M1008 CUCV Miniman Factory 1/35 blog
    January 2006
Posted by SprueOne on Wednesday, April 26, 2017 11:03 PM
Miniman Factory M1008 CUCV kit in 1/35 will be my first all resin and PE kit build.
kit contents overview
The following are side by sides with the MENG "Toyota"
sprueone
sprueone
sprueone
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    July 2004
Posted by stikpusher on Wednesday, April 26, 2017 11:54 PM
Yes
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2006
Posted by SprueOne on Saturday, April 29, 2017 12:40 AM
interior assembly m1008 sprueone
Steps 1, 2, and 3 start with the cab interior parts.
dashboard m1008 cucv sprueone
I cut a little too much of the pour block off of the dashboard part. Cut off the base of the pour block and leave the section that is attached to the "back" of the dashboard. This will assist in setting it level and will glue under the hood area.
scratch built window cranks sprueone
m1008 cucv interior detail sprueone
The window cranks and, door lock release lever, are made from scrap pieces around the bench. A hole was drilled through the door interior parts and shaped with a square file. They are a little over size because I didn't actually measure anything and just did it visually.
parts assembly conflict sprueone
The floor part strikes an interior ledge under the grille opening and doesn't seat flush.
m1008 cucv cab floor sprueone
measured 1mm
m1008 cucv material removal floor
Remove 1mm from front of floor part, above chassis frame.
m1008 cucv clean parts layout sprueone
The kit parts cut away from their pour blocks and all cleaned up. The kit supplied PE and a few other fine details are not in this picture.
Previewing the assembly instructions booklet, I see that my kit does not have white metal parts but all resin instead.
... thanks for looking.
    July 2004
Posted by stikpusher on Saturday, April 29, 2017 1:10 AM
Thanks for showing us your progress.
       - Plankton
LSM
    January 2006
Posted by SprueOne on Sunday, April 30, 2017 11:25 AM
You're very welcome Beer
    January 2006
Posted by SprueOne on Sunday, April 30, 2017 11:50 AM
 The cab interior, floor part, is not installing as easy as the I-Sheets describe so while I'm solving that, here are some close up shots of some of the other parts...
m1008 cucv suspension axles sprueone
^ These are the resin parts in my kit that are described in the I-Sheets as metal. The casting looks good (except one spot) so it's probably not going to be a problem.
m1008 cucv leaf springs sprueone
^ I broke a fragile part off during clean-up. It's the postioning peg for the, Right Side Front, leaf spring. The flat area just below it contacts the chassis frame after installation so I can still get it to fit right. Then I'll just glue the broken part on after.
^ v The, Left Side Front, part has a casting flaw on the rear end.
^ v There was enough material there to solve this little problem. Using the other part for position reference, a small flat file created a shelf for the flawed end to rest on the chassis frame in the correct position. (hopefully)
v I think the tow hooks are not the accurate shape but they look so good. And they just snap into place so they can articulate. I'll paint them like this on their pour block then cut them off later for installation.
m1008 cucv tow hooks sprueone
    July 2004
Posted by stikpusher on Sunday, April 30, 2017 7:44 PM
That suspension looks so fragile. Good save from the break during clean up. The tow shackles look ok in shape, perhaps a tad bit too thick. But I definitely came across some shaped like that in my time in the Army.
       - Plankton
LSM
    January 2006
Posted by SprueOne on Monday, May 1, 2017 8:25 PM
Oh, ok, cool. I thought they were a little more horse shoe shaped rather than a U .
Posted by Gamera on Monday, May 1, 2017 8:59 PM
Ohhhhh, very cool! Never had a truck of that year range but still pretty familar with it.
    January 2006
Posted by SprueOne on Tuesday, May 2, 2017 9:26 PM
Hi Gamera, Thanks for checking in. I've never owned a truck yet.
    July 2004
Posted by stikpusher on Tuesday, May 2, 2017 9:59 PM
SprueOne
I've seen both types. As well as the hooks that you slip the of the tow cable over.
       - Plankton
LSM
    January 2006
Posted by SprueOne on Thursday, May 4, 2017 7:48 PM
Awesome, obviously I've never been around these ion 1/1.
    January 2006
Posted by SprueOne on Thursday, May 4, 2017 7:58 PM
m1008 cucv interior assemble sprueone
Assembling the floor part into the cab doesn't go as simple as the instruction sheet describes.
The seat bottom, dashboard, and interior door detail parts are barely glued in with just a drop of glue for dry fitting. I thought I could just glue the back of the seat in later through the windows.
I tried to slide it in above the bottom lip (1), then click the front wheel arch part in (2)
The seat strikes the dashboard part also.
The seat is too wide so it strikes the arm rests of the, interior door detail, parts.
I removed approx 2mm of material from both sides of the floor. This will allow the floor part to clear the lip of the bottom of the cab.
Material had to be removed from each side of the seat to fit between the interior door detail parts.
Now I can assemble like the I-Sheets describe with the seat already glued in.
oops, now the arm rests are too low. That's ok, because it's model building, right? This problem will also be solved.
... Thanks for looking...
Posted by Gamera on Friday, May 5, 2017 10:38 AM
ARRRRGGGGGHHHHHHH!!!!!!!!!!
I know the feeling, sometimes nothing fits the way it's supposed to!
You're doing a great job with the corrections though.
    January 2006
Posted by SprueOne on Friday, May 5, 2017 8:44 PM
Thanks!
I've worked out what I need to do next so progress will continue this weekend and I'll post pictures soon after.
    March 2013
Posted by LonCray on Tuesday, May 9, 2017 9:44 AM
Being as I drove one of these (and its CUCV Blazer brother) in the Maryland NG back in the early 90's, I would LOVE to see this in styrene.  Army had plenty of these (before the Humvee filtered down to the NG level) and they were a lot of fun to drive.
    January 2006
Posted by SprueOne on Wednesday, May 10, 2017 9:07 PM
Thanks for checking in. Cool you've actually drove these things around.
I added this thing to the dashboard part. Any idea what the thing is mounted above the fire extinguisher that looks like a cap to unscrew with a lanyard chain attached to it?
picture: http://gomotors.net/photos/35/57/fileinnenansicht-chevrolet-m1008-cucvjpg_5529c.jpg?i
Posted by HeavyArty on Wednesday, May 10, 2017 9:23 PM
The below part w/the little cord on the dash is a NATO slave cable adapter.  You hook the slave cable from another vehicle here and jump the truck like you would with jumper cables on a civilian car.
Yup, these were pretty fun to drive, esp. offroad. On the highway, they were pretty slow and vibrated a lot.
    January 2006
Posted by SprueOne on Wednesday, May 10, 2017 9:57 PM
Thanks for the info. I thought that was in the grille on the right (vehicle right).
CUCV grille
photo from, Hank Chinaski's photobucket
Posted by HeavyArty on Thursday, May 11, 2017 7:44 AM
You are right.  That's what I get for trying to reply and watch the Caps lose miserably to the Pens in game 7.Boo Hoo
It is actually a STE/ICE (Simplified Test Equipment/Internal Combustion Engine) connector.  It was an early vehicle diagnostic system that connected to a very basic "computer" to diagnose engine and electrical problems.
More info here: http://www.survivalebooks.com/free%20manuals/US%20Army%20Simplified%20Test%20Equip-%20Intern%20Combust%20Engine%2076p.pdf
The set looks like this:
    July 2004
Posted by stikpusher on Thursday, May 11, 2017 11:18 AM
That box in the center- with the lid on, it looks just like the MGS box from a TOW system. Of course that does not do diagnostics on engines....
       - Plankton
LSM
    January 2006
Posted by SprueOne on Thursday, May 11, 2017 8:12 PM
Great, thanks for the additional info on this and a hockey fan I see. Yes
This is the dashboard part with the additional STE/ICE part added.
m1008 cucv dashboard sprueone
The transmission shifter that was included in the kit was glued to the left side of the steering column and a scratch built transmission shifter was glued into a drilled hole into the right side.
    March 2012
Posted by mustang1989 on Thursday, May 11, 2017 8:55 PM
Dang Bob!!!! I didn't see this thread until now! What an awesome-double throw down build you've got going here bud. I used to drive the hell out of these things in the late 80's early 90's. I had one assigned to me while I was assigned to the 175th CAC in 6th CAV while at Fort Hood. My truck was 175-3. I remember taking care of that thing like it was my own. Had the engine compartment all shined up and all while it still had the factory Delco batteries under the hood. Once those gave out they were replaced with an all green colored cased "lowest bidder" military batteries and those things leaked like hell. Totally destroyed the whole R/H side of the engine compartment with corrosion. Things went down hill from there and then got worse when I got moved from the maintenance platoon to a flight platoon out at the hangar. I loved flying more than I loved that old truck but seeing stuff like this strikes a good chord with me. I really enjoy watching something like this come together and will try my best if you have any questions in regards to the details. Model on brutha!!!! Yes
 Forum | Modelers Social Club Forum (proboards.com)
    January 2006
Posted by SprueOne on Thursday, May 11, 2017 9:03 PM
Thanks for checking in, Man. You have a history with these pickups I see. Great story and I may take you up on that offer of details info... Beer
    January 2006
Posted by SprueOne on Sunday, May 14, 2017 6:21 PM
Once the seat and interior door parts are installed in final position the armrests looked like they were too low.
To correct this, approx. 3mm of material was cut off the top of the interior door parts.
m1008 cucv armrests sprueone
m1008 cucv arm rests sprueone
When these parts are installed into final position, flush with the window sill, the armrest will be at a higher level.
The seat support bracket was trimmed down at the change in detail. I didn't measure this because it just looked about right.
m1008 cucv bench seat sprueone
The seat will be lower now glued into position.
m1008 cucv seat back low sprueone
Now the armrest and seat bottom look about right. However the seat back now looks too low against the rear window.
I want to raise it up about 1mm.
m1008 cucv raise saet back sprueone
I added putty to the bottom to increase the height. Then glued it back onto the seat bottom.
m1008 cucv seat back raised sprueone
Now it looks much better.
m1008 cucv seat belts sprueone
I also shaved down the sides of the seat back to match the bottom. This may allow room for seatbelts if I decide to install them.
thanks for looking...
    July 2004
Posted by stikpusher on Sunday, May 14, 2017 7:12 PM
I was showing this build to a couple of the vets at AMPS yesterday. They like your project.
       - Plankton
LSM
    January 2006
Posted by SprueOne on Sunday, May 14, 2017 10:17 PM
That's cool. I hope I don't disappoint them.
    July 2004
Posted by stikpusher on Sunday, May 14, 2017 11:37 PM
Nah, they were all just happy to see one being built.
       - Plankton
LSM
    January 2006
Posted by SprueOne on Monday, May 15, 2017 8:45 PM
haha, true that. Before starting I searched the interwebs the best I could for a blog of this kit. There is a clear and thorough blog here on FSM by Redleg12 started in 2012 of the M1009 by Miniman Factory.
    March 2012
Posted by mustang1989 on Monday, May 15, 2017 9:36 PM
Man you're throwin' alot at this puppy Bob! I'm digging the progress and outcome so far buddy.
