stickpusher- thanks for looking in ! This kit is going to use up precious shelf space!
Doog- Thanks for the heads up about the metal barrel. The kit is really light in the back...prolly would 've nosed in for sure! I found something interesting, the Tamiya thin glue I use was useless on this build...just didn't want to melt the plastic? I switched to Testors thin glue in the glass bottle, and that worked fine....
I pinned the spade w/ a bit of plastic rod, now I can remove it to paint and weather easier. The kit actually shows little flash, but numerous ejector marks in difficult locations. When I glued the breech halves together, the CA glue reacted violently to the plastic, and started showing small fractures . I was able to sand the damage away...heer's a pic of the section
i862.photobucket.com/.../2013-04-19_19-14-17_605_zps1d42d95d.jpg
The spade had a few punch marks in the curved portion...a quick wipe w/ Testors, stippled the surface, and should look like chipped paint after words
i862.photobucket.com/.../2013-04-20_19-16-40_651_zps06162d0b.jpg
The kit is mostly OOB..but the front glacis handles were replaced w/ wire, and I replaced a few damaged bolts.
i862.photobucket.com/.../2013-04-20_19-15-30_52_zps2007b484.jpg
more to come!
