E-50 ausf B
    May 2012
E-50 ausf B
Posted by Ninja-Viking on Monday, April 11, 2016 10:34 PM
E-50 ausf B
I am taking a short break on the E-79 to avoid "burn out".
So in the meantime I am working on my E-50 ausf B.
I needed a Upper Hull to start with.....
So Molded an Upper hull from MC and when I had a cast of that ,
I detailed it out by hanging the engine deck for mine,
removing the fenders, and opening the hatches.
I then wanted to replicate this engine deck
so I started by cutting out the engine deck, then the roof where the turret ring is.
I moved the turret ring forward, and started modifying the engine deck.
I made the cuts to the front vents, added strip styrene, and added sheet styrene to the back.
once this was all detailed, I glued it all together.
I then turned my attention to making the turret
I took a cast of my Teufels Amboss turret sand away the details and the sides to get the general shape.
Once this started to take shape I laid it on the upper hull to see how it looked.
I then began adding the details
I then turned my attention to the choice of guns for it
after this I decided to give the turret a coat of primer to bring out any flaws before molding.
I decided that if I keep handling the "master part" of the turret, as I worked on the rest of the tank......
the chances grew each day that I could screw it up.
So I molded and cast the turret, this will stand up to the constant handling better than the master would.
now... the upper hull is also quite a fragile thing as well.....
so I decided to mate it up to a lower hull and make it solid.
first I built a box around the spot where the Driver and Radio Operator  go,
then I plated over the turret ring.
glued in the rear plate, and glued them all together.
once that dried I cut a hole in the bottom and poured in resin.
This makes the whole thing "solid" and it can then stand up to the constant handling.
now the rear end needed some details
as well as the front
with this all done, I started on the tracks
I am still working out many of the finer details
but here is where I am for now.
    January 2006
Posted by Wirraway on Tuesday, April 12, 2016 1:12 AM
Great skills on display here.  Is this a "paper panzer" that didnt make it to production ?
"Growing old is inevitable; growing up is optional"
" A hobby should pass the time - not fill it"  -Norman Bates
GIF animations generator gifup.com
    May 2012
Posted by Ninja-Viking on Tuesday, April 12, 2016 1:39 AM
Wirraway
thanks for the compliment.....
as "Paper Panzers" go.......
your question gets two answers.
No. 1
Yes the E-50 is a "Paper Panzer"
No. 2
This version is strictly a "Made Up" version by WoT,
Posted by tigerman on Tuesday, April 12, 2016 1:46 AM
Enjoying your work so far. Those are both cool looking tanks, real or not.
 Eric
    May 2012
Posted by Ninja-Viking on Tuesday, April 12, 2016 2:21 AM
tigerman
Many Thanks
Glad you like them :)
    January 2007
Posted by the doog on Tuesday, April 12, 2016 8:32 AM
This is some very cool work. It's going to be a nice little unique gem in your display case.
"Panzer Front" on the PSII is the greatest game EVER. I wasted months of my life just lost in the battlefields, blowing up whatever I could, staking enemy tanks, waiting for literally 20-30 minutes behind something for them to come into range. I honestly felt like a real tanker. :)
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Tuesday, April 12, 2016 8:16 PM
Dang, this is really some nice stuff...................https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcS1geFjfNcsNZe_mNmlQBIICa7v9os7h8P5K8P0dxXI1KKLBTAaFmnAtQ
 https://i.imgur.com/LjRRaV1.png
    May 2012
Posted by Ninja-Viking on Thursday, April 14, 2016 7:48 AM
DELETE
    May 2012
Posted by Ninja-Viking on Thursday, April 14, 2016 7:51 AM
disastermaster
Glad you like it :)
    May 2012
Posted by Ninja-Viking on Thursday, April 14, 2016 7:54 AM
the doog
I am glad you like it,
Although....
I "think" that you "think" you're commenting about my E-79?
Posted by Gamera on Thursday, April 14, 2016 8:02 AM
Wow, that's a heck of a job kit-bashing. I can't seem to finish a straight from the box build and you're doing stuff like this...
    May 2012
Posted by Ninja-Viking on Sunday, April 17, 2016 9:29 AM
Gamera
Kit bashing, and then making casts to work from :)
    January 2007
Posted by the doog on Saturday, April 23, 2016 9:45 PM
Awesome work. The wheels seem to have come together quite nicely, even as "broken" pieces. It looks great to me!
SOrry, I may have indeed got the model you're doing here with the E79 from Panzer Front. Sorry about that. :)
    May 2012
Posted by Ninja-Viking on Tuesday, April 26, 2016 5:31 AM
the doog
Not a problem :)
This one is "winding down" almost finished.
    May 2012
Posted by Ninja-Viking on Thursday, April 28, 2016 9:26 PM
OK....this is "finally" done...
it is currently in the Paint Booth
Once the painting is done I will post the finished model
Boy this took a while :)
    May 2012
Posted by Ninja-Viking on Friday, April 29, 2016 7:04 AM
Posted by Gamera on Monday, May 2, 2016 12:04 PM
Oh wow, now that's cool looking! Thanks for sharing with us. Yes
    May 2012
Posted by Ninja-Viking on Wednesday, May 4, 2016 8:09 PM
Gamera
My idea behind the paint scheme is that from a distance.....
you might (mistakenly) think it is a Burned out tank,
then once you're in range....."Wham"!!!
Posted by Gamera on Thursday, May 5, 2016 7:45 AM
I like that, pretty cool idea. Idea
