All WIP and finished pictures for this BLOG is here: https://imgur.com/a/T9zbg
I glued together the one piece road wheels / suspension part(s) with the outer and inner side parts. Then the fenders on top.
After the cement cured, I masked off the painted the base coat color on the under and back side of this sub-assembly. I did this because it would be difficult to get the paint there after complete assembly and I didn't want bare plastic spots to show.
M. Brindos, this is where I put the tracks on the wrong sides of the model. The tracks were attached to a central sprue section. This section of material had to be cut off of the LEFT side of one and the RIGHT side of the other.
The side that was cut off from every approx. 5th link or so now look ugly. I should have positioned these respective side to the inside and under and not seen ever again place. No, I glued them on so that this ugly side is on the outside to be seen by all who view this forever
A clear example of the clever design of this kit. All of the puttied and sanded spots will not show after final assembly so none of that work was needed anyway.
