Thanks Bill, and here is more!
So I've added more details. The hinges for the doors and windows are from a piece in the kit that was cut into sections. I used Pro Weld to soften the plastic and then pressed it down to fuse it to the hull.
Here I had to drill holes for a part, not sure if it's a mirror or reflector so if anyone could educate me. I used a small ruler and measured 3mm from the corner down, marked with a pencil and marked 7mm down with the next hole. This piece goes on all 4 corners.
The exhaust here was drilled out, as well as the port for the gun. The license plate also needed a hole drilled for a stable place to seat.
The notek light's base was much too long so I chopped it down.
The clamps for the jack was very difficult.
As is the straps would not full fit all the way around the jack to latch so I had to shave down some plastic for it to fit.
I then ran into the issue of the straps not touching the hull, so I had to sand more on the base of the jack to get it closer to the hull.
I managed to break a strap after bending it too much.
The MG-34 mold had a ball at the base of the barrel which made me realize the gun needed to be inserted from the inside.
So I drilled out the hole and through the turret ring inserted the barrel and glued with Pro Weld.
The PE behind the muffler took a while to figure out how to bend, the instructions were rather vague and showed the piece at odd angles.
