Dragon's Tiger I late question
    March 2006
Posted by Yann Solo on Monday, June 5, 2006 8:23 AM
I just started to build the Dragon's Tiger I late kit and I have a hard time figuring out how to glue the swing arms for the idler wheels.  When the part is inserted in its socket, it can still swing back and forth but it does not clips so I have to glue it in place but I have no clue in which position to glue it.  I presume I should leave that part aside and glue it only when I'm ready to install the track so it will help to fit both the iddler wheel and the track together.  Am I right?
Also, if any of you who have build this kit has suggestion regarding the painting sequence, please let me know.
Thanks
No matter where you go ....... there you are.
    April 2004
Posted by crockett on Monday, June 5, 2006 1:34 PM
I don't really fully understand your issue, but, as I remember on my kit, the roadarm angle was controlled by the positioning of the working torsion bars. The torsion bars are located by gluing in anchors on the inside of the hull?
As I remember, the torsion bar assembly was a little different that the Initial Tiger.
Steve
    March 2006
Posted by Yann Solo on Monday, June 5, 2006 1:51 PM
Steve
I'm sorry, I'm a french canadian and sometimes I just have a hard time explaining what I have to say.  I have no problem with the torsion bars which fit perfectly.  I'm talking about the last wheel at the back, which is the iddler wheel.  There is no torsion bar for that part and there is a pin inside the hole to limit the rocking action of the swing arm, but that pin is smaller than the groove in the swing arm so once in the hole, that swing arm can partially rotate to have the idler wheel more toward the front or more toward the rear.  Here is a quick made drawing to show what I'm talking about.
Posted by Anonymous on Monday, June 5, 2006 1:58 PM
That is so you can adjust the model in a dio to have slack on the track, or tension, for dio purposes...
If that is what you are asking...
    March 2006
Posted by Yann Solo on Monday, June 5, 2006 2:02 PM
That is the answer I've expected but what is the "normal position" of that arm.  Straight down or all the way to the back?
Posted by Anonymous on Monday, June 5, 2006 2:15 PM
I think it is all the way back, down to me makes it sound as if the put it down to losen the track, back would be to take up the slack...
    April 2004
Posted by crockett on Monday, June 5, 2006 6:23 PM
Oh I understand now. I assembled mine in the 'neutral position, 12 oclock. It seemed to work out perfectly:
regards,
Steve
    March 2006
Posted by Yann Solo on Monday, June 5, 2006 7:29 PM
Wow, this is an excellent build.  Tanks for sharing and thank you for the reply.
    June 2006
Posted by ps1scw on Wednesday, June 15, 2011 2:31 PM
I just glued them at their ends.  Seems to work out ok
    July 2004
Posted by wbill76 on Wednesday, June 15, 2011 3:26 PM
This one rises from the dead almost exactly 5 years later to the day! Pirate
    July 2006
Posted by constructor on Wednesday, June 15, 2011 5:40 PM
Just one comment though. This I got from the guys after posting my Wittman Tiger. They said the antenna on the left side of the tiger's body should not be there. The antennas should be on the turret, which you have  already and the one on the right. I'm not sure if this applies to your Tiger. Nice build. I like the camo work.
    December 2003
Posted by buff on Wednesday, June 15, 2011 8:17 PM
Back from the dead alright.  I was hoping Yann had gotten back to the bench.
On the bench: 1/32 Spit IXc
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Wednesday, June 15, 2011 11:07 PM
buff
http://t3.gstatic.com/images?q=tbn:ANd9GcQUP8VUfdSTocg6GCl3t9cs4CQPTJI0M5LMbM1WWsKPrJXwEdjV Me too.
http://i20.photobucket.com/albums/b232/gluetank/Animated/th_1-Animated-Disastermaster.gif?t=1296616998
 https://i.imgur.com/LjRRaV1.png
Posted by Bish on Thursday, June 16, 2011 5:17 AM
constructor
These command tanks should have two antennas, not three. Dragon gives you three and shows pics with all three fitted, which can confuse things. There were two versions of the Command Tiger. Both had the 2m antenna on the turret. The SdKfz 267, used by Coy and battalion commanders had the star antenna on the right of the hull. The 268, used i think by FAC's had the 1.4m antenna on the left of the hull.
    January 2008
Posted by Byrden on Thursday, June 16, 2011 3:11 PM
The same chassis could be used for both purposes, so you should still have the antenna base on the left side.
David
