Dragon 1/72 T34/76 Model 1941 Kit 7262
    December 2012
Posted by RX7850 on Thursday, March 26, 2015 12:29 PM
I figure it's time to show some of my build progress  instead of just commenting on the great builds that other members publish . Overall  It has been slower than I would like but the responsibilities that are inherent in one's life tend to prevail. I will try to keep the duration between updates to a minimum . For the record this is my first build in 18 yrs.  Hope you enjoy.
I prefer not to build OOB so when ever I can I try to make improvements ( which is the fun part). Using Prime Portal's T34/76 walk around I started with the turret. I felt the  casting seam on the front needed more  emphasis . On the left is the kit's , modified on the right.
Added missing welds around vision ports
Once assembled I continued with adding  weld beads were necessary . Also added the rough cast texture, shaved off the the molded on vision port protectors  and replaced them with new ones of thin aluminum sheet stock. The kit's PT-4-7 periscope is nothing more than a protrusion so I cut off where it's protective cover would be hinged so I could have it in the open position.The assembly seam in the front is sealed with super glue.
The kit's barrel didn't look accurate so I made a new one from K&S aluminum tubing. Not sure if it  can be seen but I added rough texture (left  from cutting torches and grinders ?)   to the outer edges of the mantlet and recuperator housing. The inside of the  periscope tower was also  recessed to accommodate the optics.
Here's how the turret currently looks with the PT-4-7 periscope done.
And a few other things
Replaced the kit's exhaust outlets with ones made from K&S aluminum tubing
Drilled out the the drive and idler wheels. Kits supplied on left,  drilled on the right.
I plan on replacing the kit's  front and rear fenders so far I have almost completed the front.
Shaved off the equipment tie downs and made new ones from very fine copper wire.
I also made the cooling intake louvers . They turned out on the large side so I might  change them
That it for now.Thanks for looking .
    January 2015
Posted by M. Brindos on Thursday, March 26, 2015 12:33 PM
Your work looks perfect so far. Nicely done! Keep it up. :)
- Mike Brindos "Lost Boy"
Posted by Bish on Thursday, March 26, 2015 12:44 PM
Some nice detailing there, I like the barrel.
    September 2006
Posted by RBaer on Thursday, March 26, 2015 1:28 PM
So if I did all that work in 1/72nd scale, I'd need an 18-year break too.......
My hat's off to ya!
Apprentice rivet counter.
    January 2015
Posted by M. Brindos on Saturday, March 28, 2015 10:27 PM
Oh wow. Its 1/72! Ha! I fell for the assumption its 1/35 lol. That's amazing for 1/72. Fantastic job thus far.  :D
Posted by Rob Gronovius on Saturday, March 28, 2015 10:52 PM
    January 2006
Posted by SprueOne on Sunday, March 29, 2015 12:31 PM
Awesome progress. Really getting down with the details.
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    December 2003
Posted by psstoff995 on Sunday, March 29, 2015 2:11 PM
Nice! Looking forward to more. I had to do a double take when I saw 1/72! Too cool
-Chris
US Army Infantryman
    May 2009
Posted by Pawel on Sunday, March 29, 2015 2:47 PM
Hello!
Very nice work in my favourite scale! Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
    January 2007
Posted by the doog on Sunday, March 29, 2015 8:34 PM
Wow, that's some genuinely impressive detailing! I can't wait to see that turret painted up--it looks so cool!
    December 2012
Posted by RX7850 on Monday, March 30, 2015 8:01 PM
Thanks guys for the gracious remarks,
Surprisingly  I made a little more progress.  Since I find the look intriguing  I decided to add some Ekranami ( additional welded armor ) to the front glacis plate.   I don't know if I took artistic license in the representation. I found some of the research confusing. It appears to have been in production for only several yrs. ,  41 to 42 possibly early 43? Modifications were done at the factories at Stalingrad and later when they were moved. I also read that Ekranami  was also a field modification.  Pictures that I viewed show various  plate thicknesses  and patterns .  The exception would be at the factories where there was some production standards depending on the factory.  If anyone can clarify this I would appreciate it.
Not sure I am content with the plate spacing around the drivers hatch,right is narrower than left. I am contemplating widening it. Added weld bead to the antenna mount, side glacis plate and around the hull mg. The hull mg weld came out on the thick side but since this is my first build in a while , I'm going to let it slide  Smile . The  hull mg. was also drilled out ( My eyes are still crossed  ) as well as the gunner's visual sight.  And finally some nice rough texture added to the mg. armored casting.
I tried to duplicate these . The mounts for the fender mounted tool storage.
Here it is .  Bent some thin metal and used  Grandt Line HO scale bolts.  Can you see them their reeeaal small.
That it for now .
Thanks
    May 2009
Posted by Pawel on Tuesday, March 31, 2015 1:47 AM
Hello!
One thing - the word is "Ekrany" - meaning "screens". "S ekranami" means "with screens" in Russian - that's where the confusion comes from. Getting a definite pattern on any piece of mass-produced Russian piece of equipment is hard - you had different factories, then came the field modifications. Then decades passed, museums were sometimes sloppy on the restorations.On top of that, add the Russian obsession with secrecy and lack of faith in written manuals (many of the soldiers couldn't read) - and that's what you're facing. But you're doing great, good luck with your build anyway - and have a nice day
Paweł
www.vietnam.net.pl
    December 2012
Posted by RX7850 on Tuesday, March 31, 2015 7:06 AM
Ah , that would explain a lot . Thanks
    January 2007
Posted by the doog on Tuesday, March 31, 2015 6:46 PM
That armor looks HEAVY! Hey, the cool thing about WWII is that there were so many experiments and one-offs that you can reasonably get away with a lot. I think it looks cool!
    December 2012
Posted by RX7850 on Friday, November 24, 2017 7:44 PM
So I am finally able to update this long dormant WIP with some progress. I'm nearing the finishline with regard to assembly of this enjoyable yet lengthy build and should  start painting soon. Recently I abandoned modifying the kit supplied  fender mounted tool box and built one in the open position out of brass, aluminum and copper stock. Still contemplating what to put in it as well. Here is the initial progress.
Tool box finished.
Added the various grab handles , fabricated a new headlight and added the mounting and wiring.
Added some more weld beads and rough texture where needed and then atention was given to the rear external fuel tanks. I added more weld beads, rear support strap mounts, support brackets, nut and bolt details etc.
Almost ready for paint... Thanks for looking..
Posted by Tojo72 on Friday, November 24, 2017 7:50 PM
Wow great detailing on such a small scale
    January 2015
Posted by M. Brindos on Sunday, November 26, 2017 12:18 AM
I did this next level of detailing on the Dragon Dieppe Churchill. Drilling out MG barrels in 1/72 is seriously nerve wracking lol.
All the extra attention to the weld beads and texture alone are going to make this thing pop, but you have gone all the way with the details!
I can't wait to see how you paint it up. :)
    December 2012
Posted by RX7850 on Sunday, November 26, 2017 5:53 PM
Tojo72 ,
Thank you.
M. Brindos,
Thanks. I remember following your build, it was very enjoyable.  The Churchill came out great as a result of your talented hands. I have some artist oils on order and hope to get started painting soon.
    May 2015
Posted by Griffin25 on Sunday, November 26, 2017 6:32 PM
Holy cow that is looking great. Incredible detail for 1/72nd scale. Serious skills man.
Griffin
    December 2012
Posted by RX7850 on Friday, December 1, 2017 2:03 PM
Thanks, much appreciated.
