Weathering modern armor tracks
    June 2013
Posted by Reaper420 on Friday, July 31, 2015 3:28 AM
So I recently dived off into a few modern armor kits, M1a1, m1a2, challenger I mk3 and a leopard 1 a5. My question is what techniques do you guys do to weather the tracks. I know that the techniques used for WWII armor don't apply as much as modern tracks have a good deal of rubber, almost more than metal. So what do you guys suggest?
Kick the tires and light the fires!
    January 2007
Posted by the doog on Friday, July 31, 2015 6:53 AM
I would go with a dark gray finish, a wash of dark brown, drybrush with steel and then a dusting of "dirt" style pigments, Really no rust on new tracks unless the vehicle has been sitting a while, then only fresh bright orange rust.
    September 2012
Posted by GMorrison on Friday, July 31, 2015 11:39 AM
And try to play down the differentiation of color between elements, like the tires vs. the tracks. Pigments are great for that. After all, they've been side by side in the same environment. If you imagine a truck that's just been offroading, or Karl on his bike, it/ he is pretty evenly coated, but not covered, in road dust.
Posted by Bish on Friday, July 31, 2015 11:53 AM
I use exactly the same approach as I do for WW2 tracks. Some of those do have rubber pads, I just avoid getting any of the steel dry brush on the pads.
    June 2013
Posted by Reaper420 on Friday, July 31, 2015 12:24 PM
Thanks guys appreciate the tips.
    July 2004
Posted by stikpusher on Friday, July 31, 2015 12:57 PM
Yup. In truth there is not much difference material wise between WWII era Sherman tracks (the rubber types) and modern era tracks used on an Abrams. Your weathering should reflect the environment that you are representing. Mud & dirt for Europe, sand & dust for the desert. The longer any AFV is out in the field, the more it becomes covered in that field. Any rust formed on the bare steel areas is worn off as soon as the AFV is on the move again. But, one small detail missed is that rubber track pads and road wheel rims will get pitted and gouged in service. Particularly over rocky terrain.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
