1/35 Tamiya Jagdpanzer IV 70(L): spring 1945. Log complete
    February 2010
Posted by EBergerud on Tuesday, May 5, 2015 2:58 AM
Tamiya Jagdpanzer IV 70/Lang 1/35
Paints: AK modulations sets: Vallejo Model Air/Color
Weathering: Vallejo acrylic washes, Iwata Com-Art paints; AK enamel streaking grime
Base & Foliage: Scenic Express Super Trees (European equivalent “Sea Moss”), several colors and textures of flock from Noch, Woodland Scenic and Scenic Express
The Vehicle:
I'd like to give a brief biography of the vehicle I had in mind. The JagdPanzer IV was developed in reaction to the T-34 shock of 1941-42. It was the first tank destroyer designed from the ground up for the task – the much lighter Hetzer was started later but delivered a little sooner. Stugs, Marders etc, although often successful, were all hybrids and carried some ugly baggage. The JP was based on the PKIV chassis but given very strong sloped armor and after Normandy armed with the same gun carried by the Panther. A very successful design, although only 2,000 were built because the Germans did a poor job of getting a prototype out the door quickly especially with allied bombing gumming up the works. The big Panther gun made it front heavy (the vehicle was only about 25 tons) and its crewmen often called it “Guderian's Duck”. Badly named actually – Guderian saw the need for Stugs and Hetzers – but wanted heavier AFVs to have turrets. The German Army put great emphasis on counterattack and this was one role the JPIV was not good at – the gun's traverse was poor and in a “battle of encounter” (very frequent) it was at a serious disadvantage against any true tank. Any Soviet tank and 76mm Shermans could penetrate the JP side armor inside the 500 yards or so that these violent clashes often took place. In such battles you wanted a turret and Guderian kept the standard PZIV in production until the bitter end despite Hitler's orders to use all PZIV production for JPs.
Probably 2/3ds of the Jagdpanzers went East where counterattacks were increasingly rare and the need for a reliable vehicle with whopping big gun obvious. But early models JP served at Normandy (most carrying the standard PZIV 75mm). About a hundred of the up gunned “Lang” variants were at the Ardennes. Production continued and some went to Nordwind. After January 45 the Wehrmacht was ordered to make the allies bleed for every mile on the advance to the Rhine. Hence a good supply tank destroyers (which in allied terms was a tiny supply) was kept or sent West where they tried to reproduce the effective delay tactics employed employed between October and December 44. Ideally tank destroyers would work with VolkGrenadiers (the surprisingly effective sweeping of the manpower barrel managed by Himmler and Goebbels starting in September 44 allowing the raising for 40 divisions equivalent of units that varied greatly in quality) or the last gasp Volkstrum. So figure the great power of a rare state of the art AFV like a Panther or JP working in concert with a blizzard of erratic infantry armed superb small arms and mgs plus deadly PanzerFaust and PanzerSchrect. Manpower quality was down greatly, but if the situation was ugly and the officers were good, they could still inflict painful casualties on their enemies. (American casualties in each month of 1945 -including April- rivaled the worst of 44.) So I'm thinking of a Jagdpanzer in an ambush position sometime in early March on either side of the Rhine. There was little city fighting in the Western allies' attack on Germany, so most fighting was comprised of a large number of small ugly engagements. The terrain would have been wooded if not forest with soil still soft. Rather like the Ardennes after the thaw. Many hills, small villages, crossroads of minor roads. Last project I put a US M8 in the snow and mud of late January and the upcoming JS2 will get the heavy mud treatment too, so I wanted something different. Think of this tank as having arrived for the Ardennes and survived. In March 45 a vehicle like this would be waiting in ambush and its crew hoping for the best.
The Kit:
This kit is a new tool effort from Tamiya less than a year off the presses. It is a brilliant kit. The part count is about 250 but unlike DML efforts there are zero extras. Personally I find the detail perfectly adequate particularly knowing how badly I was going to mangle it. There are three sets of PE – Tamiya makes a new gun with metal barrel if you want a gun that moves like the real one: plastic barrel was one piece and because there really is no place to see an interior I saw no reason to create one. There are side skirts available, but that would have hid the elaborate lower hull and from the pics I could track down full schurzen were rarely used – it also made the beast look very clumsy. The third was largely detail stuff for tools etc – stuff that bores me to tears and would also be invisible. Instead I installed a lot of stowage and a lot of foliage. Like 8th grade art class – great fun really.
The engineering was nearly faultless. Pieces are in perfect numerical order on the sprues. The plastic is of perfect consistency – not too brittle or too soft. The small parts were always placed on the sprues to make them easy to remove with little danger to the part or residue. The instructions always showed, usually on the next step, how the parts were to look when installed. (Listening DML? I've never made one without installing a part incorrectly simply because it was never shown clearly how it was to lay.) All of the major parts fit so well that filler was left on the shelf. A full interior would have been nice but the way the JPIV was designed there was no way to show it off, so I buttoned up the buggy. The very well detailed plastic tracks were so precise that I glued them before assembly and the brass pieces gave, if anything, too much sag. Because of the vehicles design there were buckets of road wheels. I like them a lot. Road wheels are Zen modeling: you can go through the pleasingly repetitive task and listen to Bach at the same time. Below is the assembly up to prime:
Here it is with black/gray Vallejo primer on it - I always apply this in a fine coat. There will be a lot more coming.
Painting:
The Tamiya instructions and many of the pics of the new kit appearing made by good modelers (very small number of original wartime photos for some reason) showed a classic three color 1944 scheme. Might have been right for the Normandy or the Bulge, but there was no one recipe. As always I've burned a lot of time looking at photos to prove what I already knew: the German "three color" camo scheme appeared in a few thousand variations.
This might be almost literally true. According to Terence Wise in the classic Squadron book "D-Day to Berlin" German tank crews were given pots of olive green and red brown paste to dilute as they saw please-with petrol or water and apply to the Dunkelgelb factory applied base. Apparently some German AFVS were given factory applied the "ambush scheme" for a few months in 44. AFVs used to delay the allied avalanche toward the Rhine were certainly given them: Hetzers and Jagdpanzers were often decked that way. But not for long in the case of JP. Orderly production was breaking down. In addition, the paint job was essentially a field modification made by the crew, I'd guess that if a vehicle stayed in action for any amount of time it may have worn several different schemes. The kind of classic three color scheme with large green and brown hard edged (sort of hard - if you look close you can see a little fuzz on almost every one of them - about what you'd expect from hand painted or hand airbrushed vehicle.) More likely you'd see Dunkelgelb dominant with large blotches of green and smaller bits of brown. (Depending upon dilution - Olive green can range from a very dark color to a very light pea green: the brown from dark to almost a rust-like very light tone.) The various combinations defied generalization near the end of the war.
I chose a Dunkelgelb with a good dose of dark olive green and only light blotches of brown-red. I had AK “modulation sets”for both DG and the Olive/Brauns. Perhaps I had bad luck but I was very disappointed with both. Two bottles were spoiled before opening. The paint was unusually coarse – making for some clogged tips – and some of the browns & greens looked off to me. I used Vallejo Model Color for the green and Model Air for the Rotbraun – much better. (All hand work in DG was from Model Color “Middlestone” - a perfect match.)
Next I used a technique to show wear that I got from Mike Rinaldi the wonderful modeler and author of the “Tank Art” series that he calls “reverse dry brushing.” The idea is to have a dark color (I used lacquer protected Vallejo black/gray primer) with a lighter color on top (I'm aware that German armor used a rusty red primer - but I'm not trying to emulate a stain that went to the primer or steel). When dry, dampen a stiff brush with something like Vallejo airbrush cleaner, ISP or Tamiya lacquer thinner. The less time it takes to dry, the faster and easier a bit will come off. What is left are areas that are more like a surface marred by boots and grime ground in on or around areas where the crew would be very active.
After this came three filter Com.Art and undiluted an Vallejo acrylic sepia pin wash. (Because both products are quite forgiving I dickered with both several times – I did keep the kit gloss for filters and matte for pin washes – Vallejo has fine mediums for both. I was thinking of a tank that had survived the Ardennes and the intense fighting west of the Rhine, so I gave it more chipping than normal. I do like the AK streaking grime and I applied some.
Stowage and Foliage:
There isn't a lot visual interest in the JPIV – it's got a face only a mother could love and a lot of simple surfaces. The rear however has lots of tools. I though I did them up right and wanted to leave them on. Unfortunately, almost every film and a lot pics of JPs showed a vehicle with a lot of stowage. History won and I put on some equipment from Academy and big piece of netting from my shash. So here's what it looked like weighted down:
I spent a lot of times with pigments. I use artist pigments from Sennelier and the fine US brand Gamblin. They're better than anything on the market (the differences are not great) and are much cheaper for ounce. I put on several colors of dry mud under the hull and a couple of layers of heavier soft dirt or dry mud. I used some Pledge to moisten some areas and added a good dose of graphite on the front and sides. After a little dickering that was pretty much that. Here are a few pics before we the base and foliage were applied.
A fair build in my standards but I couldn't leave well enough alone. But the most cursory look of German AFVs in late war show them covered with foliage. (Allied vehicles were similar.) So that meant making some foliage for the JP and, just to make life complicated I made a base.
The stuff I used for the foliage and base was a combination of materials obtained from a Model Railroad's company “Scenic Express.” The major product is what SE calls “Super Trees.” This item is made up of dried Norwegian arctic shrubbery. It's not cheap ($35 for a basic package) but includes enough of the stuff to keep a couple generations of tank modelers happy. It's well packaged because if the stuff gets wet, a mold can form and ruin the lot. I've only begun to explore Railroaders techniques and think they offer much. Super Trees, for instance, have a look that makes plastic or wire armatures toy-like. Most of the stuff is aimed at large dios for railroads and most of the clumps are designed to be turned directly into trees with artificial “flock” (very small bits of plastic that could stand in for grass or leaves depending on the scale.) The flock is an art into itself and I've only got four colors and need at least five more. However for a project in 1/35 scale standard Super Trees make terrific shrubs, bushes and camo foliage. However if I simply used a tree shaped piece it would look like a 12' high tree with a trunk as thick as my wrist. Fortunately they include a bag of the plant's major branches and when dried they are much larger. They're utterly bare so to build a big tree like I did (could only eyeball – the JP was 6' high – I'd guess the tree at 18'. What you have to do is employ large numbers of the smaller branch, glue them to the big branches and then apply the flock. All branches on the tree were painted gray with some black flecks. (As one of the RR gurus on YouTube put it, “trees are not brown.” I've looked at a lot of trees in the last couple of weeks and he's right there.) You attach the flock with a brushed or sprayed on “Matte Medium” which is sold cheap by SE. A blast of hairspray will lock the flock on nicely. Here's the junk below: the spindly stuff is the bulk of the Super Tree collection – there is one of the thick branches there, a pack of very good flock from a German company Noch, and a few regular super trees treated by yours truly with flock.
Here are a couple of pics showing the JP with it's own foliage. German AFVs did have tank netting but most crews found it miserable to use and thus welded a few loops onto the hull to help anchor some some proper camo if they were setting up a defensive position. The camo itself was often replaced daily and tidied up if it looked like the Earp Brothers were coming.
In for a penny, in for a pound. I think it accurate that if possible a Jagdpanzer in harm's way would have been in a camouflaged position. Here's the base I made for it. It's possible to see the darker curved strips made by the tracks moved into position.
There should have been infantry near so I put in some sand bags could have been quickly manned if the JP had to withdraw. Here is finis:
I kind of like this one:
Interested in any comments. I have not mastered armor so every time out I trying something new or extra – almost guarantees some failures. Anyway, interested in what wiser heads think.
Eric
A model boat is much cheaper than a real one and won't sink with you in it.
    January 2007
Posted by the doog on Tuesday, May 5, 2015 7:02 AM
Eric,
A nice model, and a commendable effort in making a nice scene with a lot of planning and effort to make it complete.
I would suggest a figure or two to give the scene "human interest". That always adds a lot to a scene.
One thing that I noticed is, in the photo taken from the front, here is a noticeable gap between the upper and lower hull. This should not be there, obviously. I should have been glued and then sanded smooth. This is a part of the basics of modeling that must be mastered first. Make sure that you have all the basic elements of construction, neat gluing, sanding, etc, mastered first before you start painting and weathering. :)
    January 2013
Posted by jibber on Tuesday, May 5, 2015 8:34 AM
Eric nice detail on that Jag, a figure on or around it would really bring the scene to life. Other than what Karl stated, I noticed that the outer skin is a little "shiny". Maybe just the lighting reflecting off an angled surface, but if it is there are many ways to dull it down. For example, a light spray of Dullcote, some pigments, a light mist of a thinned earth color and many more. The last thing an AFV needs is a reflective surface in the field.
I think you've done a really nice job on your Jag, well done Eric.
Terry
    February 2010
Posted by EBergerud on Tuesday, May 5, 2015 3:20 PM
Now that you mention it I should have run a mini streak of molding paste along the front - the basic fit is quite sound. Attention to detail is not my great strength. Live and learn.
The camera work was a little erratic. I think if you look at all the photos you'll see several where the shine is not evident. Might add that the model had a gloss coating in some of the build photos that I apply before filters (flat for washes and back to satin at the end.) Former German armor top gun Tony Greenland pushed strongly for a satin hull above the fenders and dead flat underneath. I think what he wanted to emphasize was the flat, grainy pigments below. The very last thing I do on a model tank is to spray the whole thing with pigments mixed in ISP - perhaps this one could have used another coating of the brew. Too much and you can dull down the tank completely. I don't know about others but I find a certain tension between attempts at extreme realism clash with making a model that will show the detail and paint job - and even the weathering. I'd guess that if you would examined WWII vehicles at the front you would have found covered with dings, mg/mortar damage, broken fenders and above all a bucket of mud, dirt and grime. I think you could argue that fidelity to the real world might make for less interesting models. (I just read von Luck's memoirs and he said that when crewing an AFV the dust was so ever-present it was like chewing chalk: and that's just the stuff in the air.) Arguably if a genuine vehicle looked they way I think they would have, many weathering techniques like modulation and even wear/chipping might not be necessary because the vehicle would have had a cake of dirt, dust and or mud rendering detail, especially at 1/35 scale almost invisible.  Mig Jimenez once wrote that it's impossible to make a small plastic object really reproduce a large metal one - and he was talking about his own work. I think he's right, although the best modellers out there can come pretty close, but I'll never be in that league.
I don't do figures. I consider them almost a separate genre of modelling. If I was even going to think of it, I'd put hours into practice first. Maybe I have bad eyes but I think unless figures are done by someone who really knows his stuff, they detract - sometimes badly - from the kit. And if you put a group of figures in, they will draw the eye away from the kit itself for better or worse. I'd like to think of ways to suggest their presence. (They certainly would have present if trying to spring an ambush or hold a position. JPs were never supposed to travel alone.)  In this humble piece I would have liked to stick in a MG42 somewhere - but I didn't have one.
Thanks much for the comments. Always a help.
Eric
    January 2015
Posted by M. Brindos on Friday, May 8, 2015 10:32 AM
I am most impressed by the amount of careful thought that went into this build. I came across a lot of the same information when I was building my Panther.
I think you've done this model justice. So you missed a few things, it happens. My Panther has taken me years and a few repaints to get to where it is now and I'm still not 100% okay with it.
With this amount of dedication to your subject I would suggest practicing some figure painting. The same techniques apply to them just as they do to armor. Its all about how you think about it. Practice, even if they don't make it into a build, is still forward progress to your ultimate vision.
I say well done, and I'd really like to see more of your work in the future.
- Mike Brindos "Lost Boy"
Posted by Gamera on Friday, May 8, 2015 11:26 AM
Eric: She looks pretty good to me. I built an ancient Dragon kit of this vehicle and it seems this new Tamiya kit was waaaaaaaaaaayyyyyyyyyy better!
I didn't even notice the seam on the front hull until Karl pointed it out. Is it possible to smear a little 'mud' pigment over the gap to hide it?
I love the foliage and groundwork, thanks I've picked up a lot of useful information from your run-though here!
    February 2010
Posted by EBergerud on Friday, May 8, 2015 1:33 PM
Thanks for the kind words. When one of my kits is done, it's done. Another reason why I'll never be a top notch modeler. When my next kit is finished (a Cyber Hobby IS2) the JP will be moved and almost certainly without its base. Now if I had a midwest basement I'd have a proper case - but my kits are scattered around on bookshelves with few exceptions. Even when you can see them, nobody, myself included, gets much closer than six feet - that distance hides a lot of errors. But when I start a new project my concentration is on it - everything else is old news. Maybe I can't multi-task. (Although you are right that it would only take five minutes to raise the mud line on the front. Pigments hide errors too.)
I might rethink figures when I start to get the base-making under control. That's actually fun - like 8th grade art class. For the Stalin I'm thinking of some village in Pomerania around February 45. Snow, mud, rubble - maybe some water effects. The best dios that I've seen with figures have been very complex and the figures really become the focus of the project. (I remember one in Finescale that showed a US bulldozer covering wrecked German vehicles and other remnants of the countryside at Falaise - that was terrific but I couldn't do anything like that as of now. It's a deep hobby - always something new to master.
Eric
    January 2015
Posted by M. Brindos on Friday, May 8, 2015 2:07 PM
Like I said, I'm just impressed by the research and dedication.
Figures can get addictive once you get into them. Just like your next armor build, you get into a figure and that turned out pretty good, but next time I want to try a little more of this, and so on, and so on.
They really are just like any other model. I've found that most of the guys who think they are too hard have only to change how they look at figures. lol
I've seen more than a few dios where the figures are the topic and the armor was only there as a background prop. There's nothing wrong with that. But figures always lend a sense of scale to things because we can relate ourselves to the subject.
anyways, yeah. You could totally hide that minor seam with pigments. That would be easy.
    March 2013
Posted by garzonh on Friday, May 8, 2015 8:36 PM
Hi
Im trying to catch back into the forum, work has been crazy. We are implementing SAP.
Anyway...
I like your Jagd...specially that loooong dio, curiously I´m also starting the same tank, and also will do a dio. I like your cammo and the tools you put on the back specially the netting.
The weathering is done lightly which adheres to the environment which looks as there not mud or dirt. Looks like a nices spring day.
If I may suggest, a couple of figures would be nice...but..I know, figure painting is a nightmare.
Thanks for sharing your work.
    August 2014
Posted by aWintersTale on Sunday, May 10, 2015 12:45 AM
The time spent on research and execution for this model would make my models and modeling effort look like the Snap Tite variety. (Nothing, however, against Snap Tites). After viewing this model, I'm thinking maybe I should specialize in something simple, like the development of the stick grenade, and the dynamics  of throwing one.
    January 2013
Posted by jibber on Sunday, May 10, 2015 7:02 AM
Eric really nice job, and a great theme. It takes a lot to add figures to a base with foliage and one of the best trees I've ever seen on a Diorama. Thats going to look nice on the shelf.
Terry
