Hand Painted Numbers vs Decals
Posted by Anonymous on Tuesday, September 28, 2004 6:45 AM
Working to complete my first armor model, a Tamiya Panther Ausf A. I applied zimmerit (RJ Products) but wonder if the decals can be applied over the zim or will it be necessary to hand paint the turrent numbers. If hand painting is the way to go, does anybody have any suggestions on how best to do this?
This forum has been an invaluable resource to me as a beginning modeler. Thanks for all the help. A.D.
    July 2003
Posted by okieboy on Tuesday, September 28, 2004 8:21 AM
Hi Apache,
I've used Zimm-it-rite too. When I built my Tiger I, I had to air brush the numbers and Balkan crosses on because my ridges were so deep. If you sand the zimm down by hand a bit you should be able to apply decals. If you try this, I would recommend buying a bottle of "Solva-set" to apply to the decals once you have them in place. This will help suck the decal into the nooks and crannies of the surface and seal it in. Good luck.
Okieboy
"We sleep safe in our beds because rough men stand ready in the night to visit violence upon those who would do us harm." George Orwell
    July 2003
Posted by diggeraone on Tuesday, September 28, 2004 10:27 AM
I agree with okieboy solva set is the best way to go.There are other ways like dry transfer decals or hand painting.The solva-set thought will soften the decal into the cracks for that realistic look.You use it after you just applyed the decal,use a q-tip to dry up the water that is left after you applied the decal. This will help the decal to into the cracks.Then apply the solva-set in a light application and use a q-tip after a few seconds when the solva-set has had time.You will be amaized at the resluts.Digger
Put all your trust in the Lord,do not put confidence in man.PSALM 118:8 We are in the buisness to do the impossible..G.S.Patton
Posted by djmodels1999 on Tuesday, September 28, 2004 11:39 AM
I always paint my numbers and insignas on AFVs. Can't bear the thought of silvering..! On smaller scales, the decal's film often show up too much too..
Posted by Moses on Tuesday, September 28, 2004 12:20 PM
Kit decals are basically a no no on Zimmerit. I have had great success with Archer and Verlinden Dry Transfers and I highly recommend them. Of course hand painting is perfectly fine if you wantto go that course, but you will receive much better results with a Dry Transfer. All you need to do is burniosh it until it comes of the top coat, then coat it with Micro-sol, with a final coat of Miro-set to seal it.
The markings on the Tiger I are dry transfers over the hand made zim.
Cheers
Mo
"ZIM FIRST, ASK QUESTIONS LATER!!"
Posted by JWest21 on Tuesday, September 28, 2004 2:15 PM
I used kit decals soaked liberally in Testors setting solution (complex surface one) on Cavalier zimmerit and it turned out good. I first painted the surface with future. Then after the decals went on, I used a stiff brush soaked in setting solution to jab the decal into the zimmerit. After a flat coat, there was just one little portion that silvered, which was trimmed off with an exacto knife.
Jason "There is a very fine line between "hobby" and "mental illness." -D. Barry
Posted by Moses on Tuesday, September 28, 2004 2:43 PM
Hey if it works for ya JWest, go with it. I personally found that Dry Transfers work the best if you do not want to hand paint..
Cheers
Mo
Posted by JWest21 on Tuesday, September 28, 2004 2:48 PM
I haven't tried the dry transfers yet, but I may the next zimmed tank I do. As for hand painting, I would try the mono-colored numbers, but the two color numbers scare me.
Posted by Anonymous on Tuesday, September 28, 2004 5:44 PM
If you were going to paint them , I don't know if anyone has suggested stencil's would be a good way to go.
Posted by Anonymous on Tuesday, September 28, 2004 7:30 PM
Other than painted on, dry transfers are the only way to go. No silvering, no decal film, no paint mistakes, no Future, no problem.
    January 2004
Posted by cplchilly on Tuesday, September 28, 2004 9:57 PM
I used a combination on my late Tiger (Ital kit) painting the turret #'s on and using the kit supplied crosses for the hull and the ruffing them up a bit with a brush to give it a more hand applied look.
http://img1.photobucket.com/albums/1003/cplchilly/?action=view¤t=bills_models_040.jpg
[img]http://members.fcc.net/ice9/badge.jpg
Posted by Anonymous on Tuesday, September 28, 2004 11:08 PM
Dry transfers are more expensive than a couple of jars of paint. Yet usually you get enough on a sheet to use on several models, so maybe the cost isn't so bad. They are, however, quick to put on once you get the hang of them.
Glenn
    July 2003
Posted by ridleusmc on Wednesday, September 29, 2004 12:52 AM
I'm looking intentively at the answers to this question, because I'm about to be presented with the same delema. If the solvaset doesn't work for me, I'll (somehow) knock off the decal and use dry transfers or a stencil. I don't know about hand painting. It may turn out too rugged.
Posted by djmodels1999 on Wednesday, September 29, 2004 1:39 AM
Painting two-tone numbers is not that hard really... The key is to work with thinned down paints. This helps application, keep the insigna very flat and thin, and already gives a bit of weathered look with a touch of base color showing through...
I start with the color that outline the number, but I paint the whole thing rather than just an outline. On Zimmerit, errors are 'allowed'. After all, even if airbrushed on the real thing, there would have been paint splilling under the stencil... Once the paint is dry I then add in the 'inside' color. Since there is a 'line' to follow, it is easier to do this stage than the first one. Glarring mistakes can the be corrected with paint or scrapped away with a cocktail stick. I normally use enamels for this as up to a certain point, it is easy to scrape minute amount of paint with a cocktail stick and correct little mistakes.
    August 2003
Posted by South Aussie on Wednesday, September 29, 2004 4:48 AM
I obtained at set of templates (stencil's) many years ago for German crosses that worked well on zimmerit finishes. The templates were manufacturered by Verlinden, and although I can't be sure I think they also had a set for numbers.
Wayne I enjoy getting older, especially when I consider the alternative.
    July 2003
Posted by okieboy on Wednesday, September 29, 2004 8:32 AM
I used a homemade stencil for the two tone numbers and the balkancrueze for my Tiger. I used the stencil to paint the red interior of the number and then hand painted the white outlines.
Okieboy
Posted by Anonymous on Thursday, September 30, 2004 2:40 PM
Excellent information as usual. Thanks to everybody for their suggestions. Since I'm just starting out of the gate in my modeling career, I may try the decals. I did check out the transfers and I'm sure that's the way I will go on my next model along with better tracks and a one piece barrel. Once again, you folks have been a big help. Thanks again. A.D.
