- Member since
May 2003
Posted by rtvmodeler
on Tuesday, November 16, 2004 3:07 PM
QUOTE: Originally posted by blitzer
is the pzkpfw IV Ausf H a good kit from academy? I found one that was nice and cheap and i was wondering if that was a good buy or is it cheap because its bad. thanks for the input. Levi
In my opinion, this kit of Academy is from regular to bad, I had some problems with it as: the upper rear are very short for adjusting the second part, in order to correct, both parts were filled with putty. Finally for reinforce the parts, I posted glue on the surface. Some faults as: hatches, rear hull, rear chassis, lateral pipes, muzzle of the gun barrel, skirts of the turret missing, etc., I know, this is a very old kit. But, with patience and time you can obtain a good result.
Here you can see my work in progress: http://rtv-mm.com/MyProjects/PanzerIV/panzeriv-1.htm
Regards,
Rodolfo
Current Project:
Figures from Dragon, "German 6th Army, Stalingrad 1942-1943", 1/35
