Thanks Crown, I've slowly but surely been working on my El Camino. The engine block went together with no issues, easy as pie. I had to add some detail to it however, and used soldering wire that my Uncle had given me as spark plug wires. I researched and printed out a firing order diagram for a 305 cid motor, drilled out holes in the block with my dremel tool, and ran the soldering wire to the correct location on the distributor. I then painted the wires flat black. I dry brushed flat black on some of the edged surfaces of the motor, to give the effect of a little bit of dirt and oil...but not too much!
The interior was the next step. I painted the floor and dashboard and door interiors per the instructions...which I later found out were inaccurate. After a bit of research, I found out that you couldn't order an El Camino SS in 1986 with a black interior. So I guess my Elky has gone from "stock" to "custom" I spent a LONG time super-detailing the dashboard, using the smallest brushes I had and even the tip of a toothpick to detail the climate controls, gauges, am/fm/cassette player, and the CB radio that was supplied on one of the sprues.
With the exception of the interior of the roof, the interior of the El Camino is complete. I've also put together the wheels. The next step will be to work on the underside of this car/truck hybrid.
