help removing paint
    May 2003
help removing paint
Posted by Robert92562 on Monday, January 12, 2004 6:36 PM
I would like to remove the paint from a Tamiya porsche that i painted yellow. what should i use?
Posted by Anonymous on Monday, January 12, 2004 6:48 PM
I usually use Easy-Off oven cleaner and an old toothbrush.
Maker sure that you wear rubber gloves and perhaps a set of safety glasses would'n hurt either.
Spray the car and let it sit for a while and then scrub it with the toothbrush.
I usually use an old pan of some sort that the car can sit in entirely.
Hope that this helps.
Ray
    September 2003
Posted by nicholma on Monday, January 12, 2004 8:59 PM
A couple of suggestions: go to http://www.bonediggers.com/1-3/strip/strip.html where a detailed comparison with all the pros and cons of different methods are listed based on actual trials. Also find the posting "How to strip old paint" posted December 12th (about page 5 of this forum I think) where there are again a heap of suggestions.
Kia ora, Mark "Time flies like the wind, fruit flies like bananas"
Posted by Anonymous on Saturday, January 31, 2004 3:31 PM
soak it in brake fluid and then use a old tooth brush.Then soak it in mild dish washing soap to clean it.
Posted by orvallin on Friday, February 13, 2004 9:16 PM
Use Simple Green it works well and isn't caustic so you don't need rubber gloves or a respirator.
Orval Lindsey(Mesa Modeler)
