How to: Rusty/weather effect for Panzer 4 muffler
    January 2006
Posted by Howitzer on Saturday, October 20, 2007 10:30 AM
Help. Confused [%-)]Anybody out there know how to do a realisic rusty/weather effect on a Panzer 4 muffler.  I don't want the end result to be an overdone brick red color, but rather a suttle effect.  I need to know what the base color should be, followed by ?????
    July 2004
Posted by wbill76 on Saturday, October 20, 2007 11:26 AM
There are many different ways depending on what type of paints you use to get this effect. I'll describe mine but there's no real "one true way" to do it. I paint the mufflers in a basecoat of Testor's Model Master Non-buffing Metalizer Gunmetal (you should see them try to print THAT on the bottle label Wink [;)] ), then apply a thin wash (90% thinner, 10% paint) of MM enamel Rust and let it dry. Then follow that with a dry-brushing of MM enamel Burnt Umber to deepen the tone and voila! rusted muffler.
While not a Pz IV, this will give you an idea of the effect it produces:
Then with weathering and final finish attention...it looks like this:
    January 2007
Posted by the doog on Saturday, October 20, 2007 1:25 PM
I give mine a base coat of any acrylic dark brown, then I wash it with a fairly thick mix of orange/raw sienna/raw umber oils, and dab some of it off with tissue after about a minute or two...I let that dry, and then give it a straight wash of thinner, and while that is wet I shave rust-colored pastel sticks onto the surface for additional color and texture.
    May 2005
Posted by terry35 on Sunday, October 21, 2007 11:51 AM
I'm presently working on a Mk.IV chassis and had to do the exhaust, The vehicle I'm building is old so the exhaust is quite worn.
 I done it as so:
  1. Textured the unit with liquid cement.
  2. lightly sanded.
  3. Based with browns and flesh, randomly applied.
  4. painted in the scratched/burned remains of the base colour.
  5. washed out with burnt sienna/raw umber.
Added mig pigment rust to a very thin mix of the wash and applied liberally, I still haave a lot of work to do, but I hope these shots of the W.I.P help.
Regards,
Terry.
    October 2004
Posted by jthurston on Tuesday, October 23, 2007 6:43 AM
I do this:
1. Paint the muffler in Model master "Rust" or something similar
2. Grind a little of the reddish-brown pastel stick (from a pack of artists' pastels, earth-tones) onto your pallette (or whatever you use).
3. Mix in a little Rustall, or something similar
4. Apply this mixture to the muffler, as a wash
 Hope that helps
    November 2006
Posted by dupes on Tuesday, October 23, 2007 10:44 AM
Hmmm. Sort of an add-on question here. How long did it take for the muffler to get all rusty? I'm assuming that they didn't roll out of the factory already corroding. What's the actual "base color"? If you're doing a relatively new vehicle, what would it look like?
I only ask because I'm painting my Hornisse...which was only a month or two old by the time it got to Kursk.
    July 2006
Posted by mg42gunner on Tuesday, October 23, 2007 2:03 PM
I use tamiya weathering sets for my rust, but the effect should work with any pastels. I grind up some of the rust colored pastel, and then add differnt ammounts of water to the pastels, This produces differnt shades of rust. To get more texture, I only wet the paintbrush I am using, then dip it into the pastel powder. Here are some examples of my rust:
    January 2007
Posted by dahut on Tuesday, October 23, 2007 2:16 PM
Pastels work great and are a great way to do this.
Another "oldschool" trick for the larger scales is to paint the part a rust color and then while still wet, cover it in fine powder like scrubbing cleanser. How wet and much powder you want to stick depends on how old and rusty you want the muffler to be. Then repaint it to cover the powder and you get a nice grainy texture represnting a scroungy, rusted up muffler.
Cheers, David
    January 2007
Posted by the doog on Tuesday, October 23, 2007 2:55 PM
Gotta vehemently disagree with ya here, dahut; DO NOT cover ANY model part with ANY " SCRUBBING CLEANSER-type" chemically active powder, or get ready for somewhere down the road a catastrophe in your finish when the chemcals leach out into the paint and start to eat it or attack it; see the poat on "baking-soda snow" recently...
    August 2006
Posted by K-dawg on Tuesday, October 23, 2007 3:02 PM
I would assume they were painted with the rest of the tank but remember some German tanks had the sheilds over the exhaust pipes because they glowed from being so hot. At that temp the paint wouldn't last but a VERY short while and then they'd start rusting...
Kenneth Childres, Central Arkansas Scale Modelers
    January 2007
Posted by dahut on Tuesday, October 23, 2007 4:34 PM
Gotta vehemently disagree with ya here, dahut; DO NOT cover ANY model part with ANY " SCRUBBING CLEANSER-type" chemically active powder, or get ready for somewhere down the road a catastrophe in your finish when the chemcals leach out into the paint and start to eat it or attack it...
Like I said, it's oldschool and may have been baking soda, I dont recall anymore. I see your point and it IS a good one - I dont remember if any of the models I tried this on ever melted down into a toxic heap as you suggest they might. They never lasted through kids, moves and/or being blown up with firecrackers.
Probably best to try something else. Was just the only thing I could think of. Smile,Wink, & Grin [swg]
Cheers, David
