Ok, you guys knew it had to happen.
I sneaked a peak into the kit and here is what I saw.
The parts(33) are as follows:
4 resin parts for the body(upper/lower, tank and a sidecover)
2 clear vac-formed parts for the wind screens(will get a replacement set just in case)
6 clear parts for the headlights, tailights, etc.(might replace a few with AM parts)
3 rubber tires(2 small 1 large)
1 set of decals
17 white metal parts for rear spoiler, mirrors, handlebars, axles, connector rods, engine cover, disc brakes and 3 rims for the tires.
Instructions are typical for japanese resin kits(parts list, 4 assembly steps, 1 decal placing image.
Overall looks like it will be an impressive little model when it is finished. now it has to go back under the X-mas tree till next year when I officially can open the kit.
[edit]
Might pick up a 2nd copy of the kit when I am in japan later this week.
[/edit]
