How to Make Plastic "Rubber" Parts More Rubber-like?
    July 2003
Posted by MonsterZero on Wednesday, May 26, 2004 2:16 PM
My T72 tank currently in assembly has side skirts and wheel tires that are made of rubber in the real vehicle. Tamiya tells me to simply paint them flat black (not sure I like the idea, if anything they should be very dark grey).
What would you do to make them more rubber-like in appearance? I think Testors makes dedicated "Rubber color" paint.
Posted by Anonymous on Wednesday, May 26, 2004 2:26 PM
Several companys do make "rubber" color paint but I always use black. after weathering it looks fine.
    December 2009
Posted by wildwilliam on Wednesday, May 26, 2004 2:43 PM
Testors does make a color 'rubber' available only as a 'square bottle' enamel.
it is pretty good looking, and i use it myself.
but i have also used flat black,
flat black w/ some grey
flat black w/ some grey & some brown
a Sharpie (followed w/ dullcote)
after flats, dry brush for tread or wear, wash, weather, many things look pretty good.
i guess i would recommend experimentation,
and balancing the effort/result ratio to an acceptable level.
    April 2004
Posted by crockett on Wednesday, May 26, 2004 3:11 PM
I use the Testors rubber paint with success. If I need more realism i.e. "chunking" the rubber on the road wheels which happens on real tanks with regularity, I will paint the hole with a flat back mixed with a little gray. On brand new road wheels the rubber surface is actually a little glossy, but after a few weeks in the field, the bearing surfaces take on a slightly lighter hue.
Posted by Anonymous on Wednesday, May 26, 2004 3:15 PM
In my humble opinion....sorry ed, Testors rubber is too reddish. I think a dark almost black gray is best with a slight sheen to the edges.... just my 2 cents
    February 2004
Posted by tlivancso on Wednesday, May 26, 2004 5:21 PM
I like to used Gunze's Tire Black MAH077 for painting rubber parts such as road wheels, airplane tires. Dries nice and dark gives a rubberized appearence.
Cheers
IPMS Member #42958 /  AMPS Member #2091
IPMS Central Connecticut (President)
IPMS Northeast Military Modelers Association (Web Master)
Like Alice "I try to believe in three impossible things before breakfast"
    January 2003
Posted by wipw on Wednesday, May 26, 2004 5:33 PM
Another possibility is Floquil's Weathered Black or Grimy Black. Both have grey in them but are still pretty black. Old Floquil paints would eat plastic, if brushed on. I understand the newer type won't do that. But they are still lacquer based and therefore need lacquer thinner for clean up.
Bill ========================================================== DML M4A2 Red Army ========================================================== ========================================================== -- There is a fine line between "hobby" and "mental illness". (Author unknown)
Posted by Anonymous on Wednesday, May 26, 2004 8:39 PM
Try Polly Scale-Grimy Black, thinned with Windex. That's what I've used recently. I also referred to the article, "Brush Painting Basics," in this month's issue of FSM. Very Helpful!
-Cheers
    May 2003
Posted by erush on Wednesday, May 26, 2004 9:48 PM
Poly Scale also has a "scale black" that is a good gray-black and looks good.
Eric
Hi, I'm Eric and I'm a Modelholic too. I think I have PE poisioning.     "Friendly fire...isn't"
