Rookie Painting Question . . .
    July 2013
Posted by bitbite on Sunday, July 7, 2013 8:47 PM
. . . so before I try my next armor model, let me make sure I've got the steps right.
1. Primer (I've never done this before, is it really necessary and if so, what color?)
2. Base color (and camouflage if necessary).
3. Future or other gloss coat (never done this either but from what I've read here, it's the thing to do).
4. Washes and decals.
5. Flat coat.
6. Weathering.
I've looked at a lot of other posts and this is what I've gathered from them.  I just want to make sure this is right before I get started.
Thanks.
"Resist the urge to greedily fondle the parts . . ." - Sheperd Paine "Modeling Tanks and Military Vehicles" Page 5
Posted by tigerman on Sunday, July 7, 2013 10:18 PM
I've never primed.
 Eric
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Sunday, July 7, 2013 10:54 PM
  Except for when I'm going to do some chipping, (using hairspray or salthttp://doberman-chat.com/community/styles/default/xenforo/smilies/scratchhead.gif..... maybe just some simple scratches) I don't undercoat either.
 https://i.imgur.com/LjRRaV1.png
    July 2013
Posted by bitbite on Monday, July 8, 2013 1:00 AM
Thank you both, and I'm glad to hear you don't prime because I never saw a reason for it either.  Your two posts confirmed my thoughts.  I never understood why.  But are the rest of my points correct?  I've never used Future before and don't want to screw up a $70 model experimenting with stuff I've never done before. Confused
Posted by Bish on Monday, July 8, 2013 2:21 AM
I never prime either and never had any problems.
As for future, it depends why you want to apply it. If its just to apply the decals to, armoured vehicles tend not to have as many markings as aircraft, you could just brush the future where you want the decals to go. If your using enamel paints and are doing an oil wash, then a couple of coats of future are a good idea. If your using acrylic paints then you can do the wash straight onto that.
Apply the decals before you do any washes or anything else, but apart from that, you have the right idea.
Posted by ajlafleche on Monday, July 8, 2013 8:53 AM
In your list, apply decals BEFORE you apply any weathering, including washes.
    July 2013
Posted by bitbite on Monday, July 8, 2013 9:15 AM
Roger that.  Just careless itemizing on my part.  Thanks.
    January 2007
Posted by the doog on Wednesday, July 10, 2013 9:12 AM
I would NOT recommend spraying Future all over your model, You;'ll get a big, shiny coat that then has to be toned down, necessitating another coat of flat. Just not worth it. Rather, if you're worried about decal silvering, dip your decal itself in Future after you remove it from the backing, It will settle right down on the model, nicely.
    July 2013
Posted by bitbite on Wednesday, July 10, 2013 1:00 PM
Awesome.  Thanks.
    April 2013
Posted by FlyItLikeYouStoleIt on Wednesday, July 10, 2013 1:59 PM
I myself am fond of priming. It not only eliminates any concerns that your paint may one day decide it's not happy on plastic anymore, it also gives you the option of using a sanding method to show surface details. I lay down a couple coats, usually one gray, one black. I am, however, the exception to the rules of most in here. It really is entirely up to you.
Bill.
On the bench:  Lindberg 1/32 scale 1934 Ford Coupe and a few rescue projects.
In queue:  Tamiya 1/35 Quad Tractor or a scratch build project.
    April 2013
Posted by FlyItLikeYouStoleIt on Wednesday, July 10, 2013 2:03 PM
Oh, and Future ..... I brush it on. It's fantastic at self-leavening. Also, you CAN use Future as a dull coat by adding a flat base such as Tamiya X-21 acrylic.
Bill.
