Tank main gun detailing
    November 2023
Posted by Don_K on Wednesday, November 8, 2023 2:08 PM
I've been away from model building for about 25 years.  Kinda impressed with the advancements while I was away!
I'm having fun (and some frustration) with a 1/35 Serman M4A1.  Does anyhone have any good ideas on how to simulate the rifling in a tank main gun barrel?  Every search I have done (including the word's "model kit" just comes back with links on what rifling ius in real guns.
Not sure it can be done on a 1/35 scale but I'd like to hear any good idea's anyone can share.
Thanks in advance,
Don
    May 2009
Posted by Pawel on Wednesday, November 8, 2023 3:33 PM
Hello Don!
I don't know if it's worth it, on the few real tanks I've seen that rifling wasn't all that noticeable (and most of them had a muzzle brake anyhow). I've seen something to show rifling on some metal barrels - like this one here:
Source: Scalemates.com
- but they are axial, not helical (that would be OK with me).
I hope this helps you - good luck with your builds and have a nice day
Paweł
www.vietnam.net.pl
    November 2023
Posted by Don_K on Thursday, November 9, 2023 11:20 AM
Thanks Pawel.  I am probably trying for too much detail.  I'd probably be better off scratch building interiors and leaving the hatches open.
Don
    July 2004
Posted by stikpusher on Thursday, November 9, 2023 1:14 PM
Years ago, one of the Aftermarket companies sold photo etched sheet that had the rifling on it and you could use to line your model's gun barrel. I don't recall which company or know if it's still available. But at one time, such a product was available.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Rob Gronovius on Friday, November 10, 2023 12:38 PM
Depending on the caliber of the gun, the rifling may or may not be visible in scale. Something larger like a 90 mm, 105 etc. Sure.
A smaller barrel like a 50 or 76, maybe not in 1/35 scale.
    December 2012
Posted by Ixion on Thursday, November 30, 2023 3:19 PM
A DIY method of the product Stikpusher mentioned is to use lead foil, (I have a large stash from old wine bottle hoods). Scribe parallel groves in foil with a ruler and X-Acto blade to represent the rifling. Cut foil into a suitable rectangle, in which the length matches the gun's diameter when rolled-up, (C=2πr). It will take some test fitting to get the length just right. Give the rifling a black wash to make it stand out and insert the rolled rifling into the barrel, seam side up and glue with CA. Burnish the outside edge with a round, pointed tool to blend the edge into the barrel. I've used this method on larger guns, it may be rather tricky on a barrel his small. If the thickness of the foil is a problem, you can drill out the barrel to ensure the correct diameter.
