flying tank
    March 2014
flying tank
Posted by kpnuts on Tuesday, July 8, 2014 2:19 PM
In early 1942 the British were made aware (by the Master spy Leopold Tepper) that the Russians were developing a flying tank. The A-40 Krylya. This information was was passed on to the MOD who hastily commissioned the design our own flying tank.
It was decided this tank should be able to take off and land under its own power and not,as a glider towed by another plane, just increasing the target size and not as useful.
The top designer, a young handsome genius by the name of K.P. Nuts was called in to do the job, his first request was to find the lightest, strongest materials available, it was discovered the MOD owned a patent on a product called Carbon fiber, invented by W. Watt, L.N. Phillips and W. J. Johnson.
The Grant M3 was the tank chosen to be used on the project. The turret and mantle would be made of carbon fiber and the middle set of wheels would be removed and carbon fiber skids added to replace them, reducing the weight from 30 US short tons to 19 US short tons.
I realise I've been a bit inventive with history carbon fiber was not invented till 1963 (at least as we know it today, they did have it in 1939 but was not useable for this type of thing)
I will be building the tank as normal to start with, to get the experience with washes and stuff, my first attempt was not very good.
as you can see very crude and no washes, but I hope to improve.
    January 2007
Posted by the doog on Tuesday, July 8, 2014 7:18 PM
Ya know, it's not too bad, your paint colors just look a little oddly strong, but that might be the flash?
Some pointers to keep as guidelines. Don't paint metal parts in silvery metallic. Paint in a dark, almost blackish gray, and then gently drybrush with silver or gray metallic. LESS IS MORE.
Next, think carefully about why and where you would actually find chips. Again, here, smaller is better.
Tank interiors are generally all painted in off-white. Bare metal except for the actual breech parts are actually rather rare, as they would tend to corrode or rust.
Your model looks very shiny. Again, this could be the flash, but you should try to dull it a bit.
I would paint those cables a darker grey, flat, and then lightly drybrush them with a metallic silver-gray.
Take time to read through some of the posts with "weathering" in them in the search bar. You can learn a lot from the many talented people here.
