Tamiya Tiger 1
    March 2010
Tamiya Tiger 1
Posted by Bocks Suv on Sunday, October 26, 2014 10:56 AM
I'm an airplane guy but got a commission build for this 1/35 tank. He wants it finished in the lighter desert version so the details, shading weathering are important. Any tips on how to build so I'm not constantly retouching? Lots if fiddly parts on the exterior. The treads are vinyl and will need to be painted and sagged appropriately. Thanks.
Posted by Rob Gronovius on Sunday, October 26, 2014 11:06 AM
This is a good article on the Tamiya Tunisian Tiger:
hyperscale.com/.../tigerigc_1.htm
    July 2014
Posted by modelcrazy on Sunday, October 26, 2014 11:10 AM
Rob,
I have to say, Your a veritable wealth of armor information. Thank you for jumping in with you knowledge and help.
Steve
    January 2006
Posted by SprueOne on Sunday, October 26, 2014 11:23 AM
And for the vinyl tracks,
Painting:
wash them first in isopropyl or denatured alcohol and let them dry on some paper towels.
I primer/base coat mine with Rustoleum Flat Black enamel. Shake the can for at least 1 minute after hearing the ball inside start to rattle.
Then flow in pastel pigment / acrylic sloppy washes of red browns and then to dirt browns until the look is where I like it.
Lightly dry brush a gun metal color where the "steel" parts contact the wheels and the ground.
Use the technique described in the I-Sheets for connecting the ends. Probably the hot screw driver method.
Installation:
The drive sprockets and idler wheels shouldn't have been glued or installed onto the model yet.
Wrap the loop of track around the idler wheel and the drive sprocket in the approx. appropriate locations, then install onto the model.
The sag can be achieved by gluing to the tops of the road wheels and around parts of the drive sprockets after installed onto model. CA glue works for this.
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
