Ok fellas. This one's now on the bench after my 7 month ordeal with my Monogram 69 Camaro Project.
Going to shake things up a bit in the order that I do things as I'm going to build the engine first this time. I've been holding off on that part of the build until a later stage with the last few builds in order to get all the theory right but this time I've still got a couple of items to pick up with one of those being another set of aluminum wheels with five lugs instead of four. The four luggers were supposed to be used on my 1990 LX 5.0 Mustang build. I'll be having the same offset for the rear wheels and will be using the 15x3-1/2" wheels up front and all. I've gotta make the switch due to the fact that I just don't know of many four lug rear axles holding up to a 460. (yeah I know, you'd think I was building a real car or something!! lol).
One of these days I hope to be building a 1:1 scale 460 powered Fox Body. I've seen whats involved and it aint that bad. Stock hood'll close right over one .....and that's no s#*@! ![;)](http://storage.proboards.com/forum/images/smiley/wink.png)
The layout of the box stock kit which I forgot to post in the intro to this thread.
![](http://i1061.photobucket.com/albums/t469/bf109g430mm/Revell%20Mustang%20Street%20Machine/Mustang%20Shots%20001_zpswd66bmjb.jpg)
As usual I'm going to TRY to keep this thing fairly simple but you know how that goes.
As for the resin engine. I'm already kind of niffed at it so far. There was no oil pan in the package!!! That right there tiks me off because I PAYED for a complete motor.
I'm over it as I had one in the stash and can work through it but dangit man! Gimme what I pay for. I mean..........c'mon!! Secondly look at the photo below:
![](http://i.ebayimg.com/images/g/CSAAAOSwBahVQsH9/s-l1600.jpg)
The cylinder heads were installed upside down and this is on the advertised picture. See how that intake manifold fits snuggly against the heads on both sides and the engine block at the front of the intake manifold? Yeah, well when the heads are installed CORRECTLY, meaning turned the freak over, 1.) the intake doesn't fit that well at all, and 2.) the cylinder heads are too wide for the engine block deck. Good Lord people!!!
Makes you wanna do that "Three Stooges Slap" to a guy ya know?
The solution? I cut a piece of black plastic styrene from Evergreen the perfect size of the intake manifold area and installed it on top and sanded the sides to increase the entire deck area to allow the cylinder heads to fit perfectly on the deck.
![](http://i1061.photobucket.com/albums/t469/bf109g430mm/Revell%20Mustang%20Street%20Machine/Mustang%20Shots%20002_zps32265puh.jpg)
The layout before everything gets test fitted in place and I'll be figuring out how I'm going to fix the front of that oil pan:
![](http://i1061.photobucket.com/albums/t469/bf109g430mm/Revell%20Mustang%20Street%20Machine/Mustang%20Shots%20004_zpsilja5ivg.jpg)
and the trial fit with everything lining up. Now I can proceed with removing the oil pan, stripping the chrome and black basing the entire assy. Here's how it's supposed to look folks.
![](http://i1061.photobucket.com/albums/t469/bf109g430mm/Revell%20Mustang%20Street%20Machine/Mustang%20Shots%20003_zpsmikbkogx.jpg)
![](http://i1061.photobucket.com/albums/t469/bf109g430mm/Revell%20Mustang%20Street%20Machine/Mustang%20Shots%20005_zpsbhcuhugb.jpg)
Was thinking of going a little wild with the engine in terms of paint and theme choice.
![](http://i1061.photobucket.com/albums/t469/bf109g430mm/Revell%20Mustang%20Street%20Machine/Wicked%20460_zpsjqfitrqh.jpg)
