Need some weathering/highlighting tips
    February 2015
Posted by acctingman on Friday, May 6, 2016 1:07 PM
Hello all
So, I just started my first build, ever. A 1/72 Revel T-34/85. I struggled with the tracks. They look terrible, but this is a learning process.
Painted the kit by hand and while I'm happy with how it turned out (for being my first kit) the tracks presented a lot of issues for me. Besides them coming out fugly, I had a hard time deciding how to paint them and highlight them.
I'd post a picture, but honestly, I'm embarassed at how it looks Embarrassed
Any tips or advice on how to approach tracks on kits of this size? Mine look.....horrible!
I know I'm not only limited with lack of experience, but also with tools....I don't have all the paints, pigments, washes, etc...that I'll need as I go along.
 I tried to upload a picture but it didn't show up. I'll add one in a bit so I can get some better input.
Thank you
    February 2015
Posted by acctingman on Friday, May 6, 2016 3:31 PM
    May 2009
Posted by Pawel on Friday, May 6, 2016 4:02 PM
Hello!
Don't despair, I've seen worse tracks here :D
The big question is: what do you expect from the tracks and from your model in general?
I'd suggest working on the assembly some more next time, so that the tracks go tighter around the drive and idler (rear an front) wheels. Sometimes, in order to do that you have to do some filing, add or remove a link from the tracks, add or remove some "slack".
As for the painting, you've got a good base, now you might add some shiny spots where the steel of the tracks wears off constantly in contact with the ground. Same for the steel wheels. The rubber bandages/tires of the wheels where necessary should be dark gray if the tank runs on paved roads, or dust colour if it runs on dirt. You might also contemplate light rust colour if the tank is a wreck. Shiny highlights are best added by dry-brushing. A wash of dark colour or dirt colour could also be a good idea - you can make it yourself by thinning your paints a lot - so no special materials are really necessary.
One more thing - look at as many photos of the real thing as possible - people often neglect this important step.
I hope it helps - good luck with your projects and have a nice day
Paweł
www.vietnam.net.pl
