QUOTE: Originally posted by johnpo
Anyone have the skinny on this T-62 braille scale?
John
Well, I'm not Rob, but I have built several of these kits, one of which is featured below:
It is the Israeli captured version before it was converted to a Ti-6
It is a fairly simple kit with pretty good detail. It features link & length tracks; the first model I'd ever built with them. The kit went togther well with few fit problems. The downside is it is slightly over scale, and the wheels are very basic and simple, and not very accurate.
I liked how I could make the 12.7mm DsHK moveable up and down through careful construction.
Altogether, if you are looking for a simple build that can look good, this is an acceptable kit to build, particularly if you are lookingh for something easy to put together. If you are looking for something a bit more detailed and accurate, then you'll want to go with ACE's selection. Be warned, their kits need alot of cleanup, and can be difficult to fit together. With a lot of patience and careful buildiing, the ACE kit builds into an excellent model.
Hope this helps.
