m-60 patton model?
m-60 patton model?
Posted by Anonymous on Monday, December 13, 2004 4:22 PM
Does anyone know a model company that makes an M-60 Patton tank, or conversion kit?
    July 2003
Posted by ridleusmc on Monday, December 13, 2004 4:33 PM
Tamiya Makes a USMC M60A1 w/ Reactive armor and an M60A3
Revell also makes an M60A3
I'm sure there are more kits out there, but those are the ones I know of.
Posted by kaleu on Monday, December 13, 2004 4:35 PM
Esci makes several M-60 kits. They have recently been rereleased by Italeri, but the Esci kits are a better bargain. The molds are getting old and the Italeri releases seem to have flash and sink mark problems. The Esci M-60's can usually be found on Ebay for about $10. Some aftermarket items are made by AFV Club (tracks), p/e frets (eduard, but tough to find) and Tiger Model Designs makes a replacement cupola. There is more stuff available, but this is all I can remember at the moment. Hopefully Major Gronovius will see this post and give you more information.
Erik "Don't fruit the beer." Newest model buys: More than I care to think about. It's time for a support group.
Posted by Rob Gronovius on Monday, December 13, 2004 4:50 PM
Are you talking about the M60 aka "Slick 60"? If so, the only kit that I recall off hand is an old Tamiya 1/48 scale kit that is motorized and long OOP. If you do a forum search here, I listed all the 1/35 scale M60 variants available today and some of the older kits that you can still find in stores or on eBay.
Chesapeake Model Designs (CMD) makes a really nice M60 turret that you can add to an M60A1/A2/A3 kit to back date it to an original M60. I've got one and recommend it. I can dig it out if you want to know the kit #.
Posted by tigerman on Monday, December 13, 2004 5:50 PM
My son has the Tamiya with the reactive armor. Let's just say the putty tube has gotten a work out, not to mention very noticable motorization holes.
 Eric
Posted by Anonymous on Monday, December 13, 2004 8:39 PM
In the 1/35 scale, there are the Tamiya & ESCI kits (mentioned previously). But, to my mind, the best kits of that AFV/in that scale are those made by Academy. The latter has a US M-60 (with reactive armour) # 1349. As well, a couple Israeli versions (one is the basic tank...the other has a mine roller attachment. I can't recall the kit numbers for the latter 2, but I'm sure one could find them in the Academy catologue.
    July 2003
Posted by diggeraone on Monday, December 13, 2004 9:18 PM
Revell of Germany makes the best of the tank in that line and the price is not bad at about $22.00.It has so fine details with section and indy tracks.Digger
Put all your trust in the Lord,do not put confidence in man.PSALM 118:8 We are in the buisness to do the impossible..G.S.Patton
Posted by HeavyArty on Monday, December 13, 2004 10:02 PM
Revell of Germany version is a rebox of the Italeri, which is a repop of the old Esci molds. Therefore, as mentioned above, Esci model is still the best.
    January 2004
Posted by gdarwin on Tuesday, December 14, 2004 1:29 AM
Big Smile [:D] i have see the italeri m 60 patton,other than that i cant be of any help,sorryBlush [:I]
gdarwin[roy]
airborne death from above http://photobucket.com/albums/a350/roygd/
Posted by Rob Gronovius on Tuesday, December 14, 2004 6:25 AM
Italeri didn't rebox the ex-Esci M60A3TTS, only the ex-Esci M60A1 and M60A1 Blazer. The M60A3TTS and M60A1 have a different parts layout due to a mold swap section that deals with the air cleaners and main gun tube. Basically the only difference between the two models.
    March 2004
Posted by Scorn on Tuesday, December 14, 2004 6:34 AM
Tamiya makes the M60A3 kit, or they used to. Academy makes Israeli Blazer with is actually a Magach 6B. They also make the US Marines M60A1 with reactice armor and blade attachement.
You can find M-48s pretty easily these days. The differences are fairly supperficial if you wanted to try your hand at conversion. AEF Designs has many different add-on and conversion kits for the whole Patton series of chassis. Verlinden also makes a blade conversion for the M48/M60 series of tanks.
The US made a lot of armor vehicles off of the Patton chassis so there are tons of different variants out there to choose from. M88 Hercules, M728 Combat Engineer Vehicle, as well as a couple of nice bridge layers. Any of these kits could be converted to an M60 MBT with the right add-on kit or some good imagination.
Posted by HeavyArty on Tuesday, December 14, 2004 9:30 AM
QUOTE: You can find M-48s pretty easily these days. The differences are fairly supperficial if you wanted to try your hand at conversion.
The above is incorrect. The front hulls are totally different. M48 has a rounded hull, M60 has a sloping angular hull. Lower hull on M60 is very diferent as well. Turrets are very diferent too. Comanders cupola on the turret top is diferent too. It would be very dificult to convert an M48 into an M60. Much easier to buy one of the M60 kits available out there.
M48:
M60:
They are both derived from the Patton series of tanks which started with the M26 at the end of WWII and went through the M60A3, but are not the same. M60 was a further develop[ment and next generation to the M48. For more info on the M48, M60, and other Patton versions, check here: http://www.patton-mania.com/index.html
    March 2004
Posted by Scorn on Tuesday, December 14, 2004 1:58 PM
I understand the front hull is different. That, IMO, wouldn't be a hard conversion. Yes, the turrets are different too, but I also suggested that he could use the hull and also use conversion kits to supplement and create the vehicle he is after.
I was trying to make the point that even though there aren't that many 60 models out there, there are options available to make it happen.
Posted by ABARNE on Tuesday, December 14, 2004 2:10 PM
That's good. One needs to know how to fill gaps. We also wouldn't want the next generation of model builders to have too easy a time of it and not have a proper appreciation of a well fitting kit!Big Smile [:D]
Posted by Anonymous on Tuesday, December 14, 2004 3:17 PM
to convert a M48 into a M60 would be as hard as converting a Panther into a Kingtiger
they look the same but are totaly different
Posted by Rob Gronovius on Tuesday, December 14, 2004 5:30 PM
Not many? In 1/35 scale?
Tamiya did the M60A1, M60A2, M60A3TTS, USMC M60A1 RISE/Passive.
Academy did the IDF M60A1 with Blazer armor (with and without mine roller), USMC M60A1 RISE/Passive w/M9 dozer
Esci did the IDF M60A1 with Blazer armor, M60A1 RISE/Passive, M60A3TTS
Italeri reissued the Esci M60A1 Blazer, M60A1 RISE/Passive
Revell of Germany reissued the Esci M60A3TTS
AFV Club did the M48H (M48A5 turret on an M60A3 hull)
Trumpeter did the M60A1 and M60A3 (bad copies of Tamiya/Academy ktis)
While the Esci kits are OOP and the original M60A1 is too, the vast majority of the M60 kits are still kicking around on the store shelves and on eBay as well.
Posted by gjek on Tuesday, December 14, 2004 11:48 PM
Buy an early Tamiya M60A1. Pitch out the turret. Buy anTamiya M48 and use the turret. Get some good reference photos and put it together. Send photos!
Msgt USMC Ret M48, M60A1, M1A1
    July 2003
Posted by zokissima on Thursday, December 16, 2004 6:45 AM
QUOTE: Academy did the IDF M60A1 with Blazer armor (with and without mine roller), USMC M60A1 RISE/Passive w/M9 dozer
Surprised to see only one person brought up the the Academy offering. I haven't built any other M60, 'cept the academy offering, and if I may say so, not knowing how accurate it is, it is a kit with very few flaws in terms of building and fit of parts.
Posted by Anonymous on Saturday, August 20, 2005 4:30 AM
M48:
M60:
They are both derived from the Patton series of tanks which started with the M26 at the end of WWII and went through the M60-A3, but are not the same. M60 was a further develop[ment and next generation to the M48. For more info on the M48, M60, and other Patton versions, check here: http://www.patton-mania.com/index.html
That is incorrect. The first M60's had the M48 turret. The prototype was basicly an M48 turret on another chassis. The picture you have is of an M60A3.
Notice the commander copula, its the M19 copula. The M48A5 had the M1 copula and most models didn't have a copula because the M2 was put in a pintle mount. Also the M48A5 had the M68 105mm Rilfe Cannon, same as the M60.
Posted by HeavyArty on Saturday, August 20, 2005 9:32 AM
M48:
M60:
Yes, I know all the above. My point, in this ancient post that has been revived, was that an M48 and an M60 are not the same tank and it would be a major project to make an M60 out of an M48 as someone advised the guy to do in an above post.
QUOTE: The M48A5 had the M1 copula and most models didn't have a copula because the M2 was put in a pintle mount.
Actually, this is incorrect as well. M48A5 had the Israeli designed Urdan Cupola, which is very different than an M1 cupola.
    April 2004
Posted by crockett on Saturday, August 20, 2005 9:38 AM
The M19 cupola did not utilize the M2 .50 weapon, The M60 was equipped with the infamous M 85 .50 cal. a completely different weapon than the M2.
Posted by Rob Gronovius on Saturday, August 20, 2005 9:56 AM
M60:
The picture above is not an M60A3 but an M60A1. Note the lack of the crosswind sensor and the thinner main gun tube indicating the lack of a thermal shroud. Some of the identification points used by old tankers to ID the A1 from A3 like the smoke grenade launchers and top loading air cleaners are no longer valid since the M60A1s in US service were upgraded with these features towards the end of their service use.
The M48A5 did not have an internal machine gun cupola. It used a 7.62mm M60D machine gun in a flex mount. Although some A5s retained the M1 cupola of the M48A3 (a picture of one is in the Squadron Signal book on the M48).
