Rubber (or something like it) wheels
    April 2008
Posted by smeagol the vile on Tuesday, November 18, 2008 6:59 PM
Im working on that mini, for my friend for christmas.  Im looking at the wheels for the kit, there not plastic.  How should I go about painting them, should I paint them?  Can a auto newb get some help?
    January 2008
Posted by acmodeler01 on Wednesday, November 19, 2008 7:01 AM
Wheels are regular plastic, they can be painted like anything else. The tires are a synthetic rubber and should not be painted.
    March 2008
Posted by EasyMike on Wednesday, November 19, 2008 7:28 AM
 smeagol the vile wrote:
...Im looking at the wheels for the kit, there not plastic...
If the wheels are not plastic, what are they?  Knowing what they are made of will determine what to paint them with.
    April 2008
Posted by smeagol the vile on Wednesday, November 19, 2008 7:54 AM
guys, you know im not a car guy.  To me the wheel is that spinnie thing that makes it go.  Ok, no need to tease.  I meant the tire.
    January 2008
Posted by acmodeler01 on Wednesday, November 19, 2008 8:03 AM
If you need to paint the raised letters, use an acrylic water-based paint. I use a small amount applied with the side of an eraser. You know the long adjustable erasers? Take about a half inch of one of those, roll it in a little paint, then roll the eraser on top of the letters, it will leave only a little paint on the letters where the eraser contacted them, with no mess that you would get with a paint brush.
    April 2008
Posted by smeagol the vile on Wednesday, November 19, 2008 9:30 AM
Thanks.
    January 2007
Posted by the doog on Wednesday, November 19, 2008 12:26 PM
Steve--IMPORTANT!!!
If you mount the rubber or vinyl wheels onto theirplastic rims, I think you have to paint the rims INSIDE, where the rubber/vinyl will be touching them. There's some weird chemical reaction that can take place over the years with the styrene/runner/vinyl that will eventually literally melt the tires!
I read about it on this forum, I believe, or another one that I can't remember exactly whwere?
    October 2007
Posted by Summit on Wednesday, November 19, 2008 12:41 PM
 the doog wrote:
Steve--IMPORTANT!!!
Really ? I would think that the paint would cause the reaction for meltdown. I know that if you attempt to paint red lines, sidewalls or raised lettering directly on the tire with enamel paint the stuff will stay tacky for the rest of your life.Yuck [yuck]
I have some really old globby brush enamel (1970's vintage)  painted wheels, and unpainted with tires mounted in the junk box,(most glued with Testors Tube glue)  nothing going into Nuclear Meltdown yet. I wonder if the "rubber" compound has been changed in the last 10 yrs or so ?
Sean "I've reached nearly fifty years of age with my system." Weekend GB 2008
    January 2008
Posted by acmodeler01 on Wednesday, November 19, 2008 1:24 PM
Doog's right, but I think it applies to the vynil (sp?) tires only. I've only heard of it happening with american (i.e non-japanese) kit mfrs. Tamiya (who makes smeagol's kit) uses a softer rubber that seems to be less reactive (if at all).
    October 2008
Posted by eatthis on Wednesday, November 19, 2008 1:43 PM
the spinny thing that makes it go is the engine
sorry il get me coat
snow + 4wd + escessive hp = :)  http://www.youtube.com/watch?v=x7egUIS70YM
    April 2008
Posted by smeagol the vile on Wednesday, November 19, 2008 5:44 PM
So you mean paint the inside of the tire, or paint the ENTIRE wheel?
    January 2007
Posted by the doog on Thursday, November 20, 2008 11:41 AM
NO, NO!
Paint the plastic parts that will be IN CONTACT WITH the rubber/vinyl part of the tire!
Just to be safe.....
    June 2003
Posted by Silverback on Thursday, November 20, 2008 2:19 PM
Most "rubber" tires are actually some sort of vinyl, and all vinyl compounds contain copolymers (the chemical compound that that give the vinyl flexibility).  If the vinyl is placed in contact with polystyrene, some types of copolymers can migrate, causing degredation of the styrene.  The worst offender in recent memory was the flexible tires in the AMT F7F Tigercat kit.  Fortunately, few model car kits are blessed (or cursed) with these types of vinyl products.  I have built-up kits nearing 50 years old that do not exhibit melted wheels, while a fairly recent kit (Monogram Gambler dirt-track car, unbuilt) has a huge honking tire burn affecting several of the parts.  Real rubber and synthetic rubber tires deteriorate, but do not seriously affect the plastic.
If the part has a pungent "vinyl wading pool" smell, or if it feels slightly sticky to the touch, its probably of the styrene-devouring variety, and should be replaced.  As insurance, I've started dipping the tires in Future (now called Pledge with Future Shine, BTW).  Future was originally made for vinyl flooring, and coats vinyl tires quite nicely.  Future also takes paint a lot better than the raw vinyl, although I still can't recommend excessive flexing.
If you want to be obscessive, (say, a unique tire type/size/style for which there is no replacement) plate any areas of the wheel that may contact vinyl with Bare Metal Foil, which will form an effective barrier to copolymer migration.
Just my .02€
Phil
    January 2007
Posted by the doog on Friday, November 21, 2008 4:23 PM
Just my .02€
Phil
Thanks, Phil!!
That was exactly what I was talking about!!! (But didn't know the specifics!)
    April 2008
Posted by smeagol the vile on Friday, November 21, 2008 9:26 PM
so wrap some tinfoil around the wheel and put the tire over it and it will be fine?
    October 2007
Posted by Summit on Friday, November 21, 2008 10:08 PM
Bare Metal Foil is ultra thin foil with an adhesive backing. It is used for like covering the trim down the center of the hood or down the side of car and ect. You can find it at most hobby shops.  Next time your out and about buy an Issue of Scale Auto just for something different, and check out all the wonderful stuff out there for autos.
