Olds 442
    June 2009
Olds 442
Posted by jimbot58 on Wednesday, June 26, 2024 12:39 AM
The Chevelle's are still ongoing, though I keep getting distracted. This time, it is the Oldsmobile 442-W30. I never paid a whole lot of attention to them back in the day, but now I recently added a few aquisitions.
1967 Olds 442 W442 w-30 from Lindberg
Testors Dark Red, My phone doesn't really capture it but it is very close to the box art.
On my workbench now:
It's all about classic cars now!
Why can't I find the "Any" key on my keyboard?
    June 2009
Posted by jimbot58 on Wednesday, June 26, 2024 12:54 AM
    May 2009
Posted by Pawel on Wednesday, June 26, 2024 1:51 AM
jimbot58 - well I wish you good luck with your builds and I'll be watching!
When somebody say 442 I just have to post this one from back in the day:
1:72 Special Hobby AH-1G Cobra by Pawel
Have a nice day!
Paweł
www.vietnam.net.pl
    June 2009
Posted by jimbot58 on Thursday, June 27, 2024 1:43 AM
Tryingto paint and polish up the '67 body. The worst thing about this hobby is waiting for paint to dry. Any tips on getting those really shiney finishes?
    May 2009
Posted by Pawel on Thursday, June 27, 2024 2:14 AM
Hello!
My take on that was to put on several light coats of paint with light wet sanding with fine grit sandpaper between the coats. I let each coat dry about 48 hours before sanding, and you have to be careful not to sand through, this is especially critical on any edges or raised detail. Once you have good colour coverage it might be good to switch to clear coat, I had a good experience with the one from Gunze. I have a feeling it dries faster so you dont have to wait so long before sanding. After the final coat let it sit for afew days and then you can polish it with an automotive polishing paste and a soft cloth or paper tissue.
Hope this helps, good luck with your build
Pawel
www.vietnam.net.pl
    June 2009
Posted by jimbot58 on Sunday, June 30, 2024 12:38 PM
Pawel
Hello!
Pawel
I know what you are saying. You can see the original red I started with inside the engine bay and it has been multiple sessions just to cover it. I didn't like that red. Lots of patience and work on other projects waiting for paint to dry. I know the fenders will call for orange on these cars.
One thing to start is the engine. Lindgerg calls for blue and I know many of these were actually gold. Photos online show both, though the majority are gold. I went for the "Olds" blue from MCW. It's my build after all! Smile
I actually use Colgate toothpaste for polishing and it actually works pretty good. That's the results you see so far on the roof.
fox
    January 2007
Posted by fox on Sunday, June 30, 2024 9:29 PM
Lookin good!Yes
Stay safe.
Jim Captain
 Main WIP:
    June 2009
Posted by jimbot58 on Sunday, July 7, 2024 3:47 PM
Carpet monster got me today. One of the rear coil springs jumped off the bench and off to places unknown. One side of the rear axle is going to get a little peice of sprue in place of it. Doesn't matter as you absolutly can not see it once the axle is in place.
fox
    January 2007
Posted by fox on Monday, July 8, 2024 7:53 PM
I don't have that problem any more. Just had laminated flooring put in the whole house. My loft (workroom) got a very nice light grey. When a pin hits the floor, it sounds like a 12"ruler and you can hear if it rolls or not. If you drop something and you don't hear it hit then you have a problem. Wink
Stay safe.
Jim Captain
 Main WIP:
    June 2009
Posted by jimbot58 on Monday, July 8, 2024 11:46 PM
fox
Stay safe.
Jim Captain
I am considering putting down some plywood under my work area as it is, because it is shag carpet. The wheels of my chair sink down into it. I tried putting down one of those plastic protectors but that just made it worse. The wheels just make wells and the chair won't roll.
It doesn't matter what I do to the floor as it is already a wreck. It's a mobile home and has absolutly no resale value.
In the meantime, after an hour long search, I moved on. I created a fake with a stub of sprue and some copper wire.
Once it's painted and buried under the car, nobody but you and I will know it's there! And yes, that's a little filler drying on the back of the differential cover.
Nothing will save the carpet in any case as it has had more than a few bottles of paint spilled on it anyway.
fox
    January 2007
Posted by fox on Tuesday, July 9, 2024 9:23 PM
That was my problem too. Plush carpet with a clear mat under the chair. Sink holes in the mat and when I pushed back from the desk the chair rolled off the mat and the wheels sunk. Today was my first day back at work on the bench after unloading everything. My wife couldn't believe how quiet it was up there today. No banging the chair when lifting it back onto the pad and no expletives deleted coming from me.
One slight difference. Everything sounds louder in the room. Voices, music and things that fall and hit the floor. Mission accomplished.
Stay safe.
Jim Captain
PS - Good luck
 Main WIP:
    November 2018
Posted by oldermodelguy on Monday, July 22, 2024 5:11 AM
jimbot58
This is pretty much how I get the shiny finish with enamel, the same way Andy does it in the video. It also works with decanted Rustoleum 2X gloss paints, just add a bit less lacquer thinner. Anyway, here is the link:  https://youtu.be/lCKZ_fo4eW0
Also Tamiya LP gloss lacquer, thinned with Mr Leveling Thinner ( specifically MLT) will give a very high gloss finish right out of the airbrush. With LP you can use a finer tip and less pressure, as well.
    July 2024
Posted by Papaof2 on Tuesday, July 23, 2024 3:37 PM
Got same kit. Doing it in white with a black vinyl top. Was my first car.!
    June 2009
Posted by jimbot58 on Saturday, August 3, 2024 9:48 AM
Papaof2
I didn't give a whole lot of attention to the 442 back in the day as I was a hard core Chevrolet nut with my '68 Chevelle. Years later I am rediscovering these Detroit beasts in modeling!
    June 2009
Posted by jimbot58 on Saturday, August 3, 2024 11:04 AM
An oversight on the 442! Discovered I had missed a molding seam on the trunk deck lid. I had to resand and remove it:
There is a huge amount of chome in front and the back as well. I hope I fully captured those orange plastic fender liners, Just held with some tape for now. I know the turn indicators should be white but I like the amber, Stands out more
My first red interior. I have tended to favor black inteiors as they are simple. The other 442 will have a black inteior with white seats.
Much like this:
    April 2020
Posted by Eaglecash867 on Saturday, August 3, 2024 1:52 PM
Wow!  Well, it looks like you have the shiny finish question answered.  Nice work, Jim!
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    June 2009
Posted by jimbot58 on Saturday, August 3, 2024 3:39 PM
Eaglecash867
The bad thing is this Testors Gloss Dark Red is almost translucent. It's has taken multiple coats to get the paint to cover and the repair on the deck lid is going to be the same. I think 80% of my time is waiting for paint to dry.
