Help finding a specific model
    January 2017
Posted by ecotec83 on Wednesday, January 12, 2022 7:25 PM
Hoping someone here can give me a hand. My coworker used to drive a tow truck for BP fuels when he was younger and wants to build a replica of that truck. Does anyone know of a company making a plastic model kit of the 1968-1970 Ford F-350 homles wrecker?  Done some digging but havent had much luck so far. Thanks
Here a link with the truck in question
http://davidsclassiccars.com/ford/109688-1969-ford-f350-4wd-holmes-440-wrecker-nut-amp-bolt-restoration-f100-f250.html
    August 2021
Posted by lurch on Wednesday, January 12, 2022 7:33 PM
There is a shop in St.Paul, Mn that has old kits. Not sure if they have one but you can give them a try. Its called Scale Model Supply. Good luck hope you find what you are looking for.
Posted by keavdog on Wednesday, January 12, 2022 7:44 PM
Maybe this
Plus this (pricey)
Thanks,
John
    August 2021
Posted by goldhammer88 on Wednesday, January 12, 2022 9:35 PM
Don't know about availability, but there was a '67 Ford with a service body.  Looks like a 4x2, but single rear wheel.
Main differences between '67-'72 was the grille and trim levels.  I had a '70 Ranger back in the day.
    January 2017
Posted by ecotec83 on Sunday, January 16, 2022 5:41 PM
Thanks for the info, sounds like he may have to get the truck and add the towing gear onto it from another kit.
    June 2010
Posted by OctaneOrange on Monday, January 17, 2022 2:15 AM
I'd do what keavdog suggested and combine the truck with the wrecker
That's what I did to make this International Wrecker
    August 2021
Posted by goldhammer88 on Monday, January 17, 2022 9:23 AM
Depending on his skills, might be able to try scratching the tow bed.  Most were built up from flat plate.  The hardest thing would be the boom and winches.
