Italeri 1:12 FIAT Mefistofele
    March 2015
Posted by NickD on Saturday, June 6, 2015 2:22 PM
A quick question. For a while I've felt the main body moulding, impressive though it is, is a bit to smooth and clinical. What I want to do is skin the middle section of the body in thin plastic card. It's a slightly compound curve so getting things to sit nicely is a bit scary. I've started to make the pattern in masking tape. So the question is, has anyone else succeeded in doing this?
MJH
    April 2005
Posted by MJH on Sunday, June 7, 2015 12:09 AM
To be honest Nick, I don't really follow why you think it's necessary but I'll be interested to see how it turns out.  I certainly haven't done anything similar in the past. I have considered adding a reinforcing framework in the manner of Kurtl's build but no more than that.
    March 2015
Posted by NickD on Monday, June 8, 2015 3:44 PM
Why is certainly a good question. Partly it is that I thought it would be more convincing if the body appears to be made of separate bits. Partly it was to see if I could do it. I therefore decided to make a template. Cut out the shape and see if it worked. It did so, rightly or wrongly I decided to do it. Like any plastic surgery, it does not look good straight after the operation. Picture is below. Clearly I did not get the shape quite right, though it is on the large size. The critical bit though is the shoulders, where I needed put some cuts to remove material. The fit was quite good, but as usual I used to much glue to so the surface is currently a bit rough. Hopefully it will tidy up OK.
While I'm on, for completeness, the picture below is the front of the firewall. I deliberately made it darker to represent the sorching.
    June 2015
Posted by Jnkm13 on Monday, June 8, 2015 8:36 PM
Hi, guys. I am new here. Building the same kit myself. Great work you have done here Nick, loved the wooden effect. I'll try to post some pictures of my progress.
I do not have much skills in painting wooden effects, so have replaced most wooden parts with real wood or wood veneers.
Gotten to the decalling part.
    March 2015
Posted by NickD on Wednesday, June 10, 2015 1:01 PM
Jnkm13. Thanks for the comments. As I said in an earlier post, the wood technique is surprisingly easy with the right materials. Worth a try sometime.
Sounds like you've got to a bit I am a bit worried about. namely a nice shiny gloss paint finish. Let us know how it goes.
    June 2015
Posted by Jnkm13 on Wednesday, June 10, 2015 7:39 PM
Hi NickD. The actual car is nowhere near glossy. So that's a problem. It's actually quite rough in texture from the pictures i have seen.
The problem i am facing is with the thickness of the decals. If you go through Kurtl's progress, you will notice that he too has trouble blending in the "mefistofele" decals. He airbrushed the "FIAT" instead of using decals. What i did was to cut out each of the FIAT letters and also the "XD-711" and put them on separately.
I am now into my 2nd gloss coat. I think it will need another 2 or 3 wet gloss coats before polishing to get rid of the the decal edge on "Mefistofele" then i will finish off with a semi gloss coat.
The biggest weakness of this kit is the chain. There is no way to really get it right. I wonder if the motorcycle chains by Tamiya or 1/12 after market chains work. It's a pity for such a gorgeous kit to be let down by the chains.
Jeremy.
    March 2015
Posted by NickD on Friday, June 12, 2015 3:14 PM
Hi Jeremy
You've just described the processes that scare me most. I have models that it's taken weeks of spraying and sanding trying to get a smooth gloss coat. Rubbing down the gloss between coats to remove the ridge on decals is something I have seen mention of before but never had the nerve to do. So thanks for the warning. Looks like that's my next challenge, once I have rivetted all the panels on that is. Did you spot that Kurtl, as well as detailing the bonnet panels also adjusted their fit significantly..
Nick
    June 2015
Posted by Jnkm13 on Saturday, June 13, 2015 1:09 AM
Hi Nick,
Here are some photos of my progress.
Last night, i sanded the 2nd layer of wet coat where the "mefistofele" decals are to try to blend the edges. Partial sanding and laid on another wetcoat. Will lay on another wet coat tonight and sand again tomorrow. I leave at least 24 hours for the wet coat to dry before sanding.
As you can see from the above photo, the decal edges are still there.
Jeremy
    June 2015
Posted by Jnkm13 on Saturday, June 13, 2015 7:46 AM
Hi Nick,
I had the main body 'shell' slightly elongated as well. If not, there was a slight gap between the bonnet panels and the main body. Way easier slightly elongating the panel than the 2 bonnet pieces.
I also added the strengthening pieces underneath the 2 bonnet panels as what Kurt did, as well as adding additional details to the inside of the main body as what he did.
Jeremy
    October 2006
Posted by kenjitak on Sunday, June 14, 2015 4:45 PM
Sorry I haven't posted any progress pics but I decided to try to get this done for a contest, the COMMIES Fest IPMS Region 10 Regional held in here Denver. So here are a bunch of finished photos,; I finished in time and am quite happy with it. Evidently the judges agreed as it won a First place in Competition Vehicles category. Even though all the photos showed a somewhat beat, weathered car I kept it shiny and new; it must have been that way at some point! Various issues, such as tubing being too small, fiddly assembly order, holes for some of the screws too small, slowed down my work but it all came together. Hope you like it!
Ken
    March 2015
Posted by NickD on Monday, June 15, 2015 2:42 PM
Jeremy/Ken
Ok, really jealous now! I am soooo slow. Both look great particularly the gloss. Not sure I have ever managed to get it so neat. If you don't mind me asking what red's did you use?
And well done Ken on the prize too.
Better go and plod on!
Nick
    October 2006
Posted by kenjitak on Monday, June 15, 2015 3:41 PM
Thanks everyone! The paint is Tamiya TS-85 Bright Mica Red that I decanted and sprayed thru my airbrush.
Ken
    June 2015
Posted by Jnkm13 on Monday, June 15, 2015 7:33 PM
Nice finish Ken. I hope to get to your stage, but really being put off by the chains supplied in the kit. I see that you have done an excellent job of blending in the thick decals.
Nick,
The color I used was Mr. Color 158 Super Italian Red, over a white base. I will be finishing off with a semi gloss layer as i prefer a less glossy finish compared it its current state.
Jeremy
MJH
    April 2005
Posted by MJH on Tuesday, June 16, 2015 9:10 AM
Hi folks;
Some really impressive work going on here!  I don't aspire to the level of workmanship displayed  here but at least it's given me something to aim for...
Ken; What were you referring to when you said the hoses were too small and, while on the subject, what have you used for hose clamps?
Michael
    October 2006
Posted by kenjitak on Tuesday, June 16, 2015 6:27 PM
The gray hose was too small in diameter; also the clear hose for the spark plug wires was too small. I got some 1/12 scale photo etch clamps.
Ken
    March 2015
Posted by NickD on Sunday, June 28, 2015 3:34 PM
Chaps,
Could anyone help me with a tip for how to bend the curved plastic that lines the body cutout that goes over the rear chassis tube. I've tried a couple of things with semi-circular rod but could not make the bend tight enough. Either the rod broke, or twisted or it did not hold the shape.
    August 2007
Posted by DUSTER on Sunday, June 28, 2015 7:42 PM
 If you are using plastic; putting the piece in hot water should soften it enough to conform to your shape--might have to repeat a few times to get to the final desired result
Steve
    June 2015
Posted by Jnkm13 on Sunday, June 28, 2015 7:53 PM
Hi Nick. I used the half rods by the Japanese brand Wave. This was the first time I used this brand and found the rods to be extremely flexible, able to do 90 degrees bends without snapping. I also formed the U shape by bending the half rod over a rod of the correct diameter rather than forming it on the body itself.
Or as what Steve said, soaking in hot water and coaxing them into shape will also work.
Hope it works out for you.
Jeremy
    March 2015
Posted by NickD on Monday, June 29, 2015 2:49 PM
Chaps,
Thanks for the help. I had tried hot water but bottled out. More tenacity is clearly required.
Oh and thanks for the tips on the red too.
Nick
    June 2015
Posted by Jnkm13 on Wednesday, July 8, 2015 9:57 PM
I'm almost done with this kit. Just can't get over the fact how poor the chains will look on the finished model.
Do you guys have any idea on whether the 1/12 after market PE motorcycle chains will work on this kit? What about miniature roller chains?
Jeremy
    October 2006
Posted by kenjitak on Thursday, July 9, 2015 1:05 PM
Using a hot tool to flatten the ends of attachment points is something I haven't seen in a kit since the 50's or so. My dad had to help with a heated pocket knife blade when it was time to attach wheels to landing gear axles!
I gave the finished chain a light once-over with a fine file to try to flatten the chain axles and knock of the stretched sprue bits.
Ken
    June 2015
Posted by Jnkm13 on Monday, July 20, 2015 7:08 AM
Hi guys,
Finally done with this kit after approximately 6 months. Here are some pics. C&C welcome. The seat was scratch built, just from reference photos.
Jeremy
    October 2006
Posted by kenjitak on Tuesday, July 21, 2015 6:02 PM
Nice job! I like the detail on the seat!
Ken
Ken
MJH
    April 2005
Posted by MJH on Tuesday, July 21, 2015 8:01 PM
Great work Jeremy!  Looking forward to getting back to mine when the weather warms up - I have to spray outside and it's been freezing here lately.
Like the rivet work.
Posted by Don Stauffer on Wednesday, July 22, 2015 8:32 AM
It looks beautiful!  I have long wanted to model that beast.  Hope I can find the kit sometime.
    March 2015
Posted by NickD on Thursday, July 23, 2015 3:33 PM
Jeremy,
That looks great. Something for me to aspire to. We'll see how far I get. One thing to add to the to do list is the bulkhead behind the seat. Hadn't noticed that in the photos. More wood is always good though.
Nick
    June 2015
Posted by Jnkm13 on Thursday, July 23, 2015 10:02 PM
Nick,
The bulkhead took me quite sometime to get the shape right. Not sure why such an important part is not included in the kit.
Jeremy
    March 2015
Posted by NickD on Saturday, July 25, 2015 2:06 PM
Jeremy,
I was dreading it but it seemed to OK though the gaps probably don't stand up to scrutiny. Fortunately you won't be able to see them.
The kit is odd isn't it. Some of it is really really well done while other bits can only be described as poor. That bulkhead makes much more sense than the floor.
Nick
Posted by jeaton01 on Monday, July 27, 2015 10:42 PM
Sweet!
John
    February 2016
Posted by brooker on Wednesday, February 17, 2016 7:13 PM
I also have just purchased a kit of this model and I am delighted that there are 3 pages so far on the topic of building this model, as for me, this will be my first plastic kit build since I was a kid some 60 years ago. I have built warship models in a large scale, but in paper and card, so this will be a complete change of medium for me - also a help for repairs to Pocher models built, but which arrived broken and require some repairs and rebuilding...a pleasant retirement activity. Brooker.
