Tamiya 35227 initial tigertiger
    July 2016
Posted by Tanker45 on Monday, September 19, 2016 12:38 PM
Hello,
Is tamiya kit 35227 initial tiger a decent one?  Most reviews I've come across are decent, but figured I'd ask here Smile
Thanks,
Matt
    April 2006
Posted by jgeratic on Monday, September 19, 2016 1:06 PM
It depends on what decent means to you.  Being Tamiya, it will be an enjoyable kit to build, shouldn't be any problems.  It is a dated kit, the original tooling is from 1969, while this particular boxing had some new parts added (1998).
Read here and decide if the inaccuracies are not a dealer breaker, or if you want to incorporate some or all them into the build:
http://tiger1.info/models/products-page/TAM35227
regards,
Jack
    July 2016
Posted by Tanker45 on Monday, September 19, 2016 1:17 PM
Thanks Jack!  I'm doing some research between tamiya and the dragon 6608.
Thanks,
Matt
    April 2005
Posted by JohanT on Monday, September 19, 2016 4:34 PM
Hi Matt,
As Jack allredy suggested, define decent ;)
The Tamiya Kit is a nice build, goes together well.
But decent in terms of accuracy - it is not.
Been offline for a while and am not up to speed with the most recent releases but for accuracy I would go for the Dragon # 6600 for the Initial.
If what you are looking for is the T1 mid I suggest Dragon #6700.
Go to http://tiger1.info , David Byrden's fact-collection is a must if you are looking for accuracy and very helfull!
Best Regards
Johan
    July 2016
Posted by Tanker45 on Monday, September 19, 2016 4:55 PM
I'm looking for accuracy so I'm leaning towards either the dragon 6600 or 6608. Thank you for the links I will check them out.
Matt
    April 2005
Posted by JohanT on Monday, September 19, 2016 5:17 PM
You need to decide what you want to build sine the vehcles are actually very different.
6600 and 6608 are both excellent kits;
Best Regards
Johan
    July 2016
Posted by Tanker45 on Monday, September 19, 2016 6:13 PM
I'll do some more research and decide.  Both kits should work with Friulmodel Alt-116, as I have a box of those.  Those are the mirrored tracks for the initial version.  I currently have Dragon's 6820 Tunisia Early Tiger 1, so I'll probably try the 6600.
Matt
    April 2006
Posted by jgeratic on Monday, September 19, 2016 10:30 PM
About the mirrored tracks, from what I've read only the first 20 production Tigers had these.  This style was abandoned because it was too much trouble to carry two types of spare tracks on the vehicles.
Beginning late August 1942, chassis numbers 250011 thru 250020 were indeed delivered to the 501st earmarked for Tunisia.  Question is, did these ten Tigers retain these original tracks, or swap them out before shipping to Africa in November.
regards,
Jack
    August 2005
Posted by Phil_H on Tuesday, September 20, 2016 12:52 AM
jgeratic
This kit bears little resemblance to the old '60's kit - the breakdown is completely different. It's based on the 90's new tool kits.
    April 2006
Posted by jgeratic on Tuesday, September 20, 2016 1:33 AM
Hi Phil, thank you for pointing this out.  My mistake was based on the chart associated with 35227 over at Scalemates, and none of the lineage indicated new tool.
regards,
Jack
    January 2008
Posted by Byrden on Tuesday, September 20, 2016 2:53 AM
Mirrored tracks never appeared in Africa.
David
    April 2006
Posted by jgeratic on Tuesday, September 20, 2016 4:33 PM
Byrden
David
David, right on que - thanks for that.
regards,
Jack
    July 2016
Posted by Tanker45 on Tuesday, September 20, 2016 6:23 PM
Thank you for all the help!  I got the mirrored friul tracks from a friend getting out of the armor building and would like to use those. Dragon's 6600 kit seems to be right as it gives the option to use mirrored tracks.  I'm still researching which version to make as the kit has three options.
-Matt
    January 2008
Posted by Byrden on Wednesday, September 21, 2016 3:02 AM
The kit's instructions are pretty clear about that.
David
    July 2016
Posted by Tanker45 on Wednesday, September 21, 2016 7:02 AM
Great!  Thank you everyone, I look forward to this build!
