DAK RAL 8000 confusion
    September 2016
Posted by ManCityFan on Friday, February 3, 2017 12:45 PM
Hi all,
I am posting this in armor instead of the paint section since I think armor builders will have encountered this at some point.  I am going to be builing a DAK Panzer II, and did a forum and internet search for the "correct" color.  I see that some DAK armor was sent to Africa in dark gray, and given camo with anything that could be found, then a standard RAL 8000 was used, and finally a standard RAL 8020, although the RAL 8000 was used until they ran out, so this is the most likely color used on the tank I am modelling.  I plan on this tank having decals for the 15th or 21st Panzer Division.
In looking up RAL 8000, I see the name listed as either Grunbraun or Gelbbraun, and seems to run from what looks like staight Tamiya Dark Yellow (Grunbraun) to chocolate brown (Gelbbraun) as seen in AMMO's take on the color.  I know that panzer colors are a major point of contention for modeller's, and getting the "right" color is very difficult, especially taking weathering into account.  In this case, the more research I do, the more I get a headache.  When looking at what other modeller's have done to get a "gut feeling" of the color, I tend to see a much more yellow color, closer to "standard" Dungelgelb with other colors mixed in, or a color closer to a Tamiya Desert Yellow.
Sorry to be so long winded, and I hope not to start a contentious post.  I try to do research before asking a question, but even with research, I am feeling befuddled.  So I am looking for suggestions on what color (or color combination) I would be safe using as a base coat before weathering.
Thanks for any help offered,
Dwayne
Dwayne or Dman or just D.  All comments are welcome on my builds.
    March 2007
Posted by armornut on Friday, February 3, 2017 1:16 PM
Dunkelgelb= dark yellow,  grunbraun= green brown, gelbbraun is probably not chocolate brown. Not sure of the german word for chocolate but I'm almost sure it isn't gelb. As for DAK, While I have not researched much on the two divisions your discussing, vehicles that initially went to Africa were panzer grau, dunkel grun( dark green), it wasn't until late 42 early 43 that vehicles appeared or were painted dark yellow. Hope someone else will weigh in to help.
we're modelers it's what we do
Posted by Bish on Friday, February 3, 2017 1:59 PM
RAl 8000 was Grunbraun and Gelbbrun (yellow brown) was RAL 8020. 8000 was a darker brown colur and officially was combined with 7008. In March 42 the colour switched to 8020, a very light colour and 7027. So it really depends on when the vehicle you are doing reached Africa and if it got there before March 42, would it have been re-painted.
Also keep in mind the situation the Germans faced in Africa. Paint was not a priority for many variations can be found.
Posted by Bish on Friday, February 3, 2017 2:00 PM
armornut
Schokolade
    November 2016
Posted by cabrown1 on Friday, February 3, 2017 2:51 PM
I've found this site to be a wonderful source of information on paint colors for german vehicles:
http://www.webring.org/l/rd?ring=ww2;id=863;url=http%3A%2F%2Fstugiii%2Ecom%2Fhome%2Ehtml
The link takes you to their home page, then click "German Vehicle Camouflage". Hope this helps.
Charles
Posted by Bish on Friday, February 3, 2017 3:12 PM
cabrown1
Charles
But always treat with caution. What the rules say and what happened on the ground are not always one and the same. Only way to be sure, find a pic of the vehicle your building, if possable, in colour. But good luck with that Wink
    September 2016
Posted by ManCityFan on Friday, February 3, 2017 3:26 PM
Bish
So it appears that AMMO of Mig Jimenez has a pretty good representation of RAL 8000 based on comparing it to the website above, although that color is darker than anything I have seen done by other modelers.
I could always cheat and use British desert color and say this paint was used after being captured (which would be historically accurate).  Or, I could paint armor gray, and weather the hell out of it with mud (which would also be historically accurate from what I have read).
Ooh, that would be a great diorama.  Unhappy tankers slapping mud on their gray tank so it won't stick out like a sore thumb.  Keeping that one for a later build.  I would have to find figures that would fit that scenario.  Just trying to get a decent tank done at this point with limited experience.
I have had no luck finding a picture of a DAK Panzer II in color.  Plenty in B&W, but interpreting that is pretty tough.
Going to put an online order in this weekend, and will probably go with the Mig paint, shoot it, then post here, and see what folks think.
Thanks for the input.  It is greatly appreciated.
Posted by Bish on Friday, February 3, 2017 4:49 PM
ManCityFan
Bish
I have never used the MiG paints. I use Xtracolour which comes in the colour ranges, RAL, RLM etc. But even so, colours vary. One museum was restoring a 251 a number of years ago and found 7 shades of Dark Yellow. So try the MiG out and see what you think.
By the way, which Pz II kit have you got.
    September 2016
Posted by ManCityFan on Friday, February 3, 2017 5:37 PM
Tamiya Pzkw II ausf F or G. Very old kit that came out in the 1970's. I bought it in the 1980's. Not up to today's standards, but still a nice kit. Comes with what I think are called poly caps, so you can put the road wheels on without gluing them. This is a learning kit, and I plan to use some oil paints for weathering, which will be a new skill for me.
Posted by Bish on Friday, February 3, 2017 6:17 PM
O ye, many of us have cut our teeth on that one. Certainly one to use as a practice piece.
    July 2004
Posted by stikpusher on Friday, February 3, 2017 8:19 PM
Bish
in all honesty, do abase coat or Panzer Gray (or Grey for Bish) and do a mud coat.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2016
Posted by ManCityFan on Friday, February 3, 2017 9:10 PM
Well, I was kind of kidding about that, but it certainly would help me learn what does and doesn't work for weathering effects. Could be quite fun, actually. And that is the point.
    July 2004
Posted by stikpusher on Friday, February 3, 2017 10:32 PM
You will never have more fun than weathering an AFV... Wink
       - Plankton
LSM
    April 2006
Posted by jgeratic on Friday, February 3, 2017 11:01 PM
I'd say only the very first arrival of vehicles (10 February – 12 March 1941) would of been finished in grey.  This was initally known as the 5th light division, later redesignated the 21st Panzer Division on August 15th.
Photos show that by the time 15th Panzer arrived (between April 24th and May 6th  1941), they were shipped in factory tropen colours:
Also, the Panzer IIf production began March 1941, so it's doubtful this version was shipped in grey scheme.  The balance of  5th light's panzer force was shipped Feb.28, while the other panzer division ship dates are noted above.
regards,
Jack.
    March 2007
Posted by armornut on Friday, February 3, 2017 11:51 PM
Danke schoen Her Bish. Looks like we got this gentleman on his way to the dark side. (insert maniacal laughter here). Thanks also to all y'all who chimed in,  MCF please post pix when ya get the ball rolling. Happy modeling good sir.
Posted by Bish on Saturday, February 4, 2017 1:11 AM
stikpusher
Bish
Do you guys really spell Grey with an a. Well i never spotted that.
Posted by Bish on Saturday, February 4, 2017 1:13 AM
ManCityFan
Its wasn't un known for Germans to use mud to camo a vehicle, both in Africa and elsewhere, especially when the vehciles were grey.
Posted by Bish on Saturday, February 4, 2017 1:15 AM
armornut
Herzlich willkommen.
Ye, deffo post pics. It doesn't count unless we see evidence. Wink
    September 2016
Posted by ManCityFan on Saturday, February 4, 2017 9:32 AM
Well, I did find this picture:
If you look at the turret, you can see what looks like panzer grey around the insignia.  Not sure if this was reapainted or just had mud splattered on it.  So I think I will prime in panzer grey, and then use RAL 8000 over it, then weather heavily with dust effects.  I remember reading that dust got EVERYWHERE, and that in B & W photos, what looks like yellow is actually dust.
    September 2016
Posted by ManCityFan on Saturday, February 4, 2017 9:35 AM
armornut
No need to push me to the dark side.  Already there.  Here is a picture of my "vintage" stash that has followed me from home to home for the past 30 years.
Finally decided it is time to put some of these together.
Thanks all for the comments!!
    April 2006
Posted by jgeratic on Saturday, February 4, 2017 10:43 AM
Not directing you how to paint your model, just providing info ...
The colour beach photo does look to be a paste created from desert sand covering the vehicle, but again, it is an earlier mark of the Panzer II - note the lack of a turret bin.   The bullet splash shields in front of the turret was characteristic of the early panzers that landed with 5th light div., and not the F model.
There is this colour photo of an Ausf. F captured by Americans in Tunisia:
Tank has been identified as belonging to Panzer-Abteilung 190.   It does look like the original paint was grey.  My only question is why do the helmets look dark grey?
regards,
Jack
    December 2012
Posted by Ixion on Saturday, February 4, 2017 1:20 PM
This vehicle is from the 5th Leichte Div., (rebuilt into the 21st Pz Div. in August, 1941), Pz Rgt 5, as evident by the riveted armor splash guard added to the mantlet front, a modification unique to the Pz IIs of Pz Rgt 5, as is the right side mounted storage box seen in this photo;
This is an Ausf B, as noted by the lack of conical boltheads over and under the vision blocks. Note 21st Pz. Div. symbol.
The color shot is either a Ausf B or Ausf C, as noted by the riveted mantlet splash guard armor and earlier, spoked idler. Definitely not a Ausf F. It appears to be sporting an application of mud slurry over it's original Panzer Grey.
    September 2016
Posted by ManCityFan on Saturday, February 4, 2017 1:42 PM
Thank you for the clarification and photos. The photos are great! Thanks for the info on the 5th light and 21st Panzer. I had forgotten that history. So I will get the Mig early DAK paint set, which includes RAL 8000, and do the first tropen scheme, then weather heavily with dust. You may be wondering why I am worrying about a $10 model, but want to set up good habits early by doing research and asking questions. Thanks again for an informative thread.
    July 2004
Posted by stikpusher on Saturday, February 4, 2017 7:23 PM
jgeratic
regards,
Jack
US Army Olive Drab paint has certain gray aspects depending upon lighting conditions. Also when you add in the peculiarities of various film types the gray aspects can really be pronounced.
       - Plankton
LSM
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Saturday, February 4, 2017 9:56 PM
ManCityFan
                                           http://www.sherv.net/cm/emoticons/confused/puzzled-smiley-emoticon.gif
A great strategy that will serve you well in more expensive builds.
                                                   http://i20.photobucket.com/albums/b232/gluetank/Animated/Disastermastermotion-3.gif
 https://i.imgur.com/LjRRaV1.png
Posted by CapnMac82 on Saturday, February 4, 2017 10:19 PM
Bish
There's a mnemonic:  "England withan 'e'; American with an 'a.'" to remember the spelling.
Our Canadian neighbors will append "colour" to keep it clear (the usof the Norman spelling of the ö dipthong as "ou" is consistant all acrss Canada).
Posted by Bish on Sunday, February 5, 2017 1:13 AM
disastermaster
ManCityFan
Yep, better to get these things sorted on a $10 model than a $70 one.
Posted by Bish on Sunday, February 5, 2017 1:15 AM
CapnMac82
Bish
Thanks. I knew about the U, can't miss that one on here, but didn't know about the a and e.
    January 2008
Posted by Byrden on Sunday, February 5, 2017 2:00 PM
Check out the Tiger at Bovington Museum, they have it painted 7008 over 8000. There are plenty of colour photos on the Web.
David
    December 2012
Posted by Ixion on Sunday, February 5, 2017 5:08 PM
I forgot I had these photos. An unrestored Ausf F from 15th Panzer Div. in overall RAL 8020. Note 15th Pz. symbol next to right tow hook.
Note the Panzer Grey on the insides of the engine hatches and the area behind the missing muffler, exhaust pipe flange area, driver's visor and the starter crank hole. Surprised to see even the convoy light lenses are still intact!
