Thanks for posting Grant. May I make a few suggestions? These are definitely on the nit-picky side so feel free to ignore them !
1) The conical antenna mount is a DML mistake -- that's a British item -- you want the US antenna (contact me offsite -- I have plenty to spare and can send you one).
2) That bolt strip on the glacis -- if you can still manage it, fill in the seam between it and the transmission housing. The bolt strip was part of the transmission housing and not the glacis.
3) your coax .30cal MG is proturding too far. In 1/35, it should be about 3-4 mm maximum.
4) the pry bar on the right side hull -- those two square ends are supposed to be the hull-mounted brackets and should be painted olive drab too.
5)perhaps not use the flag? It looks toylike in this scale.
6) the tow cable was attached to a bracket on the transmission housing on the left lower side. Yours would trap the driver and stop him from opening his hatch -- very dangerous!
Hope these help. Keep up the good work!
