how interchangible are AM shells
    March 2011
Posted by modeler#1 on Thursday, May 2, 2013 11:23 AM
I am looking into getting a 1/35 model that has a 8.8 cm pak 43. I want to include some AM rounds and shells, would a set of 7.5cm Pak 40 shells play the part? I am a little concerned about them looking a little  small.
On the Bench: Nothing atm
Posted by Rob Gronovius on Thursday, May 2, 2013 12:14 PM
Depends on what you are going for; total accuracy or just a representative display of ammo shells.
Posted by Bish on Thursday, May 2, 2013 12:27 PM
As Rob says, it would depend how accurate you want to be. To the eye, I would guess the size might not be that different, at least in diameter. The 88 shells might be a bit longer. If your happy to use them knowing that are not 100% then I would say go ahead.
If you do want to be 100%, both Tamiya and AFV Club do some brass L71 ammo.
    April 2006
Posted by waynec on Thursday, May 2, 2013 12:32 PM
have a gun crew made up of short people. just kidding. if they are regular looking shells probably wouldn't be a problem. in diameter in scale the difference is .4mm.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
Posted by Bish on Thursday, May 2, 2013 12:34 PM
waynec
I think you would have to be a serious rivet counter to spot that.
Posted by T26E4 on Thursday, May 2, 2013 1:44 PM
Pak 75mm shells have no "shoulder" as an 8.8cm shell.  Don't sell yourself short.  These AM kits are cheap and easily available.  8.8cm Pak 43 ammo would look very different than 75mm Pak ammo
Roy Chow
Join AMPS!
http://www.amps-armor.org
    March 2004
Posted by Mikeym_us on Thursday, May 2, 2013 2:58 PM
Bish
The Pak43 used the same ammo as the King Tiger which were longer than the other 88mm ammo.
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    March 2011
Posted by modeler#1 on Thursday, May 2, 2013 4:02 PM
thanks for all the responses!
this is the kit I am thinking of using
www.trumpeter-china.com/.../1987.html
it probably comes with plastic ammo but I would prefer to spruce it up a bit.
    March 2011
Posted by modeler#1 on Friday, May 3, 2013 9:22 AM
quite the difference then Thanks!
