AMT Trailer question.
    February 2006
Posted by Wilbur Wright on Wednesday, November 11, 2009 3:00 PM
AMT have just released or re-released two trailers. One is for hauling logs, and the other is a flatbed to haul rolls of steel. The logs and rolls of steel are apparently in the kits.
Does anyone know if these logs and steel rolls are made out of styrene like the rest of the kit.... or are they cardboard or something?
Thanks
    January 2007
Posted by the doog on Wednesday, November 11, 2009 5:25 PM
Cardboard?!
I couldn't imagine?
I would suspect that with today's advanced modeling molding, they would be of styrene, or at least wooden dowels?
    May 2009
Posted by Brizio on Wednesday, November 11, 2009 5:26 PM
I would guess plastic. And probably empty inside.
Posted by autocar1953 on Wednesday, November 11, 2009 7:30 PM
log trailer has two styrene logs, and a plastic girder
flat bed has two steel coils made of plastic
the steel coils look more like a spraycan top with a lid....
500 started, none finished....
James
    February 2006
Posted by Wilbur Wright on Wednesday, November 11, 2009 9:05 PM
Thanks for the answer............modern molding is not present in many AMT kits, particularly re- issued ones. As I suspected the steel rolls are probably unusable.
Speaking of bad moldings on kits still being injected.......I paid $65 dollars for the Glencoe SS US........it looks like a ten year old molded it in his oven....its that bad.
Posted by autocar1953 on Thursday, November 12, 2009 8:27 AM
If you are really good with an airbrush, and weathering techniques, you can make the logs look like wooden dowels from the hardware store.....
I have seen the steel coils done up very nicely.. Again.. proper paint, some rust, weathering,awooden pallet and cribbing, meatal banding to holdit in place....
If your painting skills are less than you would like.. you could paint the coil grey, make up the pallet and stuff, and cover it with a Kleenex tarp...alot of steel haulers do this..
Jim A.
James
    August 2008
Posted by tankerbuilder on Monday, November 30, 2009 5:24 PM
 HEY, wilbur; you could use wooded dowels as logs.Just take a wire brush(COARSE) in a drill and rough up the surface then stain and paint.The roll of steel(or rolls) can be made by using very large baking pans(the cheap aluminum kind)cut intostrips join strips and coil up and fasten down.The kits ,when I bought them years ago had plastic logs, beam and coil.   tankerbuilder
