First Car Model Questions
    October 2004
Posted by jschlechty on Friday, January 6, 2012 12:49 PM
Believe it or not, I've never built a car model. (I usually do WWII aircraft like normal people Wink  ) I am building a 2010 Dodge Challenger for a friend.  THe build itself wasn't a problem, but I have a couple of finish questions:
1) Do y'all dip the windshields in Future like we do the aircraft canopies?
2) How long do you wait after an enamel "dust coat" to smooth and polish it before the heavier coats?
3) after the heavier wet coat, do you polish some more, or just apply a gloss coat?
Thanks for the info - and lets keep my visit to this forum a secret from the aircraft guys, ok?
Thaks, John
Posted by Don Stauffer on Saturday, January 7, 2012 9:39 AM
1)  depends on the state of the transparency.  Fewer model car folks dip transparencies unless there are a lot of scratches or blemishes.
2).  I wait at least two full days- 48 hours.  You can sort of tell by feeling it.
3)  Depends on how smooth the finish is at that point. If it is dust free and smooth, just gloss coat it. If it has dust spots or any trace of orange peel, sand with 600 or 1000.  That will dull it down but the glosscoat will remove any of that fog from the sanding.
    January 2007
Posted by the doog on Saturday, January 7, 2012 12:07 PM
To be honest, if you're going to build a car model, I would tell you to ditch the idea of using enamels to paint it.
I used to use enamels and to be blunt, they're smelly, slow-drying, problematic paints for car modeling. You really can't put a finger on drying time because SO many factors play into when the paint might be dry. Most good finishers will tell you that you should wait a couple of weeks, not days, to polish out a good coat. And the general rule is, if it still smells like "paint", it ain't dry. This is because the "gassing out" process of curing is still happening. Ugh. That can take forever.
The best advice I can give you is to use a good primer and go with lacquers. And WEAR A MASK! Yes, lacquers are smelly too, but they cure hard in a less than 24 hours, and polish out beautifully, and can stand more polishing abuse than enamels.
    October 2004
Posted by jschlechty on Saturday, January 7, 2012 12:15 PM
Thanks Don!  That info helps a lot.  As far as the "2 full days" and "you can tell by touching it", do you mean when it is no longer 'sticky"? (I usually use acrylics).  It was dry to the touch after just a few hours, but still had a heavy "paint smell".  IIRC, I once read that enamels are fry or cured when they no longer smell like paint  - have youu heard or read the same thing?
THanks again for your help!
JOhn
    October 2004
Posted by jschlechty on Saturday, January 7, 2012 1:26 PM
Doog - I guess we were writing at the same time.  Thanks for the advice - I wish I had read it before I had already painted the car with enamels.  At this point I'm going to go ahead and finish it out with enamels, but will keep your advice in mind if I'm asked to do another one.
BTW - what company makes the lacquer paints? Seems like all I see in the paint sections at the LHS are enamels and acrylics.
Thanks again,
John
    January 2007
Posted by the doog on Saturday, January 7, 2012 2:31 PM
Jon,
Testor's makes a "Custom Lacquers" spray can. They spray really nicely, but if you want what I consider to be "the Ultimate", go to Model Car World. He makes his paints from actual company chips, and whats more--he grinds the metal chips in the metallic colors "to scale". His paints come pre-thinned for airbrush, and though a tad expensive, they're none better that I've found.
