Adding Cutting-Torch details?
    September 2009
Posted by Hinksy on Saturday, January 5, 2013 10:07 AM
Hi guys,
A quick question: I'd like to add some cutting-torch effects to the ends of the interlocking blocks on my Elefants Casemate? The cutting detail is shown on the box art but the casemate only has weld lines - the cutting torch effect is shown on the big block ends where it all interlocks and looks like several fine rough horizontal lines? I'm assuming these lines are left by a cutting torch?
Now I'm getting a lot better I really want to get these details in place - how can I add these details? Is there a recognised method?
Thanks fellas - I'll be updating my blog later too. I'm out tonight but have a couple of hours now to get a bit done
Ben Toast
On the Bench - Dragon Pz. IV Ausf. G (L.A.H.) Yes
Your image is loading...
Posted by T26E4 on Saturday, January 5, 2013 10:22 AM
I have a set of triangular sectioned files. I roughly go over the surface until I get the look I'm aiming for
Roy Chow
Join AMPS!
http://www.amps-armor.org
    October 2008
Posted by P mitch on Saturday, January 5, 2013 11:11 AM
Just as a suggestion I'd try using some liquid polly on the area, let it get soft and then use a chisel shaped cutter or a good scalpel blade to make the marks
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    September 2009
Posted by Hinksy on Saturday, January 5, 2013 2:16 PM
Cheers guys :-)
