2000 GTR Skyline [FINISHED]
    October 2020
Posted by Scale-Master on Tuesday, December 20, 2022 6:03 PM
Something simpler to tinker on while I wait for stuff to dry on other projects.  I have a basic plan…
Mostly I've just been cleaning up the parts and shooting some of them when I'm painting the same colors on other parts.  But since I had the body prepped I went ahead and shot it TS-56 Cheeze Wiz.
Build what you want and build it for yourself, the rest will follow... Mark D. Jones
Posted by keavdog on Wednesday, December 21, 2022 7:17 PM
That is pretty much Cheese Wiz.  Which kit is this?
Thanks,
John
    October 2020
Posted by Scale-Master on Wednesday, December 21, 2022 7:18 PM
It's the Tamiya kit.
Most of the engine has been assembled.
    October 2020
Posted by Scale-Master on Thursday, December 22, 2022 10:01 AM
I spent more time painting the belt and pulleys than any other part on the engine.
I had to use the factory Sky Blue for the one pulley.
    May 2004
Posted by cbaltrin on Thursday, December 22, 2022 10:25 AM
Great looking engine!
On the Bench: Too Much
    October 2020
Posted by Scale-Master on Saturday, December 24, 2022 10:13 AM
Thanks!
The chassis is coming along.
    October 2020
Posted by Scale-Master on Monday, December 26, 2022 1:31 PM
The bottom of the chassis is done.  At least for now…
    June 2014
Posted by BrandonK on Monday, December 26, 2022 4:05 PM
I really like those older Skylines. Interesting color, cheez whiz. Won't have any issues seeing that one coming. Looks very cool and great work as usual.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    November 2003
Posted by bobbaily on Monday, December 26, 2022 4:12 PM
Great build-coming together nicely.
Looking forward to the finished build.
Bob
    May 2013
Posted by hogfanfs on Tuesday, December 27, 2022 1:32 PM
I agree, it's coming along really well. The details in the under carriage are fantastic.
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
Posted by keavdog on Tuesday, December 27, 2022 1:35 PM
Looks sharp Mark.  What color did you paint the rear sway bar?
Thanks,
John
    October 2020
Posted by Scale-Master on Tuesday, December 27, 2022 4:28 PM
Thanks guys!
John, I used clear orange over silver for the sway bars.
    October 2020
Posted by Scale-Master on Tuesday, December 27, 2022 4:29 PM
I didn't like the connection of the header to the exhaust.  So I "welded" them together.
    October 2020
Posted by Scale-Master on Thursday, December 29, 2022 10:44 AM
The engine bay is pretty much done.
    October 2020
Posted by Scale-Master on Friday, December 30, 2022 10:49 AM
Flocking/carpet didn't seem to fit the theme so the floor of the interior was sprayed with textured dark gray to simulate a rubberized coating.
The rest of the parts were painted as called out in the instructions, sort of…  I swapped Medium Gray for the Black inserts.  The silver and gray are brush painted.
    October 2020
Posted by Scale-Master on Tuesday, January 3, 2023 10:28 AM
The dash is done too.  I used the same painting technique for the wood grain as I did on the console.
    August 2007
Posted by DUSTER on Tuesday, January 3, 2023 9:53 PM
Very nice job on the interior panels, not say there is anything wrong with the  rest,
Steve
    October 2020
Posted by Scale-Master on Wednesday, January 4, 2023 10:55 AM
Thanks Steve.
The shoulder harnesses are shown in the instructions to be attached to the bottom of the front seats, but I decided to attach them more like I did on my real car and anchor them by the back seat.
Test fitting the body…
    January 2023
Posted by nr15656 on Wednesday, January 4, 2023 12:54 PM
Very nice job on the engine, looks good. Do you paint engines as you go, or when done? Or another way? I'm quite new to modeling and I'm having trouble getting my engines to look nice. Any advice would be very appreciated.
    October 2020
Posted by Scale-Master on Thursday, January 5, 2023 9:59 AM
nr15656
Depends on the engine and the kit.  Generally you want to assemble the pieces that make up the subassemblies that will be the same color and paint them after addressing the seams and such.  But smaller parts that are different colors are usually better off being painted separately then attached.
    October 2020
Posted by Scale-Master on Thursday, January 5, 2023 10:55 AM
Note to self.  Install the delicate tie rod after installing the body for the final time.  I drilled the ends of the part and will fix with a steel pin.
    October 2020
Posted by Scale-Master on Friday, January 6, 2023 10:35 AM
I'm good with this repair.  I had to sand just a little bit after cementing the pin in.  Then I brush repainted the center section.
    October 2020
Posted by Scale-Master on Saturday, January 7, 2023 11:13 AM
So much for painting the body early and letting it dry for a while… I was happy with both the color and the finish of the Bright (Cheez Whiz) Orange, but after working on the tug I decided I liked the Camel Yellow even more for it.  It also fits the inspiration for this project better, the BRE BrockBuster 510.
    January 2022
Posted by q20v on Monday, January 9, 2023 8:04 AM
Build is coming along nicely! Top notch work.
Posted by keavdog on Monday, January 9, 2023 9:58 AM
From Cheez Whiz to Frenchs Mustard Stick out tongue
Thanks,
John
    October 2020
Posted by Scale-Master on Tuesday, January 10, 2023 11:39 AM
Thanks guys!
The grille and taillights are done…
    October 2019
Posted by Tanker-Builder on Tuesday, January 10, 2023 3:47 PM
Geez!
 A purty yaller Car. Looking good fer sure!
    October 2020
Posted by Scale-Master on Thursday, January 12, 2023 10:21 AM
I planned to use both the front spoiler and the oil cooler, but upon reading the instructions I saw they were either one or the other.  Since I'm keeping this one out-of-the-box I bent up the PE oil cooler bracket to move the cooler up and forward.  Still OOB and I get to do it the way I had envisioned.
    October 2020
Posted by Scale-Master on Friday, January 13, 2023 11:58 AM
I started painting the window trim satin black, but decided a dead flat sheen better provided the high contrast look I wanted.  The panel lines were done with Tamiya Accent.
    April 2016
Posted by GlennH on Friday, January 13, 2023 3:38 PM
hogfanfs
I was just gonna say that looks like a well detailed kit.
A number Army Viet Nam scans from hundreds yet to be done:
https://www.flickr.com/photos/southwestdreams/albums/72157621855914355
Have had the great fortune to be on every side of the howitzers.
