Smile
Really a slammer!
Posted by Gamera on Wednesday, May 15, 2013 12:49 PM
Another great job there Bill! My hat's off to you for taking dull panzer grey and making it look great! Love the mud and weathering.
    July 2004
Posted by wbill76 on Wednesday, May 15, 2013 4:58 PM
Karl
thanks for the comments as always! It was a delicate balancing act but I'm glad it created the 'muted-toney' result I was looking for. Big Smile
Gamera
glad you like how the beast turned out as well. Panzer gray schemes offer a lot of opportunity if you're not afraid to experiment a little bit along the way. Wink
    May 2004
Posted by f8sader on Wednesday, May 15, 2013 6:18 PM
I'll admit, I had to check out this post just to see what a Neubau-Fahrzeug Nr. 3-5 was!  I'm glad I did as that is a very good finish; nice work!
Lon-ski
    July 2004
Posted by wbill76 on Wednesday, May 15, 2013 8:04 PM
f8sader
Glad you stopped in! Thanks for the comments. Beer
    July 2006
Posted by bufflehead on Tuesday, June 4, 2013 12:19 AM
Sorry to be so late responding to the completed thread Bill!  Gotta say this is another BEAUTY!!  The markings came out perfect and the camo scheme and weathering are fantastic!  YesYes
Now that your Neubau is done I guess I better get cracking on the WIP blog of my Dragon Neubau....Whistling
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
    July 2004
Posted by wbill76 on Tuesday, June 4, 2013 9:39 AM
Thanks Ernest! Now you no longer have any excuse for yours. Get cracking mister! Wink
