Su-85 detailing and finishing
    April 2005
Posted by Thunderbolt379 on Tuesday, May 28, 2013 11:52 PM
Hi guys,
I recently got the urge to grab a simple kit and enjoy building from the git-go rather than fight the mental block of other projects much further along. The one I seized was Tamiya's old Su-85, early vintage and a lot of fun to whack together.
I was wondering about adding some quick superdetailing -- can anyone recommend a diagram or detail source for plumbing the external fuel drums of a T-34 type hull? I have not come across any projects on line as yet where this has been added, though research is continuing.
I was thinking about doing a winter scheme and have been researching the "hair spray method" and the new AK chipping fluids. I found a video tutorial on using them but the effect appearing in the video was one of blurring rather than chipping, as if paint had been smoothly abraided rather than struck and chipped. The effect I have associated with hairspray in the past is the one below, a pic I found many years ago and cannot remember where, though it was probably right here...
This is definitely not a softly blurred or rubbed-looking effect... Do any of the armour experts here recognise this technique? Is it hairspray? Can the AH Heavy Chipping Effects fluid produce this kind of sharp demarcation?
It's all experimental, of course, I'm just looking for pointers!
(The pic above, BTW, I have always felt represents one of the finest worn finishes I have ever seen on any armor kit! Kudos to the artist!)
Cheers, hoping for a signpost on this particular road,
Mike/TB379
http://worldinminiature.blogspot.com/
Posted by T26E4 on Wednesday, May 29, 2013 6:11 AM
www.primeportal.net/.../t-34.htm  Tons of T-34 walkarounds
Roy Chow
Join AMPS!
http://www.amps-armor.org
    November 2004
Posted by Bronto on Wednesday, May 29, 2013 6:30 AM
The rear tanks on the the T-34 series were not plumbed to the inside of the hull.  They were simply used for carrying extra fuel, then the fuel had to be manually transferred to the internal tanks to be used.
Posted by Tojo72 on Wednesday, May 29, 2013 6:36 AM
The AK Heavy chipping fluid can be used for achieving heavy wear as you describe,but experiment on something to achieve your desired effect
    April 2005
Posted by Thunderbolt379 on Wednesday, May 29, 2013 6:56 AM
Many thanks for your pointers, guys! Roy, I took a look at some of those walkarounds and thery are very useful indeed.
Bronto -- thanks for the info. No wonder I can't find any hint of tank plumbing in any of my photos, either the real thing or buildups. There is one pic of a buildup in which I thought something had been added, maybe it was just debris around the tanks that suggested piping to my eye.
Tojo72 -- I'll give it a whirl, then, and do a test piece on plastic sheet to get a feel for how it works.
Cheers, and thanks again,
Mike/TB379
