Sagging vinyl tank tracks
    December 2011
Posted by Chrisk-k on Sunday, July 21, 2013 2:48 PM
I'm building an old Tamiya T-34. It comes with vinyl tracks. Besides supergluing the tracks to the road wheels, are there other methods to make the tracks sag?
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    April 2013
Posted by FlyItLikeYouStoleIt on Sunday, July 21, 2013 3:24 PM
edited by author (what was I smoking?)
Bill.
On the bench:  Lindberg 1/32 scale 1934 Ford Coupe and a few rescue projects.
In queue:  Tamiya 1/35 Quad Tractor or a scratch build project.
Posted by Rob Gronovius on Sunday, July 21, 2013 4:53 PM
One method is to drill small holes in the hull sides and use pins inserted from the inside of the hull (clip them to the right length) in a few key spots to hold down the track. Super glue the heads of the pins inside the hull or use 5 minute epoxy to hold them in place.
Another method is to use a needle and thread to loop around a road wheel center and through the upper run of the track in a couple of spots. Tie off the thread and it will hold the track down too. Use black or that semi-clear brown hemline thread.
    December 2011
Posted by Chrisk-k on Sunday, July 21, 2013 5:08 PM
The clear coat method seems the easiest. Does a clear coat really make a vinyl track rigid?
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Sunday, July 21, 2013 5:37 PM
 http://forum.cabalonline.com/images/cabalsmilies/Aiwan/on_the_quiet2.gif  Cut some foam earplugs in half and wedge 'em between the sponsons and the track surface - one side at a time. Turn on a 1200 watt blow dryer 10 to 15 inches away from the track and watch VERY CLOSELY. When finished with that side put it in the freezer for a couple of hours to set them. When you want to take the earplugs out, just let them warm to room temperature before trying to remove them - and then do the other side.
 Been doing models a long, long time. Always works fine for me.
 Be sure to pay attention to any small delicate details so as not to inadvertently warp/distort them while watching the tracks.     http://forum.cabalonline.com/images/cabalsmilies/Aiwan/derisive.gif
 https://i.imgur.com/LjRRaV1.png
    July 2004
Posted by stikpusher on Sunday, July 21, 2013 5:38 PM
Not likely... those tracks will likely flake off paint before it gets rigid enough to stay in place
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    April 2013
Posted by FlyItLikeYouStoleIt on Sunday, July 21, 2013 5:59 PM
Clear coat method probably won't work on the REALLY rubbery vinyl stuff. Disastermaster's blow dryer / freezer method would work well with any of the rubbery tracks. Just be EXTREMELY mindful of the surrounding parts with that blow dryer!
Bill.
    December 2011
Posted by Chrisk-k on Sunday, July 21, 2013 8:07 PM
I won't blow my models with a hair dryer. So the thread method seems like the way to go.
Posted by Rob Gronovius on Sunday, July 21, 2013 10:01 PM
I may experiment with that technique on an old Tamiya SU-85. I'll just build up the lower hull and see what happens.
    April 2006
Posted by waynec on Sunday, July 21, 2013 10:09 PM
One method is to drill small holes in the hull sides and use pins inserted from the inside of the hull (clip them to the right length) in a few key spots to hold down the track. Super glue the heads of the pins inside the hull or use 5 minute epoxy to hold them in place. Another method is to use a needle and thread to loop around a road wheel center and through the upper run of the track in a couple of spots. Tie off the thread and it will hold the track down too. Use black or that semi-clear brown hemline thread.
i have used both and also one strand of speaker wire instead of thread. any track with holes near the center guides can use the thread method. for the pins i also superglue a plastic "platfrom" inside the hull so i can glue the pin to it
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    April 2004
Posted by Jon_a_its on Monday, July 22, 2013 3:16 AM
Surprised no-one has mentioned aftermarket plastic or Fruil metal tracks yet! Stick out tongue
Not my Idea, but this is as old as the hills:
Another option would be to assemble the wheels on the side, then trace the outline of said wheels & transfer this to eg, thin balsa wood.
Trace the intended curve of the track (front return roller to drive sprocket)
Cut one of: to sandwich the guide horns between & pin through the tracks to conform to the desired curve.
Heat gently, with hair dryer or near-boiling water until it conforms, then allow to cool.
This also works for Shermans, etc., cut one of: the thickness of the road wheels for those tracks with outside guide horns, but with a straight top-run as the Shermie has taut 'live' track.
I did this for the Italeri tracks on the Sherman & M32 as the track supplied in the box was too thick & springy, would bend the suspension like a banana, that only a ridiculous amount of weight would solve.
HobbyTrax produce aluminium track assembly guides .
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    September 2006
Posted by Blitzwing on Monday, July 22, 2013 3:54 AM
I've had a bit of luck with epoxy resin and then wedges to keep pressure on the top of the tracks. It takes a while to dry but pretty much sticks anything.
URL=http://picasion.com/]
Posted by Spamicus on Monday, July 22, 2013 7:33 AM
If I use the kit provided vinyl tracks I always use the thread if the vehicle has no support rollers and the pins if it does. I've found that some CA glues don't adhere well to the vinyl.
Steve
Posted by Gamera on Monday, July 22, 2013 8:17 AM
I've always used the pin method Rob describes before but the heat and cool method DM posted has piqued my curiosity. How long do you keep the hair dryer on the model and how do you know when you've heated it enough? Like some of the guys here I'm a little afraid I'd go overboard and melt the model.
    July 2003
Posted by disastermaster on Monday, July 22, 2013 4:40 PM
Gamera
     http://emoticoner.com/files/emoticons/smileys/woops-smiley.gif?1292867701 Is THIS too much science?
http://forum.cabalonline.com/images/cabalsmilies/Aiwan/boast.gifThis sounds a bit lengthy but it doesn't take as much time as wheeling out the sewing machine http://forum.cabalonline.com/images/cabalsmilies/Aiwan/sarcastic.gif
  Place the model on a flat surface. This method demands patience and attention.
 Be sure to especially watch the detailed areas of the tracks (if it gets too hot this and the thinnest areas will be the first area to deform) and all surrounding areas near the tracks.
 I only use flat tip tweezers like this for insertion (no preference for extraction).
http://www.tooltrolley.co.uk/images/CK/T2364.jpg
http://www.hearos.com/uploads/foam-ear-plugs.jpg No particular earplugs required.
1. Compress a earplug vertically.
2. Place it in the tweezers.
3. Insert in the appropriate area.
4. Hold plug in place and slide out the tweezers
5. Repeat for each sag.
6. After all are inserted, heat them up.
"How long do you keep the hair dryer on the model....."
http://forum.cabalonline.com/images/cabalsmilies/Aiwan/unsure.gif Brace your knees as they may tend to knock. Don't worry, it's not like you're setting fire to the house.
 You will know how long to heat 'em because you will be able to see the tracks begin to sag slightly since the sponge earplugs are constantly trying to expand to their original configuration.... just like they do in your ears. As the tracks warm up, the plugs are still expanding. Here's where you watch the track detail and the guide horns for distortion. When the tracks soften, they are conforming. That's the reason I use the earplugs - you won't get the same results or visual cue using anything else.
The most important thing you have to do is http://forum.cabalonline.com/images/cabalsmilies/Aiwan/pilot.gif pay attention (and heat them warm enough).
 Patience...... http://forum.cabalonline.com/images/cabalsmilies/Aiwan/to_clue.gif
     http://forum.cabalonline.com/images/cabalsmilies/Aiwan/mda.gif  less is more (you can always add more).
 So if the area between the sponson and the track is small, cut them down vertically leaving enough for them to expand back to. If the said area is larger use the full height.
 This even works with individual track links, just measure and add a extra link or two while assembling.
 Except for small details you won't melt the model if you constantly place your hand at the same distance (in front or beside the subject, not behind it) and use that to gauge your distance from it since that's the only way you can adjust the heat too.
 If done right (without any visible means of deprimere) people will ask,
                      "How'd 'ya do that?"http://forum.cabalonline.com/images/cabalsmilies/Aiwan/this.gif
......And then you tell them - and they just shake their head with a dazed look......  http://i587.photobucket.com/albums/ss319/wvvdiup1/Holiday%20Snoopy/shakinghead.gif
Hope this explains it better to you.
Gotta go, past time for the ......http://i11.photobucket.com/albums/a155/Yofclef/Smiley%20faces%201/bth_newsman.gif
    January 2007
Posted by the doog on Monday, July 22, 2013 5:33 PM
Chrisk-k
Uh, I"d be really reluctant to endorse that method. You'd have to load up that track pretty heavily to get that effect, and if you use a lacquer base, you're going to eat your track.
That heat-sagging method would also scare me unless you really practiced it and had a real "feel" for the kit's particulars regarding the tracks. Also, I'd wonder how much distortion in the tread you would get?
This kit's tracks are particularly springy and flake paint something fierce; I would recommend you go with the pins in he hull method, or better yet, go with an aftermarket indy link set. Don't waste your money on Friuls, you can get some plastic or resin links cheaper than that.
Posted by Rob Gronovius on Monday, July 22, 2013 5:48 PM
Jon_a_its
Fruils on a Tamiya T-34 would be akin to putting Dubs on a Yugo.
    July 2004
Posted by stikpusher on Monday, July 22, 2013 11:53 PM
Maquette used to market some indy link tracks for T-34s that are reasonably priced for the Tamiya kit. The AFV indy link tracks are about as high end as one should go for this kit.
       - Plankton
LSM
    July 2008
Posted by castelnuovo on Tuesday, July 23, 2013 1:36 AM
Rob Gronovius
Jon_a_its
Take it easy on Yugo Smile. I used to drive one....Whistling
Posted by Gamera on Tuesday, July 23, 2013 7:38 AM
Thanks DM!
Excellent explanation, things are a lot clearer now. I don't have anything on the bench with rubber band style tracks right now but I'll have to dig an old model out and try this when I do.
PS: Nope, you can never ever ever have TOO MUCH SCIENCE!!! Geeked
(well according to Dr. Paul Armstrong you can't!)
    November 2008
Posted by plasticjunkie on Tuesday, July 23, 2013 8:39 AM
The invisible vinyl thread (from Walmart, Hobby Lobby, any fabric shop, Target) looped over the track and tucked into the road wheels works every time. The other method would be to go with link track.
 GIFMaker.org_jy_Ayj_O
Posted by Rob Gronovius on Tuesday, July 23, 2013 9:46 AM
castelnuovo
Rob Gronovius
Jon_a_its
Even if the Yugo was brand new, would you have bothered to put wheels & rims worth more than the car itself on it?
Same difference; why spend $45-50 or more on Fruils for a 40 year old kit worth $10-15 when that same amount of money could buy the top of the line T-34 model with aluminum gun tube and photo etch that didn't need new tracks?
That's my point.
    March 2013
Posted by garzonh on Thursday, July 25, 2013 7:58 PM
WOW, how many methods.
In fact, Im also tryring to do the same on my JS-3. Using the tread "sewing" it to thr retun rollers, wouldn't that make the track to stay close to the rollers but go up in between spaces?
I will experiment with several approaches, will see.
    April 2004
Posted by Jon_a_its on Friday, July 26, 2013 6:54 AM
Ahem....  Link   & Oh dear... Surprise
Don't feed the CM!
    March 2013
Posted by garzonh on Friday, July 26, 2013 7:36 AM
Jon_a_its
It sends me to some Autotunning cars thread??? Tongue Tied
    November 2008
Posted by plasticjunkie on Friday, July 26, 2013 8:41 AM
garzonh
The thread method works well on tracks that rest on the road wheels such as the Panther, Tigers, T-34's etc. The JS 3's tracks will need "the pin the hull" method to provide the sag between the top rollers as in the Panzer III and IV family.
    May 2014
Posted by Steelclown on Thursday, May 1, 2014 6:17 PM
I am having the same problem with my SU-100 witch has the same tracks. I am planing on using some double faced tape to attach them to the wheels. The sagging wont be great but I can't resolve myself (or my wallet) to pay for aftermarket tracks on this kit. I guess I will also had a lot of mud or snow to hide the flaws of the sagging. The other methods seems kindda tedious for a noob like me.
    April 2006
Posted by waynec on Friday, May 2, 2014 8:25 AM
plasticjunkie
You can also take speaker wire apart and use the individual wire strands to tie down track.
