First Ever Auto Model
    July 2003
Posted by MonsterZero on Monday, January 25, 2016 10:01 AM
I bought my first ever car model. It's a red Ferrari from Revell. I have never built a car before, So I figured now would be a good time. I understand in order to achieve a beautiful glossy body, they mix gloss paint with some gloss lacquer. In what proportions?
Posted by midnightprowler on Monday, January 25, 2016 11:46 AM
Welcome to car modeling. No, not mix them, but you can paint the color, then put clear over that. Just remember to use like paints, as you can spray enamel over lacquer, but not the other way around.
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
    March 2012
Posted by mustang1989 on Monday, January 25, 2016 1:52 PM
I found this out ..............the hard way. Never lacquer over enamels...............ever.Surprise
I'll give you some information you can use here. Go to the link below and order this DVD. Follow it step-by-step and you'll be fine. It's one of the most thorough explanations to painting that I can find for automotive finishes. The guys name is Donn Yost. Just order the DVD. You can't mess it up.
http://www.oldmansmodels.com/id76.html
 Forum | Modelers Social Club Forum (proboards.com)
Posted by Don Stauffer on Tuesday, January 26, 2016 8:56 AM
The problem with gloss paints is that you need to put on a fairly thick coat in order to get a good gloss.  With gloss enamels, this can lead to runs.  Using fast dry paints like acrylics and lacquers avoids the runs, but neither is very glossy as sprayed.  Lacquer tends to be glossier than acrylics.  Acrylics need gloss coat- a clear but glossy finish.  Lacquers can be polished with polishing compounds to bring up the gloss.  So there is no single way, all three types of paint will work- you just need to use the appropriate method for the paint you use.
