The two bumps are most likely supposed to be the hinges. I would remove the bumps first, then using a straight edge and score a line where the door seam is. Next, bend and break the plastic along your score line. Sand the newly seperated door/body pieces to get a sharp line. Then add the hinges back to either the door or the body piece.
To make the tarp look like fabric with damage, thin the underside with a rotary tool so it is thin enough to poke a sharp hobby knife through it. The knife will leave jagged edges like cut fabric. To paint the fabric, use a brush and do a couple different coats brushing in opposite directions. This will give it some fabric texture. Lastly, drybrush with a different color to give it some variation. Another option is to rebuild the whole tarp using tissue paper and thinned PVA glue (Elmer's school glue) to give it the texture and look you want.
Gino P. Quintiliani - Field Artillery - The KING of BATTLE!!!
