M32B2 Tank Recovery Vehicle
    May 2008
Posted by LO51 MERC on Sunday, May 11, 2008 2:19 PM
This is a conversion of the Italeri M32B1 Tank Recovery Vehicle to an M32B2 TRV. The lower hull, tracks, turret and all the related recovery equipment are from the Iatleri kit. The upper hull is an MP Authen-I-Kit M4. The paint used is Testors ModelMaster.   Gary
Well, I built the B-52. Now what am I gonna do with all my free time
Posted by T26E4 on Sunday, May 11, 2008 2:42 PM
Looks cool.  One thing to note however, the M32B2 is based on an M4A2.  The M4 hull that you have would make your model an M32.  HTH
Roy Chow
Join AMPS!
http://www.amps-armor.org
    January 2007
Posted by the doog on Sunday, May 11, 2008 3:24 PM
Good man, Gary!  Smile,Wink, & Grin [swg]
Can I ask, what's the difference between the Authenti-kit and the Italeri hull? How does it change the model?
Posted by T26E4 on Sunday, May 11, 2008 4:58 PM
The M4 was a welded hull vs. the M4A1s which were cast hulls.
the Authentic kit by MP Models allowed you to build an M4 or early M4A3 Ford.  It was a conversion for the Tamiya M4A3 kit or Italeri M4A1 -- this was before the Tamiya M4 Early Prod kit was made.
The problem with the base Italeri M32 kit is that it sought to depict an M32B1 using the hull from their M4A1 76W kit.  The issue is that all photographed M32B1s are made with the small hatch M4A1 hull (such as the new Tasca  M4A1 hull or the older DML 6048 kit).  I'm not aware of any extant photos that use the combination that Italeri offered.
By using the Authenti kit M4, Gary makes the M32 in a correct configuration.  (one could also use the M32 parts and place them directly onto the Tamiya M4 kit).  There were also M32B2s and M32B3s (using the M4A2 and M4A3 respectively)
HTH
Roy Chow
Join AMPS!
    May 2008
Posted by LO51 MERC on Sunday, May 11, 2008 8:16 PM
Thank you HTH! I mis-read the Info in Hunnicut's book thinking (for some stupid reason) that there were only 2 versions of the M32's. I re-read the section in the book and will change my records to show the correct information.  Gary
