carperting flock question
Posted by Anonymous on Tuesday, November 16, 2004 10:01 AM
ived used flocking before, but not with good results. my question is about applying it. i have heard of putting it directly on the paint after it is sprayed on, using clear parts glue, and using diluted white glue. which one of these works best. and what steps do i take after applying it to assure an even, realistic finish. thanks-mark.
Posted by Anonymous on Tuesday, November 16, 2004 12:55 PM
I use what they call Tack White glue its real thick and heavy and it drys some what slow but it works a lot better then any white glue i have seen.
Chas
Shaw Custom Aluminum headers
    January 2004
Posted by mkhoot on Tuesday, November 16, 2004 1:48 PM
I brush paint a flat color close to the color of the flocking and apply while the paint is still wet working in small areas.
When in doubt just build it. Mark http://www.ipmslivonia.org/ipms/
    July 2003
Posted by lizardqing on Tuesday, November 16, 2004 5:06 PM
The only way I have tried it Mark is with the flat paint useing a color a bit darker than the flocking to give it a bit of shadowing effect , it wirked pretty good after I figured it out.
Posted by Anonymous on Tuesday, November 16, 2004 6:16 PM
alright, thanks for the tips, i will practice will all the ideas to se which one i prefer. thanks.
Posted by LoneWolf1Seven on Tuesday, November 16, 2004 6:27 PM
What I do and has been very good is to use dull coat in a spray can, put a light to medium mist and sift it through a sifter or window screan, no shine at all.
"When you're gambling always put your money heads down, never let money look you in the face!" "If I die before I wake, hit the snooze button for me!!!"
Posted by Anonymous on Tuesday, November 16, 2004 10:41 PM
i cant concievably see myself flocking an interior, but here is what seems to be an excellent link http://www.italianhorses.net/Tutorials/Flocking/flocking.htm
hope this helps
Posted by Anonymous on Wednesday, November 17, 2004 4:20 PM
awsome link, thanks for the tips guys.
    March 2004
Posted by DanCooper on Friday, November 19, 2004 6:03 AM
This flocking stuff looks great, but I've never seen it in my hobbyshop. Where can I find it ???
On the bench : Revell's 1/125 RV Calypso
    March 2004
Posted by DanCooper on Friday, November 19, 2004 6:04 AM
hope this helps
Well I guess carpets would look kind of strange in the "office" of a F-14 Smile [:)]
