WIP - Panther G Project ***Now Complete***
    March 2006
Posted by marevic1 on Thursday, December 27, 2007 1:30 AM
Hi all.
here's the current project I'm working on. Still a long way go, but it's getting there.
The base kit I'm using is Dragon's Panther G with Steel Road wheels Smart kit.
The P/E set is from Voyager.
cheers,
Jurgen
    November 2006
Posted by dupes on Thursday, December 27, 2007 11:24 AM
Dang. That is one serious set of PE! Shock [:O]
Nice work on it, too. Thumbs Up [tup]
Aren't the "smart" kits supposed to eliminate a lot of PE work...? Whistling [:-^]
    August 2007
Posted by 9 Toe Tanker on Thursday, December 27, 2007 4:54 PM
Looks great man! ....looking forward to seeing this done!
Best Regards Joe
Posted by tigerman on Thursday, December 27, 2007 6:03 PM
That's a big chunk of heavy metal! incredible detail on that stuff.
 Eric
    April 2007
Posted by SMJmodeler on Thursday, December 27, 2007 7:55 PM
marevic1,
Enough brass there to make a pair of knuckles!  Nice and clean too!...I have a Tamiya Panther G Late on my shelf, I'll be keeping an eye out for more of your progress photos...Thumbs Up [tup]
What's your painting scheme going to be?
    March 2006
Posted by marevic1 on Friday, December 28, 2007 12:17 AM
Thanks guys.
SMJmodeler - I going for the 3 tone scheme with a disc pattern.
The R01 vehicle from the HG div.
Jurgen.
    April 2014
Posted by Carves on Friday, December 28, 2007 7:53 AM
Nice !
Lots of PE stuff. Looks like you are going all the way "accurate" and full details.
Just dont forget to add the wire that connect to the headlight to the superstructure.
Ben
    July 2003
Posted by zokissima on Friday, December 28, 2007 9:49 AM
Looks great. Some fantastic P/E work.
    April 2004
Posted by crockett on Saturday, December 29, 2007 7:45 AM
Nice work on the PE. I see that you have dry fitted the cupola. You may already know about the fit up issue here with these "new" Panther kits. I'm talking about the inherent gap. There are some tutorials out there which show how to correct it. I simply enlarged the opening to settle the cupola down on my A build.
regards,
Steve
    March 2006
Posted by marevic1 on Saturday, December 29, 2007 5:50 PM
Thanks Gents.
Thanks for the tip Steve. Honestly wasn't aware of that one.
Cheers,
Jurgen.
    March 2006
Posted by marevic1 on Thursday, June 12, 2008 4:26 AM
Hi all.
Thought I'd post a couple pics of the finished vehicle.
The paint scheme is from the HG Divisions R01, with it's distinctive disc camo on the side skirts.
Hope you like it.
cheers,
Jurgen.
    August 2005
Posted by Phil_H on Thursday, June 12, 2008 5:09 AM
Love the paint job Jurgen.The subtle streaking looks just about right to me. It almost looks like you could climb aboard and drive away.. Thumbs Up [tup]
Posted by Bish on Thursday, June 12, 2008 6:02 AM
Thats one nice Panther you have there. I have seen the disk scheme on a StuG before but not a Panther.
    November 2006
Posted by dupes on Thursday, June 12, 2008 6:14 AM
Wow, man. Great finish! That disc scheme is very cool, and the weathering looks great. Thumbs Up [tup]Thumbs Up [tup]
Figs in the last pic also get the thumbs up. Wink [;)]
    April 2005
Posted by wing_nut on Thursday, June 12, 2008 6:37 AM
That is a beautiful piece of work there.  Finish and weathering are great.
Marc
    May 2006
Posted by panzer88 on Thursday, June 12, 2008 7:22 AM
Beautiful panther!!!!The paint job and weathering are awesome!!! How did you achieve the disc pattern camo? Again, a superb build.
    April 2004
Posted by crockett on Thursday, June 12, 2008 7:30 AM
Great job here. You've really captured those details and replicating the disc cammo is just awe inspiring. Just a nit pick, the star antenna should be recessed in the tub. This is the same error I made on my Befehls D model, and it was pointed out to me over on missing lynx. It is easily fixed ......what a beautiful job congratulations. I really like the touch you made, showing the wear marks from the hull spare track block stowage and the rust stains...pretty cool, I might have to steal that from you on my next build!
regards,
Steve
    April 2004
Posted by crockett on Thursday, June 12, 2008 7:33 AM
This is a well documented vehicle, photographs of the distinct disc pattern on the skirts are clearly visible. Just google "Panther Tank" and you'll run across the pics.
Posted by Anonymous on Thursday, June 12, 2008 7:38 AM
Very, VERY nice...what is that emblem on the hull front?
    March 2006
Posted by marevic1 on Thursday, June 12, 2008 7:47 AM
Many thanks for the comments guys!!
panzer88 - the disc pattern was drawn onto a piece of thick graphic tracing paper.
               The outer edges were cut out, leaving the discs slightly touching each other.
               I then painted the side skirts in the tri colour camo scheme. Once dry, I placed the
               stencil over each side skirt and sprayed it dark yellow.
                If you're interested, I've blogged the build.
                http://www.militarymodelling.com/forum/forummessages.asp?dt=&UTN=3820&last=1&V=6&SP=
Manstein's revenge - that's the emblem for the Herman Goering Panzer Div.
Crockett - Cheers buddy. I honestly didn't know that. Thanks for the heads up.
cheers,
Jurgen.
    January 2007
Posted by the doog on Thursday, June 12, 2008 8:02 AM
Jurgen, this is one fabulous build! Perfect paint, weathering, and some impressive work on that PE!
A very impressive Panther! Make a Toast [#toast]
    March 2006
Posted by marevic1 on Thursday, June 12, 2008 8:58 AM
Cheers doog. It was defintely a build of many firsts for me. Took me a while, but am pretty happy with how she turned out.
Jurgen.
Posted by tigerman on Thursday, June 12, 2008 1:24 PM
Man, that is just beautiful. I really like the weathering with the streaks and such. Also the disc-pattern is rare and gives a nice to touch to the tri-camo. My one observation of the pattern from what I've seen, is that the discs touch more or even overlap, thus giving the unique bow-tie look to it. Just my observations, your refs might be different. Well done Jurgen.
 Eric
    January 2008
Posted by Bodge on Thursday, June 12, 2008 1:28 PM
Awsome i love it , the build and the painting are A1Thumbs Up [tup]
Posted by Anonymous on Thursday, June 12, 2008 3:12 PM
cheers,
Jurgen.
I have an excellent article in an Armour Modelling magazine that shows how to replicate this--just the same way you did...this whole disc-scheme idea was discussed at some length about a year ago...this is one of the pics I still have from that thread that shows the tank you modelled:
The round overlays were photoshopped in to show the "discs" in the pattern...one of the ideas that was debated was that the disc scheme and the ambush scheme were really one in the same...
    July 2003
  • From: On my kitchen counter top somewhere in North Carolina.
Posted by disastermaster on Thursday, June 12, 2008 3:39 PM
That is just beautiful! Done up "just right!"
The image “http://upload.democraticunderground.com/discuss/images/avatars/ivoted.gif” cannot be displayed, because it contains errors.
You have my vote of approval!
Disastermaster
 https://i.imgur.com/LjRRaV1.png
    April 2007
Posted by SMJmodeler on Thursday, June 12, 2008 3:56 PM
marevic: We both finished our Panthers on the same dayMake a Toast [#toast]...both G's too...that's got to be a first.  I really like the paint scheme on this one...very unique.  The tools and all the extra details look fantastic!  Just the right amount of wear on the turret and I like the streaks on the front of the hull.  Nicely doneThumbs Up [tup]Thumbs Up [tup]...congrats..what's next on your workbench?
    November 2007
Posted by moose421 on Thursday, June 12, 2008 5:14 PM
Nice work!  I love the wear marks on the hull sides where the spare tracks are missing.  Get job on the disc pattern camo as well.  I'll save those pics for my reference.  Always great to learn new techniques.
keep up the great work!!
    July 2006
Posted by Douglas1 on Friday, June 13, 2008 12:40 AM
Thats an awesome Panther! Very impresive Job from beginning to end.Bow [bow] I've been obsessing about panthers here lately, I have a Jagdpather late built except for a few details and paint and finish and am drooling over a DML Panther A late, premium that I just got. I'd like to hit you up for advice when I start. What did you use for references if I may ask? I just ordered P. Jentz's Panther book that was recommended to me.
Thanks for sharing! Doug
Tamiya Jagdpanther 1/35 on the bench 80%
    March 2006
Posted by marevic1 on Friday, June 13, 2008 8:44 AM
Thanks heaps boys!!! I really appreciate the comments.
Steve - Next build is a March '45 Wegmann King Tiger.
           I'm actually a fair way through it at the moment and have got most of the paint work
           done. Hopefully it'll be done soon (fingers crossed).
Doug - I've got both the premium A and D waiting as well. They really are nice kits aren't they.
          I'm no expert on Panthers, but would be glad to help where I can.
          As for references, the Jentz book is great. I found the Trojca Tank Power series on the
          Panther an excellent reference as well. It's an 8 volume series that covers all Panther
          versions. Highly recommended.
cheers,
Jurgen.
