Cromwell Mk IV scene, just about done.
    August 2012
Posted by AndrewW on Monday, December 31, 2012 11:13 AM
http://s1337.beta.photobucket.com/user/andrews_own/library/Cromwell
Over the course of the month, I've been picking away at Tamiya's Cromwell Mk IV, with a few Tamiya figures and some Verlinden stowage.  I've just about finished off a little base for it using Gaso-Line's house, Verlinden's cobblestones, lampost and power line and Woodland Scenic's dead trees.  The water needs a few more layers, there's a couple of infantry troops to pose yet, but I think overall I'm pretty close to done with it.  The power lines were about the toughest part, and I personally liked the floor, collapsed beam and rubble.
I didn't have too many problems out of the tank, I've read about some poor fit issues, but I didn't find them too glaring.  I also tried a new method for my tracks, white gluing the road wheels on, building the tracks around them, removing and painting.  Then the trick was setting the road wheels in the tracks and mounting, but it turned out quite nicely, and saved having to glob on superglue to get two halves of track together.
Thanks for looking, any comments or criticisms are always welcome
Andrew
Life is hard, it's even harder when you're stupid - John Wayne.
    January 2007
Posted by the doog on Monday, December 31, 2012 2:25 PM
Andrew,
Is this one of your first diorama's? The first thing I can say is that, composition-wise, you might have been better off to have positioned your elements at more oblique angles; i.e., not "square" on the board that serves as your base. Also, try to cut down on  the amount of excessive open space--even though you may have more soldiers to put in yet, they should only support the main focal point, which is the tank.
The cobblestone road looks funny--it's "outlined" by the stones, but does not appear to be at all "traveled". Fill up the roadway with dirt, to better simulate a true "road".
Take a look at the positioning of other dioramas, and the efficient use of space on most of them. I think that that will pay big dividends for your next one. It's not bad for a starter, but could be much improved upon with a little research and redesign. I do have to say that the building turned out nicely.
    August 2012
Posted by AndrewW on Tuesday, January 1, 2013 8:16 AM
Doog,
thanks for the advice, I do appreciate it.  I've 'wooded in' a little more of that open space, and will play a bit at the open space between the stones.  With the road, I was aiming for overgrown areas where tracks would not have run, hence only the track stones exposed.  Next time, I'll look at the oblique angles.
