M & S Sports Porsche 962 Transkit 1/24
    April 2014
Posted by Sandbox on Monday, April 6, 2015 7:26 AM
I picked up M & S Sports resin conversion kit last week.  This is my first auto kit.  The body seems to have a slightly rough texture to it.  will I need to sand this before starting the painting process?  What grit sand paper should I start with?  How many different grit papers should I go through?  Anybody have any experience with this resin kits to share?
Posted by Don Stauffer on Monday, April 6, 2015 8:34 AM
I'd use a full bodied primer on it before sanding.  Those full bodied primers such as Krylon will do some filling as well as priming.
    June 2010
Posted by OctaneOrange on Friday, April 10, 2015 7:24 PM
like any sanding, start with a low numbered grit and work your way to a high one. i'd suggest starting about 180, then 600. you don't want it too smooth, so the primer has something to grip.
